Thread Tools Search this Thread Rating: Thread Rating: 28 votes, 4.82 average. Display Modes
Old 07-31-2011, 12:43 AM   #281
hcardona111793
My Ride: 2004 325i
Originally Posted by Hollywood516 View Post
i took me about an hour a wheel to remove this stuff.. good luck taking it off!!!
Why where you taking it off? didnt last long?
i want to do it but it last too little compared to how long it takes and effort.
how long have you guys had it, those who have done it?
hcardona111793 is offline   Reply With Quote
Old 07-31-2011, 11:58 PM   #282
Carl589
My Ride: Bmw e46 3 series
i just received fricken liquid tape aerosol instead of plasti dip in the mail. does it do the same job or should i send it back?
Carl589 is offline   Reply With Quote
Old 08-01-2011, 01:08 AM   #283
///fox
My Ride: E46 325i
try it on some metal maybe the spare wheel? see what it does........
///fox is offline   Reply With Quote
Old 08-01-2011, 01:10 AM   #284
Carl589
i did spray a bit on the inside of the rim. i would imagine it turning out pretty similar after a few coats but dont know weather it would last as long. doesnt seem as heavy duty rubber as plastidip. if that makes sense
Old 08-01-2011, 10:31 AM   #285
///fox
My Ride: E46 325i
plastidip sucks too, it only lasts about 3 months if the weather is dry and not super hot.
Old 08-02-2011, 12:21 PM   #286
bignickmetro
My Ride: 2002 330ci TiAg
Just wanted to chime in, I painted a set of LTW rims that were badly peeling and nasty. Not sure if I like the black, but it did come out pretty good, and it gives me an idea of how they look if I want to spend the 4-500 bux and get them powdercoated. The silver one was the best of the 5, the rest were worse, down to bare aluminum in spots. Less than $15 and 1hour of time for all 5. I did 2 coats sprayed thick and wet.
bignickmetro is offline   Reply With Quote
Old 08-02-2011, 06:57 PM   #287
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
I bet a pressure washer would work great...
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 08-02-2011, 09:21 PM   #288
zsp
My Ride: 328
What a load of BS! My wheels have been plastidipped for way longer than 3 months and have gone through ~40-100 degrees since they've been painted.
zsp is offline   Reply With Quote
Old 08-02-2011, 10:04 PM   #289
2005 325i
My Ride: 05 325i
FVCK PLASTIDIP!
Tried it on my rims and it looked like sh!t so now I had to spend more money on actual paint
2005 325i
-Headers
-Straight piped
-Cold Air Intake
-2 Din Kenwood/ Mmats 12"
-Megan Racing Lowering Springs
2005 325i is offline   Reply With Quote
Old 08-07-2011, 09:29 AM   #290
Kmoy2002
My Ride: 2002tii, 540i, 330i
Check my images in the previous page but I finally got tired of the black look. Looks cheap compared to the nicely finished surface of the rim. I will admit this is a good solution if your wheels are pitted and in poor condition; or if you are curious to see what your car looks like with black wheels.
As far as removal goes. It did not take an hour a wheel. A pressure washer helps and makes light of work.
Kmoy2002 is offline   Reply With Quote
Old 08-31-2011, 03:05 AM   #291
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
time to remove my plastidip. going back to silver
omhl is offline   Reply With Quote
Old 08-31-2011, 04:47 PM   #292
///fox
My Ride: E46 325i
did the same, good luck getting it all off, it takes longer to get off than on!
Old 08-31-2011, 05:04 PM   #293
Dominic.G.
Banned
My Ride: Jetblack 1999 323i
I love plasti dip
Dominic.G. is offline   Reply With Quote
Old 08-31-2011, 05:05 PM   #294
Dominic.G.
Banned
ignore the failed attempt to two tone the interior with black vinyl paint. Fixing that asap
Old 08-31-2011, 05:05 PM   #295
Dominic.G.
Banned
also a trick to get it off. Turpentine melts it with a tiny bit of elbow grease
EDIT: OH AND!!! you don't need to mask off the tire. Just spray the wheel and don't worry about getting it on the tire. Once your done and have let it dry you can just rub the tire and the paint that got on the tire will rub off very easily.
Old 09-01-2011, 04:47 PM   #296
justin654
My Ride: 03 325xi
I wonder how this will look on my stock rims.
justin654 is offline   Reply With Quote
Old 09-01-2011, 04:59 PM   #297
offspring5713
My Ride: E46
Plastidip for the win. have had it for a
Few months and have no complains
offspring5713 is offline   Reply With Quote
Old 09-01-2011, 06:38 PM   #298
justin654
My Ride: 03 325xi
Picked up a can. I'll have to do it tomorrow since it's dark out already. I'll post pics asap. Thanks for the DIY
Old 09-02-2011, 09:26 AM   #299
Dominic.G.
Banned
you might want 3-4 cans.
Old 09-02-2011, 09:55 AM   #300
tb330
My Ride: 2006 Acura TL
Instead of masking tape use index cards..reusable for all the wheels and makes it pretty hard to get any over-spray! Also a little quicker setup, did this to my wheels and really like it so far. One of my wheels had something on it that the Plastidip didn't like so I have to touch up or redo that wheel.
I had to peel it off one of my wheels and only took like 10-15 mins to get it all off, but they were the style 137 wheels so fairly flat and easy to remove.
tb330 is offline   Reply With Quote
