Sponsored by BimmerWorld
Old 02-10-2011, 04:06 PM   #1
acpstunts
My Ride: E46 330ci / E53 X5
Rear adj. control arm recommendations?
Ive been doing a lot of research and still very undecided. I was going to go with ksports, but there on back order. I need something with a lot of adjustability (neg degree). I noticed alot of manufacturers dont list much in terms of adjustments.
What are you guys running ? Any recommendations?
acpstunts is offline   Reply With Quote
Old 02-10-2011, 04:21 PM   #2
be-doubleyou
My Ride: 02 325ci
I run UUC arms and have adjusted them to -5* without any problems. They are essentially the same as SPC arms but just with a chromoly center rods. Bimmerworld also makes an affordable set or steel arms that run about $180 if price is a concern.
Bill
be-doubleyou is offline   Reply With Quote
Old 02-10-2011, 04:28 PM   #3
acpstunts
Ive seen them, but I noticed SPC says -1/+3 for the adjustment... Does that mean total, or over stock?
Old 02-10-2011, 04:30 PM   #4
acpstunts
btw Im going to need to run -4/-5 in the rear with my new setup, just to give you an idea
Old 02-11-2011, 12:20 AM   #5
acpstunts
http://www.velocitymotorcars.com/adj...-3-series.html
I stumbled upon these and via the description and user feedback I think these might be the ones
Old 02-14-2011, 11:14 PM   #6
be-doubleyou
My Ride: 02 325ci
I think its rated to reflect adjustment beyond stock adjustment.
They look pretty good. I've never seen them before but since they are designed to give the amount of adjment you need i would say get them and try them out.
Bill
