E46 Xi Forum
Old 01-31-2011, 09:43 AM   #1
Capt1014
My Ride: 2002 325xi
Front end Knocking
Just replaced the,
Inner ball joints
Lower control arms and bushings,
Front struts
had the front end inspected for tightness....no loose items
Double checked all of the ball joints
There is no play in the steering wheel or Rack,
But every time I hit a small bump in the road under 55mph there is this knock that is pissing me off!!!!!!!
any ideas?
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
Old 01-31-2011, 10:36 AM   #2
Kubica
My Ride: 2003 325xi
Sway bar end links.
Old 01-31-2011, 10:42 AM   #3
SamDoe1
My Ride: 4cyl of fury
Originally Posted by Kubica View Post
Sway bar end links.
^that.
Old 01-31-2011, 11:49 AM   #4
Capt1014
My Ride: 2002 325xi
Nope, they were all checked.
Old 01-31-2011, 11:58 AM   #5
SamDoe1
Check again.
Old 01-31-2011, 11:59 AM   #6
Kubica
My Ride: 2003 325xi
Then it's probably the heat shield by the right side FCAB carrier.
My money is still on sway bar end links though- they are a pain to tighten and need to be very tight or else they will make noise.
Old 01-31-2011, 12:42 PM   #7
Capt1014
My Ride: 2002 325xi
I'll check again, it's a good solid "clunk" as tho it was a ball joint, so I don't htink it would be a heat sheild. Let you know how it turns out.
Old 01-31-2011, 12:46 PM   #8
SamDoe1
While you're at it, make sure everything is tight to spec down there.
Old 01-31-2011, 01:44 PM   #9
Capt1014
My Ride: 2002 325xi
Talking
ok
Old 01-31-2011, 01:57 PM   #10
Kubica
My Ride: 2003 325xi
Sway bar end-link then. They have to be real tight. Mine backed themselves off a few turns after I installed Bilsteins. Can sand down some paint on the bracket so this doesn't happen.
Old 01-31-2011, 03:15 PM   #11
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
Tell me about it.. why couldnt they just make it easy like the rwds..
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 01-31-2011, 05:05 PM   #12
Kubica
My Ride: 2003 325xi
I don't know why.
Do you remember what to tighten with? I think you need a T30 socket and a thin 13mm box wrench? I can't remember . . .
Old 02-01-2011, 04:32 PM   #13
wdeerfield
wdeerfield's Avatar
I don't know why.
yea, either a T25 or T30 and a 16mm box wrench that i had to cut the end off to fit in there (unless you want to take the splash shield out.
Couldnt get a torque wrench on it so i just made sure it was as tight as it was when i took it off.
Mine are probably loose as i have some noise on wheel turn and over bumps. Im going to replace them this spring.
Old 02-01-2011, 06:50 PM   #14
Rickna
My Ride: '01 330xi - '09 IS-F
Loctite-Blue
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-07-2011, 02:38 PM   #15
ECSTuning
ECSTuning's Avatar
My Ride: BMW
+1 to double/triple checking end links...
Best,
Joe
Old 02-07-2011, 02:53 PM   #16
Kubica
My Ride: 2003 325xi
16mm box wrench
Ah yes- I stole a stubby one from my dad's tool box a while ago.
Also helpful for changing the TC fluid . . .
