Old 01-23-2011, 05:22 PM   #1
kaosblue
My Ride: 2001 330ci
Ballasts?
I just replaced my ballasts after they failed so I got new bulbs/ballasts from umnitza. After installing the new items, I'm now getting radio interference whenever I turn my lights on. Checked all my connections and everything seems right. Any suggestions on how to correct this? I have an '01 330CI business CD headunit. Thanks for any info.
kaosblue is offline   Reply With Quote
Old 01-23-2011, 05:59 PM   #2
infinite012
My Ride: White '08 STI
Radio interference is caused by cheap/non OEM ballasts.
infinite012 is offline   Reply With Quote
Old 01-23-2011, 06:59 PM   #3
Evap
My Ride: rubs tires
That doesn't explain anything, infinite. I've got non-OEM ballasts, and I have absolutely no radio interference whatsover.
Kaos, did you have OEM ballasts before? Is your car coded for xenons?
Evap is offline   Reply With Quote
Old 01-23-2011, 07:22 PM   #4
infinite012
It explains everything. Cheaply made ballasts will cause RF interference. Hell, some OEM ballasts cause RF interference. It's the nature of the electronics of the ballasts.
Old 01-23-2011, 07:47 PM   #5
E462NV
My Ride: e46 5spd sedan
Place a wire from the back of the stereo deck to the the chassis as another ground. Let me know if it eliminates the interference or minimizes it.
** '07 Armada LE l '00 GS300 l '93 Talon TSi l ^would u? **
E462NV is offline   Reply With Quote
Old 01-23-2011, 10:42 PM   #6
kaosblue
My Ride: 2001 330ci
These are umnitza's P46's that have been reflashed by the dealership not to throw an error code. The radio interference has only happened with the new bulbs/ballast, also from umnitza. I'll try running another ground wire to see if I can eliminate the problems and post the results asap, thanks for the help.
