Old 01-24-2011, 12:09 PM   #1
209BMW328CI
My Ride: 328 Ci
Unhappy Rear Bearing Replacement Project Failed.
Hey Everyone,
So this weekend I attempted to replace my rear passenger side wheel bearing that going bad. I have the usual sounds and vibrations coming from the rear of my car when going over 30 mph accompanied by vibrations now. So I've also been reading all the DIY's for this project for about 3 weeks now everyday so I could be familiar with all the steps. I've also ordered all the parts from Pelican Parts and of course all the tools. I was going to buy the BMW B90-BMW special bearing tool but at that cost I didn't. Just going to use a two different pullers and a harmonic balancer to put the bearings back on the hub.
So I got to taking apart everything and got stuck on the e-brake and the drive axle. I could not get the Drive Axle out of the wheel! Not only that but I had to take apart the E-brake and I could not get the E-Brake Expanding Lock back on correctly. So right now I'm with out my E-Brake! Does anyone know how to put this part back? This is the part that connects to the E-brake wire attached to the HUB. I've done all the searching already on both this forum and on the internet with out any luck. I've included some pictures of the part. I HOPE someone has an idea that can help.
Thanks again.
Dave
209BMW328CI is offline   Reply With Quote
Old 01-24-2011, 12:57 PM   #2
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
I've replaced mine about 5 months ago. and let me tell you, putting that ebrake together took me longer than putting a new bearing in.
You are going to need a buddy who can help out with this.
it would help alot if you could get a hold of the tool in the picture. it definitely works when you need to get the springs in place.
G-Hots is offline   Reply With Quote
Old 01-24-2011, 04:06 PM   #3
xavi330i
My Ride: 2004 330i smg
I managed it without the tool. Forgot how, but it was probably a combo of flat-head screwdriver and pliers.
xavi330i is offline   Reply With Quote
Old 01-24-2011, 04:21 PM   #4
209BMW328CI
My Ride: 328 Ci
So that tool is needed to put the parking wire into the part labeled (2)? It seems like the parking break wire will need to be put in a special way so that it's hooked into the e-brake expanding lock. I'm just stuck on putting this back together not the actual springs.
Old 01-24-2011, 04:56 PM   #5
OrientBlau
My Ride: 2003 330i
I would take it to the dealer and get it done right.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 01-24-2011, 05:57 PM   #6
Thaniel
My Ride: 06 E90, 01 330
I'm having a hard time telling exactly where you are stuck. In general though thread the break adjuster together so it is as short as it goes before assembling. Often I find attaching the springs to the shoes then putting them on their mounts the easiest.
My LS1 V8 into E36 and then E46 Blog
www.LS1BMW.blogspot.com
Thaniel is offline   Reply With Quote
bearing, rear, wheel bearing
