Sponsored by BAVSOUND
Old 05-04-2003, 01:49 PM   #1
JRoz
My Ride: 2000 323ci
Send a message via AIM to JRoz
help on molding
Hey im going to make a custom lcd in my dash..underneath the ac control and cd player..where the ashtray and blank bay is. I was wondering if anyone could give me any help. I know that i need to use fiberglass...but i was wondering if everyone made a mold before hand. I plan on taking the lcd..and mounting it in the middle of the area..next taking some type of material..or newspaper and justmaking the outline around the lcd..but im not really sure what to use to make the outline. Then putting a thin layer on the news paper or whatever i use..making sort of a mold. Then taking fiberglass and pouring it into the mold. After that i would make some desings or cut out little areas where buttons are whatever..but i just need soem help on the basics of it..kina like the material to make a mold..other then that.i got it undercontrol..let me know if anyone can help
thanks alot
Jason
Mods:
UUC TSE DTM Exhaust
Benfer CAI
Euro Clear Corners
SPP Bulbs
Carbon Fiber Dash
Predator Chromium DDE's
Carputer / 7" touchscreen
20% tints
Yellow Top Optima Battery
Work Hard..Mod Hard..Drive Hard
Carputer Specialist & Installer
Contact me for info
JRoz is offline   Reply With Quote
Old 05-04-2003, 02:05 PM   #2
msu76
My Ride: '02 Sterling Gray M3
I had mine done at a local shop. I can't remember all the specifics, but he roughly told me how he did it. I put an URL to some pictures of my setup below.
First, I think my installer used ABS--not fiberglass. He used the original cluster (sunglass holder, ash tray, and buttons) as a template. He approximated it for size first, then bent it along the same angles as the original cluster. Then he polished off the sides to get a tight fit. He then roughened up the surface with some medium grit sandpaper and painted it flat black to match the texture/color of my black interior.
I think you can do this with a Dremel and hot air gun. In any case, he said the whole process was a *itch--measuring out holes for the LCD screen and buttons, getting them to be on center.
Good luck!
http://www.villagephotos.com/pubbrow...elected=226388
msu76 is offline   Reply With Quote
Old 05-04-2003, 02:14 PM   #3
JRoz
My Ride: 2000 323ci
yo thanks alot.thats actually a really good idea..however..did he take the original pieces and put some type of surrounding over it..to make a mold or something..or did he just free hand it and mold the abs...so basically once he made the whole thing..he used a sander and then painted it black?..thats actually a really good idea..and by the way..looks great ...which monitor is that by the way
Jason
Mods:
UUC TSE DTM Exhaust
Benfer CAI
Euro Clear Corners
SPP Bulbs
Carbon Fiber Dash
20% tints
Contact me for info
Old 05-04-2003, 04:26 PM   #4
msu76
He sorta freehanded it... when you heat up that ABS, it's moldable. He put it up against the original cluster to get the bend just right. So he basically used the original cluster as a mold.
I don't know if that makes any sense. I'll try to spell it out... if you put the flat piece of ABS over the cluster, then heat ABS, the ABS can be worked into the same curvature as the original cluster.
The monitor is an Alpine TME-M760.
Old 05-04-2003, 04:49 PM   #5
JRoz
My Ride: 2000 323ci
yeah i get what your sayin except i may do somethin different..i may just use like abs plastic spray to make almost like thin plastic mold...so then i can just let it sit and harden..then just take it off..and stick in fiberglass to make the exact mold. Could i make the same type of finish as the ABS is with fiberglass...matching the other units..thanks
Jason
Mods:
UUC TSE DTM Exhaust
Benfer CAI
Euro Clear Corners
SPP Bulbs
Carbon Fiber Dash
20% tints
Contact me for info
Old 05-05-2003, 12:32 AM   #6
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
Originally posted by JRoz
abs plastic spray
Do they really make that??
SrCsTc is offline   Reply With Quote
Old 05-05-2003, 12:22 PM   #7
JRoz
My Ride: 2000 323ci
yeah they do make it...i found a site that does..6 different kinds...im gonna send you the link when i get home..im in a senior office class now hah
Jason
Mods:
UUC TSE DTM Exhaust
Benfer CAI
Euro Clear Corners
SPP Bulbs
Carbon Fiber Dash
20% tints
Contact me for info
Old 05-06-2003, 11:08 AM   #8
Shames
My Ride: none yet
Send a message via AIM to Shames
Smile abs spray
Could u send me the link for that abs spray.
JJasinski7@aol.com
Shames is offline   Reply With Quote
