Sponsored by BimmerWorld
Old 02-09-2011, 02:11 PM   #1
mikerob97
My Ride: 2006 BMW M3 Cabrio
Question for 323 Owners running 330 Brakes
Hello - I have a questions for owners of 323s that have installed the 330 front brakes.
Did you change the master cyliner? I noticed the part numbers are different for the 323 and the 330 on pre 9/2000 cars. Mine is a 5/2000, 323 and I am thinking about swapping to 330 calipers. Wanted to know if I also need to switch out the master cylinder.
Thanks in advance for your comments,
Mike
mikerob97 is offline   Reply With Quote
Old 02-12-2011, 12:29 PM   #2
t84toy
My Ride: 323 CI
No !!
t84toy is offline   Reply With Quote
Old 02-12-2011, 01:48 PM   #3
mikerob97
Originally Posted by t84toy View Post
No !!
Could you elaborate on your reply?
Old 02-13-2011, 12:37 AM   #4
cnotesdip
My Ride: 330ci
you dont need to change the master cylinder so like t8 said NO
cnotesdip is offline   Reply With Quote
Old 02-13-2011, 12:37 AM   #5
cnotesdip
My Ride: 330ci
I GOT SOME rear m3 calipers for cheap calipers and carriers
Old 02-13-2011, 12:38 AM   #6
cnotesdip
My Ride: 330ci
$50 plus shipping
Old 02-13-2011, 06:47 AM   #7
mikerob97
Was wondering if you knew the what the differences are between the two different parts - for instance, do you know the if the master cylinder piston diameters are the same?
Are you running the 330i front calipers on you car?
Did you also change the rears calipers or did you leave the rears stock?
Thanks in Advance for your replies,
Mike
Old 02-13-2011, 10:33 AM   #8
Aaron90
My Ride: 328i
i swapped to 330i front and rear rotors/calipers on my car and did not change the master cylinder. I'm not sure if I apply here though (I have a 328i), too lazy to check realoem right now
Aaron90 is offline   Reply With Quote
Old 02-18-2011, 09:23 AM   #9
BartenderPlease
My Ride: '03 540i/6 M-Sport
Do not change it, your 323 master cyl. will clamp the 330 brakes just fine. My 328 master cyl. works like OEM on the 330 brakes.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 02-20-2011, 12:43 PM   #10
t84toy
My Ride: 323 CI
Sure !!!
I have Stop Tech in the front and I did the rear 330 conversion (including e-brake).. Same Booster same master cylinder. It is a monster on braking power..
