E46 Xi Forum
Old 02-02-2011, 07:12 PM   #21
RogueStatus37
My Ride: '04 330ci
Originally Posted by Kubica View Post
Sell your xi then.
It's an amazing machine for a talented driver, which you most certainly are not with an opinion like that.
The kid couldnt be any more right... A proper AWD (Audi, Subaru, Porsche and so on...) system have a center locking diff, and even better, an electronically controlled torque sensing diff meaning that the car will actually detect slip in one wheel and send power the other wheels. In the XI's, its like having 2 rwd drivetrains stuck together. One wheel will spin forever in the front, and one in the rear will spin forever and the other side of the car wont do anything. It will never send power to the wheels that need it. Its a poorly designed AWD system.
For anyone interested in more info: http://everything2.com/title/Torque+...g+Differential
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
Old 02-02-2011, 07:52 PM   #22
bigdog2003_99
My Ride: 2009 Audi B8
^+1 2 open diffs=fail... still beats my rwd though, even though i have lsd...
its about a good driver and good tires (mostly) the newer xi's seem to be pretty decent in the snow, maybe someone should retrofit that into an e46
btw if i ever get an xi it probably will get the 3.07 lsd out of my zhp if/when i upgrade to 3.38 lsd
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 02-02-2011, 08:14 PM   #23
RogueStatus37
My Ride: '04 330ci
Well obviously in the front, they have no choice but to make it an open diff. Just think about it, the car could only go straight because the wheels couldnt turn at different speeds. But in the rear, there is no reason they couldnt have put an LSD. Our suburban even has an LSD in the rear The reason the XI is so much better than the coupes is that 2 wheels HAVE to be spinning at all times instead of just 1 wheel with RWD. Plus the front wheel has the weight of the engine directly over it.
I believe the newer AWD BMWs have a torque sensing diff, which is a HUGE improvement to any AWD system.
Just remember your front and rear ratios have to match. It would annihilate your transfer case if you didnt.
Old 02-02-2011, 08:57 PM   #24
scottz
My Ride: 2001 325xi
Uhhh.... not true
the key is limited slip. Not a locker or a spool.
scottz is offline   Reply With Quote
Old 02-02-2011, 09:25 PM   #25
sbiggi
My Ride: 325Xi
Sell your xi then.
Sorry I dont swing from BMW nutts.
I love my car, it does handle very well compared to my other vehicals. That doesnt change the fact the awd system is lacking compared to most awd systems. Its better then rwd in snow, but its slow to react and doesnt have the grip that it would if it had a limited slip center and rear.
-Seth
2002 325Xi
2003 F250 Super Duty
2013 Volt
sbiggi is offline   Reply With Quote
Old 02-02-2011, 09:44 PM   #26
RogueStatus37
My Ride: '04 330ci
Originally Posted by scottz View Post
Uhhh.... not true
That is true. However, lsds get worn out over time (the more use, the quicker they wear) which is why you have to get them rebuilt over time. If you had the diff trying to rotate the outside wheel every single time you turned the wheel even a hair, it would wear out and lose its limited slip feature in a matter of days. Plus it would make turning feel like you had no power steering all the time.
Old 02-03-2011, 03:22 AM   #27
gurov
My Ride: 2004 325XI Turbo
Send a message via AIM to gurov Send a message via MSN to gurov
i've got a helical limited slip in the front end of my turbo sentra from the factory. no clutches there, so it is doable.
now, the awd system can be pretty terrible cause of the ops diffs... maybe i should start figuring out how that abs unit and pump work electronically... start working on my own traction control for low speeds.
2014 X1 - m-sport - stock
2004 325xi top mount turbo - megasquirt3 for engine, 5 speed swap. build thread
1994 supra MKIV - single 72mm - bc272 cams - super spec twin plate clutch - aem v2, 1000CC ID, dual denso pump, j&s ultrasafeguard
2004 SE-R SpecV turbo - megasquirt3 j&s ultrasafeguard - SOLD
gurov is offline   Reply With Quote
Old 02-03-2011, 08:32 AM   #28
scottz
My Ride: 2001 325xi
Really? Hmmm... lol, I think you need to get a little more experience with limited slip before you make statements like "it would wear out and lose its limited slip feature in a matter of days". Because it's just not true. Plenty of cars and trucks on the road to prove you wrong. And it would do the same thing to the rear as well.
Old 02-03-2011, 08:41 AM   #29
lotar_6
My Ride: '01 xi, '94 Rado
...If you had the diff trying to rotate the outside wheel every single time you turned the wheel even a hair, it would wear out and lose its limited slip feature in a matter of days. Plus it would make turning feel like you had no power steering all the time.
completely not true.
lotar_6 is offline   Reply With Quote
Old 02-03-2011, 10:23 AM   #30
SamDoe1
My Ride: 4cyl of fury
^That.
The limited slip feature only engages after a certain torque difference. If you're under that, it's an open diff and nothing is getting worn out.
Old 02-03-2011, 11:10 AM   #31
RogueStatus37
My Ride: '04 330ci
Originally Posted by SamDoe1 View Post
^That.
