Go Back   E46Fanatics > Everything Else > Other BMW Models
Other BMW Models
All other BMW model questions! For additional model specific forums check out bimmerfest.com!
Please post all E90/E91/E92/E93 and new M3 news at E90Fanatics.com
Old 02-10-2011, 03:19 PM   #1
steel330i
My Ride: E46 330i & '90 318i
Rear end differential...
So before any bashing is needed, I understand that I should have posted this somewhere else, but I'm looking for somewhat of a quick response...Can someone please tell me what Rearend Diff. I may have based on my speed and RPMs? I tried to Google this with no luck... thanks all
P.S. check out that gas mileage for this tank!
-Travis
E46's are timeless, but E30's are classic!
My "Painting Your Interior Trim" DIY- http://forum.e46fanatics.com/showthread.php?t=798917
E30's FTW!!!
steel330i is offline   Reply With Quote
Old 02-10-2011, 03:25 PM   #2
E92M
E92M's Avatar
My Ride: '08 M3 | '03 R6
-Travis
What chassis and model car is this?
What gear were you in?
Those would help us figure it out,
-Chris
E92M is offline   Reply With Quote
Old 02-10-2011, 03:30 PM   #3
nk_zhp
My Ride: ZHP / E30 M3
It's almost impossible to answer this unless you provide the tire size that *should* on that car, vs the tires size that's on the car. As he ^ said, the gear you're in. And it appears that you are in an E30 325.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 02-10-2011, 03:34 PM   #4
steel330i
My fault slipped my mind...so E30 318i with the M42 1.8L...5th gear(5 speed) and tires are 195/65R14...
E30's FTW!!!
Old 02-10-2011, 03:39 PM   #5
jcns
My Ride: California
it looks like it's stock to me.
e30 318i had a higher ratio diff(bigger number) than 325i/is in order to provide better acceleration.
374miles on 3/4tank is good I think. I wish my e30 325is got that but given the mods I had I could not complain too much.
Time for new pads?!
jcns is offline   Reply With Quote
Old 02-10-2011, 03:39 PM   #6
Lemonsqr
My Ride: 2001 TiAg 330i
this is the calculator you will need. Find out what gears are in the E30 and play around with the final gear ratio to determine what it is.
http://www.bokchoys.com/differential...calculator.htm
Lemonsqr is offline   Reply With Quote
Old 02-10-2011, 03:46 PM   #7
Alex323Ci
My Ride: M3 & 323Ci (sold)
I'm going to say 4.10 (but not certain)
OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK
CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF
Old 02-10-2011, 03:52 PM   #8
BeMyWhip
My Ride: 01 BMW 330ci
this forum is "E46Fanatics", so you may get some of us who dont give a sh1T.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 02-10-2011, 03:56 PM   #9
Platinum Plus Quality
My Ride: M54B30
I believe 4.10s were stock on automatic E30s.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 02-12-2011, 11:14 AM   #10
steel330i
I have a 5 speed
E30's FTW!!!
Old 02-13-2011, 02:11 PM   #11
udelaware30
My Ride: 91 318is 24v swap
you have a 4.10 diff, this diff came stock in your car.
you are running the exact rpm and speed as i do in 5th
most likely a small case unless it has been changed out.
I blew the **** out of mine once i swapped the m42 for an m20.
Now with an m52 the real fun has begun
E30's FTMFW
udelaware30 is offline   Reply With Quote
Old 02-14-2011, 12:54 PM   #12
wikolipr
My Ride: 01' E46 M3
Post this question in www.r3vlimited.com or www.e30tech.com. You would probably get a quicker response there.
For Sale:
OEM M3 18s Size Dunlop Winter Sport 3D Tires
PM for details...
wikolipr is offline   Reply With Quote
Old 02-14-2011, 01:08 PM   #13
udelaware30
It is a 4.10 small case. Get under the car and check the metal tag on the diff cover. It will state the ratio. If it says S4.10 then you have a limited slip. If there is no 'S' prefix then it will just say 4.10 and be an open differential.
Don't bother posting this thread on r3vlimited or e30tech. Theyre going to tell you the same thing I just did and make smart ass remarks. However, there is a great deal of info and good people on those forums.
Enjoy your e30, the newer cars are nothing like em! Especially these damn e46's
