Old 02-09-2011, 12:07 PM   #1
FreddyMags
My Ride: 2001 325ci
ABS, Brake, and Traction Control Fault
The ABS, Brake, and Traction fault lights have illuminated recently. I have since noticed that the Brake fault light will start off yellow and when I step on the brake they pulse (believe ABS kicks in) until I apply more pressure. The light then turns red and I have normal brake power, however the lights stay on and sometimes the speedometer fails and will stay at zero regardless of my speed. I experienced this same exact problem a few months ago and was instructed to replaced the evaporator control valve. I replaced this valve because it was indicated on my service engine code but I didnt think it had anything to do with the ABS. Miraculously enough when I did replace the valve the ABS issue went away but to return again now. Can anyone shed some insight on what is causing this issue? Thank you.
FreddyMags is offline   Reply With Quote
Old 02-09-2011, 12:39 PM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
read here
http://forum.e46fanatics.com/showthr...648&highlight=
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-09-2011, 03:10 PM   #3
Tymm
My Ride: 320ci E46, 325i E92,
ts your rear left abs/speed sensor that you need to check 1st
2000 BMW 320ci 2.2ltr
Tymm is offline   Reply With Quote
Old 02-09-2011, 03:37 PM   #4
Another BM
My Ride: 330ci
+1
thats what i was gonna say
Another BM is offline   Reply With Quote
Old 02-10-2011, 08:12 AM   #5
FreddyMags
My Ride: 2001 325ci
Well now it has gotten much worse. The Transmission warning light (exclaimation point inside a gear) came on last night followed by the service engine light and the car appears to be stuck in 3rd gear. When I shift to Reverse or Neutral the transmission jerks the car into gear. I was going to try and drive it over to a independent BMW mechanic to check all the codes but I didnt want to risk burning up the tranny. I just had the transmission replaced 3 years ago after the first one did something very similar.
Old 02-10-2011, 08:13 AM   #6
330ciandr6
My Ride: .
probably gonna need a trans...get the codes read first.
Old 02-10-2011, 12:13 PM   #7
FreddyMags
My Ride: 2001 325ci
Is it possible that these problems are being caused by the MAF Sensor? Was thinking maybe my car switched to limp mode.
Old 02-10-2011, 01:06 PM   #8
Tymm
I have just about 2 hours ago replaced my rear left abs/speed sensor and now I have speedo and NO lights on the dash WOO HOO! I managed to get a salvage 1 for about 15 only took 30mins to do
Old 02-10-2011, 02:24 PM   #9
FreddyMags
My Ride: 2001 325ci
Did you experience the same issue with your transmission (limp mode)?
Old 02-10-2011, 03:35 PM   #10
g4LLiT0
My Ride: 99 Bmw
it maybe the asc/abs control unit, or transmission output sensor aka pulse generator..
g4LLiT0 is offline   Reply With Quote
