Engine & Performance
Old 01-24-2011, 09:47 AM   #1
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
330 6 speed transmission, uuc shifter, driveshaft
I acquired this transmission with 65,000 miles, and since have added 10k.
What I'm including:
transmission, crossmember, tranny bracket, mounts
$1300+shipping
driveshaft
$250+shipping
uuc short shifter with dssr
sold!
dssr and sled still available, pm me if there's interest
will consider lower price if bundled together, but otherwise firm on prices
I originally purchased this as a trade+cash for cams and headers
separate but attached listing:
flywheel/clutch package
(sold)
EDIT: what will this fit?
this will fit any m50, m50tu, m52, m52tu, m54, s50US, s50 euro, s52, or s54... this may also bolt onto a m20, but of that I'm uncertain. this will also fit any chassis equipped with one of the aforementioned engines. However, this requires a specific shifter sled and clutch/flywheel package made for this transmission. This transmission is unique in that it mounts the pilot bearing in the flywheel, this spline was also only found on m54s from 03 to end of production, but that's only specific to the clutch disc. But it still mounts right up on an e34, e36 or even a swapped e30.
If you have any questions about fitment, I should be able to fill you in further. Feel free to post in here or PM me.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 01-24-2011, 02:16 PM   #2
Shinji Hirako
My Ride: 325xi
will it fit XI??
Shinji Hirako is offline   Reply With Quote
Old 01-24-2011, 02:54 PM   #3
maarten22
My Ride: BMW E46 330Ci
JBR flywheel, southbend stage 3 sprung clutch disc, spec tage 2+ pressure plate
entire assembly custom-balanced
this is an extremely smooth setup, little to no chatter, made for 570 crank tq
this setup originally cost me:
$600/ flywheel
$750/ spec clutch
$100/ balancing
$450/ southbend special surface and add sprung hub
I'm asking:
$600+shipping
How many miles on these parts and wil it fit a 5 speed?
maarten22 is offline   Reply With Quote
Old 01-24-2011, 05:55 PM   #4
bluejeansonfire
ninja editor
My Ride: m5xual
Originally Posted by Shinji Hirako View Post
will it fit XI??
sorry, no it wont
edited above for mileage
this will only fit ms45-equipped getrag 5 speed transmission (fine spline, bearing in the flywheel) or 6 speed with the same setup, fine spline, bearing in the flywheel found on m54b30s 03 and later
so this shouldn't work with your transmission unless you wound up with the wrong transmission. In the US, the only 5 speeds that this would work with came out in 03-06 m54b25.
this will not work with the 10-spline ZF 5 speed
Old 01-25-2011, 09:51 AM   #5
bluejeansonfire
ninja editor
My Ride: m5xual
just added pics to the OP
so
bump
Old 01-26-2011, 09:31 AM   #6
Lemonsqr
My Ride: 2001 TiAg 330i
Any gear problems with the trans? What driveshaft (flange pattern) and condition?
Lemonsqr is offline   Reply With Quote
Old 01-26-2011, 09:57 AM   #7
bluejeansonfire
ninja editor
My Ride: m5xual
not at all, it shifts smoothly through all gears... the driveshaft is made for a 330, thus uses the 330 input flange for the diff (six-bolt, cv-joint style). If needed, I can include the diff input flange.
everything is straight and was working on my car, I'm just looking to go to something with more clutch options
the driveshaft balance was checked, and it's well. The driveshaft also comes with a 5k mile old center bearing and a 10k mile old cv joint (yes, they're replaceable, but kinda expensive)
Old 01-26-2011, 10:40 AM   #8
jacobs323i
My Ride: blown 323i
bump for a good guy!
jacobs323i is offline   Reply With Quote
Old 01-27-2011, 11:32 AM   #9
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Nice. Wish I had the cash! Bump for a good seller/Fanatic!
Old 01-27-2011, 12:27 PM   #10
darksideracer69
My Ride: 01 325ci
seems like a great package for anyone wanting to do a 6speed swap
IMAG02051
Old 01-27-2011, 01:54 PM   #11
Big Dave
My Ride: 330i sport touring.
This is just what im after at a good price,,,, pity im in the UK.....DAMN...
Big Dave is offline   Reply With Quote
Old 01-27-2011, 02:45 PM   #12
bluejeansonfire
ninja editor
My Ride: m5xual
I put the right price for the american market, it should be even more attractive overseas. I'll be happy to ship abroad, it wouldn't even be the largest car parts shipment I've made across international borders.... but shipping and duties are on you
Old 01-27-2011, 05:30 PM   #13
aggieE46
Keep it clean
aggieE46's Avatar
Sent you a PM, just in case...
Old 01-28-2011, 09:08 AM   #14
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I can vouch for Julio's shipping.
His packaging is the best I have ever recieved with used parts.
Old 01-29-2011, 01:25 AM   #15
bluejeansonfire
ninja editor
My Ride: m5xual
thanks for all the compliments guys!
clutch/flywheel package and the unlisted kaaz lsd chunk are pending sale
still available, though carrying some interest is the transmission/driveshaft/shifter package
Old 01-31-2011, 02:12 AM   #16
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
I know this is very Tempting
BimmerBrakes is offline   Reply With Quote
Old 02-03-2011, 09:05 AM   #17
bluejeansonfire
ninja editor
My Ride: m5xual
flywheel and clutch sold... transmission, shifter, driveshaft still available
Old 02-03-2011, 05:50 PM   #18
RideZERO6866
My Ride: 2002 330ci
pm sent
RideZERO6866 is offline   Reply With Quote
Old 02-06-2011, 11:45 PM   #19
Bigjake
My Ride: 2000 BMW 323ci
Might want for my 323ci since 2nd gear just went out last night
Bigjake is offline   Reply With Quote
Old 02-12-2011, 09:32 PM   #20
bluejeansonfire
ninja editor
My Ride: m5xual
this is still available
330ci, 330i, tranny, trans, transmission
