Old 01-29-2011, 09:24 AM   #1
rob88ix
My Ride: 2001 325xiT
Electronic Transmission Control Module
Hello All,
Starting this thread for help because I searched by this topic, but didn't find anything that seems to match my circumstances exactly.
2001 325Xi Steptronic trans (GM I think) 160k on the car. It has the warning light on the dash that corresponds in the owner's manual to Electronic Transmission Control Module. The manual describes getting it to reset just by shutting off and restarting the car, that's not working - the light is staying on. But the funny thing is that the trans seems to be acting normally - it's not in limp mode. I'm also able to put it in the Manual mode and shift it through all the gears.
Anyone run into this before? The car is overdue for a fluid change, think that would take care of it? If I have to change that module, is it true that I have to take it to the dealer for programming to match my VIN? Some have said so, others say as long as you get the exact matching P/N it will work.
Thanks in advance for your help!
1988 325ix
2001 325xi SportWagon
Weather or Not!
rob88ix is offline   Reply With Quote
Old 01-29-2011, 12:24 PM   #2
Zyaltr
My Ride: 01-325cic,08-750Li
Try disconnecting the battery wait 5 minutes and reconnect, if it comes back you will need to have the codes pulled...You cannot diagnose this system otherwise.
Zyaltr is offline   Reply With Quote
control, module, transmission
