Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 02-02-2011, 03:39 PM   #1
ohio330
My Ride: 330
help with noise please
So I have this noise in the rear when going over bumps slowly or when the suspension articulates while going over bumps/dips in the road. Its a rattling sound kinda like a bad shock mount. I have Rogue RSMs and I rebuilt them in an effort to make the sound go away, but it didn't. So I replaced those with stock RSMs and I still have the noise. I have ST coilovers and am only lowered enough to get rid of the wheel gap. All other joints/bushings have been verified ok by a bmw garage. any suggestions on what else to check? TIA
ohio330 is offline   Reply With Quote
Old 02-06-2011, 09:18 AM   #2
pyrocrickett
My Ride: 2004 330i ZHP
Did you get your subframe mount points inspected?
'04 ///ZHP sedan 6MT
pyrocrickett is offline   Reply With Quote
Old 02-08-2011, 04:53 PM   #3
ohio330
My Ride: 330
got it checked when new bushings went in. was ok
Old 02-15-2011, 04:33 PM   #4
Jikisan
My Ride: '01 330i
spring pads maybe?
Jikisan is offline   Reply With Quote
Old 02-19-2011, 01:40 PM   #5
4ndyhuynh
My Ride: 2001 BMW 325i
I had a similar problem and it turned out to be that the bolt retaining the trailing arm was loose, so you should check that if you havn't already.
4ndyhuynh is offline   Reply With Quote
