Old 01-22-2011, 07:47 PM   #1
tifreak
My Ride: sdfgsdf
Depo sidemarker fitment
I just got a set of clear Depo sidemarkers for my facelift sedan but when I went to put them in they don't even come close to fitting. It looks like the part that's supposed to hook on the opposite side of the metal spring doesn't come out far enough so it can't catch the fender hole like it should.
I'm just curious if anyone's had the same problem with these so I can tell if they're both defective or if it's just a poor design.
tifreak is offline   Reply With Quote
Old 01-22-2011, 09:32 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
It's part of the design, you need to notch the plastic tab that hooks onto the fender deeper to hold into place.
Old 01-23-2011, 01:08 PM   #3
tifreak
My Ride: sdfgsdf
so they won't fit unless I modify them? not thrilled about that
Old 01-23-2011, 04:03 PM   #4
Evap
My Ride: rubs tires
Just get a razor blade and shave that section that doesn't fit. :p
Evap is offline   Reply With Quote
Old 01-23-2011, 04:45 PM   #5
elliotchong
My Ride: bmw 320i
i had to use my dremel to make that area a bit wider to snap into the fender. it is a poor product if you have to do stuff like that to make it fit. I also found alot of condensation getting into mine. i went back and bought OEM and the fit was so much better. Felt like my fender just sucked the lense back into place.
elliotchong is offline   Reply With Quote
Old 01-23-2011, 06:36 PM   #6
tifreak
My Ride: sdfgsdf
well that was money well spent
anyone have any experience with the Apexcone markers sold by DDM? I'll probably just get those instead if the fit's better, plus the darker smoked matches my corners better anyway
