Sponsored by The Tire Rack
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 02-01-2011, 04:59 PM   #1
balwinderb60
My Ride: 99 e46 328i 4door
E46 M3 wheels on a E46 Sedan????
Hi All,
Will E46 M3 wheels fit a E46 sedan?????? (stock suspension and i will get the fenders rolled if needed)
Im sure there are a million threads out there about this but i've searched and couldnt find anything.
Can someone forward me a link or any info??
Thanks!!!!
balwinderb60 is offline   Reply With Quote
Old 02-01-2011, 05:00 PM   #2
SalM
My Ride: Shhh
Yes they'll fit best if you get 4 m3 front rims since they're not as wide. But its going to rub like a mofoo
SalMPhotography
SalM is offline   Reply With Quote
Old 02-01-2011, 05:01 PM   #3
David328Ci
Wohnhafter perverser Mensch
My Ride: Pimpin '99 Sentra X(
Send a message via AIM to David328Ci
You'll need 4 front wheels. The wider rears won't fit.
David328Ci is offline   Reply With Quote
Old 02-02-2011, 12:53 PM   #4
DTMdan
My Ride: 2004 M3
Send a message via AIM to DTMdan
WRONG.
They will fit but I recommend getting a slightly smaller sized tire than the standard sizes they come with. Do a search, there are a lot of people running M3 wheels on non-Ms.
DTMdan is offline   Reply With Quote
Old 02-02-2011, 04:46 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
You could run them, but as mentioned above it would be better to run a slightly more narrow tire. It would be more trouble free with four fronts, but with enough work you could possibly run the rears as well.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-02-2011, 06:08 PM   #6
GunMoto
My Ride: EG8 | E46 | W211
Send a message via AIM to GunMoto
You'll need four (4) REAR wheels, appropriate tire size, rear fender roll, and drilled out fixed camber nipple on the front strut bearing.
GunMoto is offline   Reply With Quote
Old 02-02-2011, 11:46 PM   #7
balwinderb60
wow ur car looks siiiiick!! And because of that, i have a million questions for you....
Those are OEM M3 wheels? (not replicas)?
What are the wheel sizes (with offsets)?
What tire sizes are you running?
Any spacers?
What mods did u have to do to make them fit? (fender rolling etc.)?
I have some ugly cheezy chrome wheels on my E46 sedan....need them off ASAP and i want something like urs...looks classy like from the factory.
Old 02-02-2011, 11:47 PM   #8
balwinderb60
Originally Posted by DTMdan View Post
WRONG.
Any spacers?
Old 02-05-2011, 03:42 AM   #9
Bernard SA
My Ride: BMW 320i Individual
I have the same problem
E46 M3 19" 9J to fit on E46 Sedan 320i Individual
What can I do? Here in SA they say it cannot be done!
ID:	392193   Click image for larger version
Bernard SA is offline   Reply With Quote
Old 02-14-2011, 01:06 PM   #10
DavidB
My Ride: 2003 330i
I put 18" M3 wheels on my 2003 330i sedan this weekend and the rears rubbed
every time I hit a bump.
They looked good but the rears stick out a little past the wheels wells. Had to put my 17" style 68 wheels and tires back on yesterday.
Suppose I'm going to go with 4 M3 front wheels all the around?
I would appreciate any advice on this. Looks like I'm going to have swap or sell
the rear wheels which have good Michelin PS rubber.
David
DavidB is offline   Reply With Quote
Old 02-14-2011, 02:10 PM   #11
VMRWheels
VMRWheels's Avatar
David
Four M3 fronts should work fine.
Old 02-15-2011, 02:50 AM   #12
Bernard SA
David,
I managed to find a place where they can do this kind of thing here in SA. They advised that the rear wheel has to be re-engineered - they fit the wheel on the car (without the tyre), then do the measurements (it sticks out approx 20mm). They will now cut the inside of the wheel hub to make the 20mm space, re-weld & then drill out new holes. They claim it will work 100%....they have done this before on a 330ci. It takes about 2 weeks to prepare the wheel....I will send you pictures once it has been done. Hopefully it works out ok as they claim.
PS: No problems with the front wheels.
Old 02-15-2011, 12:16 PM   #13
C18wwn
My Ride: E46 320d
i've got staggered 18" M3s on my tourer
215/40 front and 225/40 rear
they tuck in all round, and dont rub
NOW:
'02 BMW X5 4.6is
Then:
'93 FD3s RX7
'03 BMW 320d tourer
'95 VW Golf VR6
'95 BMW M3
'99 VW Caddy
'90 BMW 535i Sport
'96 VW Golf 16v supercharged
C18wwn is offline   Reply With Quote
Old 02-15-2011, 12:54 PM   #14
VMRWheels
VMRWheels's Avatar
Originally Posted by Bernard SA View Post
David,
Widening and narrowing wheels is fairly common, but I would be careful about shaving off bits of the wheel back pad. It could alter the structural integrity of the wheel since that's the first place that weight will be distributed. If you shave off about 20mm, I'm guessing you'd be left with about 5mm of metal to mount to your car.
Old 02-15-2011, 06:02 PM   #15
DavidB
My Ride: 2003 330i
Kevin & Bernard,
Thanks for your response. Sounds like it would just be easier to
buy two front M3 wheels than modify the rears?
I am going to take the M3 fronts I have now and get the curb rash repaired and refinished. The place that does the repairs might be able to modify the rears.
David
Old 02-15-2011, 06:38 PM   #16
GunMoto
David,
I think they test fitted the rear wheels incorrectly.
I don't think OEM 19x9.5 et27 wheels are going to stick out 20mm past the fender. (Sounds like they just jacked the car up, put the M3 wheel on and saw that it stuck out 20mm while the suspension was drooped/unloaded, lol)
And why mill the back pad when you can fit the wheel with slightly narrower tires and rolled fenders? This has already been done on a sedan, search for DTMdan.
Old 02-15-2011, 08:08 PM   #17
Little Dragon
My Ride: E46s
Four fronts will fit with no problems. I run 235/35/19 dropped on H&R sport springs and don't rub at all.
Rears will not fit without heavy modification, hence why I went with four fronts. If you have the time/money to get the rears modified, I say do it. It'll be worth it.
But if you don't have money like me, four fronts will do just fine...
Little Dragon is offline   Reply With Quote
Old 02-15-2011, 08:18 PM   #18
GunMoto
Fender rolling = heavy modification?
Old 02-15-2011, 08:31 PM   #19
jaycard73
My Ride: '02 325xi
love those M3 wheels..where'd you get them?
jaycard73 is offline   Reply With Quote
Old 02-15-2011, 08:34 PM   #20
Little Dragon
My Ride: E46s
I'm pretty sure it was much more than a simple "fender roll" or else I would've done it.
Got a set of 2 fronts, 2 rears locally and traded the 2 rears with a guy that wanted 4 rears. And then I had 4 fronts!