I didn't know that. That's good to know
Old 02-03-2011, 12:53 PM   #32
sbiggi
My Ride: 325Xi
And it all depends on the type.
The only kind that would need to be rebuilt is a clutch type. Helical and Viscous do not wear out.
And they all have their advantages and disadvantages.
^That.
I have no idea where you got that from.
Basics on some types of lsds:
A Helical limited splip will always attempt the trasnfer torque to the slower turning wheel. If you completely loose traction on a side, then it because a open diff and will just spin the tire that has no resistance.
Clutch type lsd always attempt to maintain the same speed between each wheel. They turn different speeds when the clutch friction is overcome. These can be tuned with different plutch plates and springs, and are sensative to fluid.
Viscous lsd has a ton of thin steel plates with a fluid in it (fluid being a grease type fluid). The plates have a bunch of holes in them. When the plates attempt to rotate against each other the visous fluid resist the movement and makes it hard for the plates to want to turn. A viscous is always resisting any speed difference between wheels, even if one tire is completely off the ground.
Then you have the bmw system. All open diffs. Ours uses the wheel speed sensors to look for speed differences. When it detects a wheel with excess speed compared to the others, it applys the abs system to that wheel which then slows the wheel and shifts the torque to the opposing wheel. Problem with that is you have to have enough speed difference before it detects the lose of traction, there is a very noticable delay in this. You basically have already spun the tire and lost all traction on that wheel before it does anything.
With any of the mechanical LSDs, it is a instanteous reponse, its already reacting before you even know a wheel has a speed difference.
-Seth
2002 325Xi
2013 Volt
Old 02-03-2011, 01:43 PM   #33
scottz
My Ride: 2001 325xi
The point is they don't wear out in a matter of days.
Old 02-03-2011, 02:53 PM   #34
ultimbro
My Ride: 325xi
Am I wrong ?
I've been reading this thread and I'm wondering if I get it right. I'm driving a 2005 325xi. I got my 2 rear wheels stucked in a mass of snow yesterday and the car wouldn't move. The front wheels were not turning. I thought that the AWD system would have help me but only the rear wheels were running free with no contact on the ground.
If I understood correctly what you are discussing, this is normal ?!
ultimbro is offline   Reply With Quote
Old 02-03-2011, 03:11 PM   #35
colo330xi
My Ride: 01 330xi
From reading about the DSC system, no that shouldn't happen. If DSC was off, yes you could have the front wheels stuck while the rear wheels continued to spin.
In that situation, the DSC system should brake the two rear wheels, forcing the front wheels to spin.
colo330xi is offline   Reply With Quote
Old 02-03-2011, 03:40 PM   #36
SamDoe1
A viscous LSD will wear out eventually. The fluid in the diff will eventually lose it's characteristics and not behave as it should.
What you described is essentially what I said with more information. The point of a limited slip differential is to allow it to work as both an open and a locked differential in one. I'm not saying that it's an instant locked to unlocked changeover, but there is a certain wheel speed/torque bias that will cause the wheels to turn at the same speed. Often times, this occurs gradually although it can be tuned to not occur gradually.
Mechanically, yes the LSD must always resist wheel speed differences. However, when that magical torque/speed bias is reached, clutch/gear/fluid is able to actually resist that difference. Below that torque/speed bias, it is not and will function as an open diff.
Old 02-03-2011, 04:06 PM   #37
ultimbro
My Ride: 325xi
I tried both with and without DSC and nothing changed. I realy don't think the front wheels were spinning. I'm not 100% sure since I was IN the car but anyway.... I'll try to check it up in the garage with the car raised and front wheels blocked. I bet rear wheels will spin free.
Old 02-03-2011, 04:10 PM   #38
sbiggi
My Ride: 325Xi
Next time that happen just apply the brakes at the same time as you are giving it gas. Should help some.
-Seth
2002 325Xi
2013 Volt
Old 02-03-2011, 10:07 PM   #39
Kubica
My Ride: 2003 325xi
The front diff can go into what I call 'TC preservation mode' when the rear wheels are spun too much.
When this happens, the front driveshaft is spinning but the front axles are not.
I just blew all your minds.
Old 02-04-2011, 12:34 AM   #40
mujjuman
My Ride: not an E46
Originally Posted by Mark M View Post
Ok....here are the simple observations from the test of the NV124 case on my workbench.
- Spinning input shaft by hand.....both output shafts rotate
- Spinning input shaft by hand and holding rear output shaft stationary.....front output shaft rotates.
- Spinning input shaft by hand and holding front output shaft stationary.....rear output shaft rotates.
Caveat....these tests were done with spinning by hand, which does not simulate rear world forces transmitted into the driveline.
Thus, my conclusion, you can NEVER make an XI into a rear wheel drive by simply disconnecting front driveshaft. It will just send all the power to the front output shaft and spin endlessly without putting power to the rear.
Thanks for the test. This makes me sad.... I did a similar test when the TC was taken out of my car.... except I only spun the front and rear output shafts. When I spun one output shaft, the other shaft spun as well. I didn't think to do other tests because I was just screwing around lol.
Can you plz check to see if your TC does the same? Spin one of the output shafts and see if the other one spins too...... Thanks
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
