E46 Xi Forum
Old 02-05-2011, 02:19 PM   #1
anhtu402
My Ride: 2002 BMW 325XI
Stick Shift to the right?
I have a question to see if anyone has this problem as well. Has anyone's stick shift gotten stuck to the right before? Right beneath #5 instead of being in the middle #3? It happened to me twice, and both occurred when it was extremely cold out. Let me know if anyone ever experienced this.
anhtu402 is offline   Reply With Quote
Old 02-05-2011, 02:52 PM   #2
jgold47
My Ride: 2004 X5 3.0
no but mine has this weird notchiness to the right. I was going to take everything apart and replace that white ring the shifter sits in, but it seems we cant do that in an XI without dropping the tranny.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 02-05-2011, 03:02 PM   #3
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
http://forum.e46fanatics.com/showthr...=5th+gear+flop
http://forum.e46fanatics.com/showthread.php?t=438087
it's a spring in your tranny that get stuck in a bushing especially in cold weather.
i've seen a diy somewhere but it involves dropping the transmission.
Old 02-05-2011, 04:41 PM   #4
Dreamliner330
My Ride: 330xi
It only does it when cold, it doesn't cause any mechanical drive issues, the fix is too intensive to worry about, and it goes away after 10 minutes of driving...
Dreamliner330 is offline   Reply With Quote
Old 02-05-2011, 10:07 PM   #5
Kubica
My Ride: 2003 325xi
I havnt had this problem after changing the tranny fluid to redline d4 ATF.
If that doesn't work just live with it.
Old 02-05-2011, 11:17 PM   #6
SLVRXI
My Ride: 2001 325xi
I have had this problem as well but it will do it at running temp or at first start. My shifter will also pop up out of the white ring from time to time. But I plan on replacing it when i put a short shifter in.
SLVRXI is offline   Reply With Quote
Old 02-12-2011, 11:44 AM   #7
mujjuman
My Ride: not an E46
I just live with it
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 02-12-2011, 05:32 PM   #8
Kubica
My Ride: 2003 325xi
Originally Posted by mujjuman View Post
I just live with it
Have you changed the fluid recently?
I'm serious when I say that cured it for me.
Old 02-12-2011, 05:39 PM   #9
mujjuman
My Ride: not an E46
I used oem fluid tho.
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 02-13-2011, 12:58 AM   #10
chsu74
My Ride: 550XI,993TT,GL320
The spring housing and tranny case are made out of different metals and they shrink at different rates especially when cold. It is only when the tranny case is warm where the temperature is the same and end up with the same tolerances.
chsu74 is offline   Reply With Quote
