E46 Xi Forum
Old 02-05-2011, 04:50 PM   #1
celluloidheros
My Ride: 2001 330 xi
Broken Rear Spring-again 2001 330xi 82k orig owner
Hello,
I have owned my car since 1/2001. it was built in 12/00. I live in rochester ny, so we have lots of salt/snow. The rear springs break on the bottom of the spring in the small diameter of the spring. I think that the metal is not stress relived properly and that the salt /rust doesn't help things any. The height of the car drops a small amount (1/2 inch or so). The dealers in this area always check the springs when they have your car because it's an easy install . I have broken 4 springs so far and do not beat on the car at all.
I run stock size 17 inch wheels/tires in the summer and BMW 17/7 steel rims/225/45/17 Hakkapelliita's in the winter
Anyway, I need a rear spring or set of springs. My one thought is to install some H & R's and only replace the stock shocks (w/Bilsteins) when they blow out in a year or so. Another thought is to buy 1 or 2 from Bavarian AUTO RECYCLERS.
http://www.data.bmrparts.com/bmwpart...42695356U.html
Pelican and Tischer sell OEM rear springs for $ 120 or so
I can get H and R's for $265 shipped. (that's a set of 4 springs too) CAN I JUST USE THE REAR H & R SPRINGS and leave the front alone for now ?
http://www.turnermotorsport.com/html...ppingZip=14580
I just hate to put OEM springs in when i know they are semi defective. This really should be a recall item.
I think I have green stripe color coding on the springs but I have to check. does anyone have a spring or two they would like to sell ?
Any recommendations ? I wonder if the eibachs or h & r's will break like the oem's. Thanks in advance, CH
celluloidheros is offline   Reply With Quote
Old 02-05-2011, 05:18 PM   #2
colo330xi
My Ride: 01 330xi
I think the only issue you'd run into is the H&R or Eibach springs will lower the rear, and the front will stay stock height. In addition to just looking weird, it might make the front end feel loose. (purely speculation on my part)
It looks like new springs will have a 1 year warranty, so they do have that much going for them. If you keep breaking the oem ones, might as well try something different right?
colo330xi is offline   Reply With Quote
Old 02-05-2011, 05:19 PM   #3
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
you shouldn't mix springs. i would go with eibach if you live in Rochester. I have H&R and dont mind them at all but they can be a bit harsh on terrible roads.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 02-05-2011, 06:21 PM   #4
The_Don
My Ride: 2001, 325Ci
I have stock rear sport springs that I just took off this summer. They are in pretty good condition, and the only reason I took them out is because I upgraded to coilovers. I believe that these are the green striped ones as well. Crazy that you've already been through two sets of rear springs. I can only guess that it's the weather and salt you guys have to deal with up north. Mine's a socal car, so it doesn't get nearly the punishment from the weather. Shoot me a PM If you're interested in the springs. Good luck!
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II -
- RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI -
- M3 Motor Mounts -
For Sale
The_Don is offline   Reply With Quote
Old 02-05-2011, 10:05 PM   #5
Kubica
My Ride: 2003 325xi
We should start a class action suit against BMW for defective springs and for not updating the part.
Old 02-06-2011, 07:28 AM   #6
celluloidheros
here's the p/n of the springs that i have in there 33-53-6-775-573 . thanks for the offer "the don". Let me pull the rear wheel and verify what color that i have in there. BMW used different springs on each car depending on the options installed.
"the don" did you say yours were sport springs off a 325ci ?
Does anyone know how to cross reference BMW color coding on springs with mfg p/n's ? I'd like to find out what color 33-53-6-775-573 is ?
I can say this, that car with aggressive Hakkapelliita snow tires is hard to beat in the snow.
Thanks again, Don C.
Old 02-06-2011, 07:56 AM   #7
celluloidheros
OK Ok i gto off my butt and pulled the rear wheel. We got 6 inches of lake effect snow so it was slushy out there but at least i have a garage. My springs have the white stripes. I loooked at my last dealer bill and these correspond to bmw p/n 33-53-6-775-573. "the don", can you check your color for me ?
Old 02-06-2011, 01:15 PM   #8
The_Don
My rear springs are the green striped ones and my fronts were, I think I remember correctly, double white stripes. It's the color code for sport suspension for '01. I don't know what other year(s) this color corresponds with, but i looked it up on a reference chart on this forum. I will see if I can't find that reference link for you. My car is a coupe, so it has the sport suspension standard anyway.
- M3 Motor Mounts -
For Sale
Old 02-06-2011, 05:26 PM   #9
celluloidheros
Thanks Don, that's too funny, my name is "Don" and i like the group "The White stripes" there's some humor in there somewhere. OK, so now where do I buy some used whitestripe springs from ? At least i have the BMW p/n 33-53-6-775-573 thanks again, dc
Old 02-13-2011, 01:03 AM   #10
chsu74
My Ride: 550XI,993TT,GL320
If you are doing the install yourself, it makes sense to buy used springs. I would buy a new set if I am paying an Indy and save the install cost when the used set craps out again.
chsu74 is offline   Reply With Quote
Old 02-14-2011, 10:43 PM   #11
srm5161
My Ride: 325xi
Something similar happened to me over the summer...I was tight on time and only had a few days when I broke a rear spring...so i ended up buying the H&Rs from tirerack. I only put the rears on as those saved a lot of time..
I didnt notice any difference what so ever after running this setup for about 5 months. the front end felt no different then before. Im also from the snowy northeast and get pounded quite frequently. The lower rear didnt affect anything at all..
Overall i didnt notice that the rear was lower...i only began to notice when i finally got around to putting the front springs on...good luck op
srm5161 is offline   Reply With Quote
