Old 04-21-2011, 10:04 AM   #21
McSpeed
My Ride: 2005 ZHP TT Stg 1
I use a cutting lubricant from Walter that you can spray on the bit...helps a ton. Also, I let the bit do the work...putting more pressure just dulls the bit faster...which is a never ending spiral of needing more pressure to cut.
Gotcha
Question- what's the recommended tapping depth for 1/8 NPT?
I've heard that leaving 5-7 threads visible on the tap is the way to do it but it seems like that leaves about half of the threads exposed on the sender (when screwing the sender in by hand without any teflon anyway). Is that desirable? Given the heaviness of the Autometer pressure sender I kind of wanted it to thread as much as possible so as to provide the best support.
Originally Posted by joejo9795 View Post
Can it fit M52TU?
Dunno. If it uses the same oil filter cap as the M54, then yes. VAC might know.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 04-21-2011, 12:16 PM   #22
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
Originally Posted by McSpeed View Post
If the side taps are unfiltered, would a tap near the center of the top be....filtered?
I think so, though even more unsure of whether that would be a good idea.
Can it fit M52TU?
yes, same oil filter, same housing
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 04-21-2011, 12:30 PM   #23
joejo9795
My Ride: 323IA E46
HIOP Racetec 3.0L Stroker Kit, Active Autowerke Supercharger Kit with Rotrex C38-71 stage II, intercooler kit, Dr. Schrick Camshaft, EMP Stewart Water Pump,Supersprint Style Header, Magnaflow Race Cat, Eisenmann Race System Dual Exhaust Tips, UUC Short Shifter EVO3 with DSSR, UUC Stage II Aluminum Lightweight Flywheel with Performance Organic Clutch, QUAIFE LSD, AEM Water Injection Kit.
joejo9795 is offline   Reply With Quote
Old 04-24-2011, 12:57 PM   #24
McSpeed
Tapping was easy. I used a T wrench from autozone and splashed on some rubbing alcohol every half turn.
The hard part was cleaning the aluminum shavings off. The cap had oil residue in it from when I did the test fitting and aluminum micro-dust was stuck in every nook an cranny. It took a unbelievable hour long repeating campaign of degreaser, alcohol, heat gunning, compressed air, Q-tips, dental picks and paper towels to finally get it all off.
Next I put in the senders with 2 wraps of teflon tape and went for a high rpm drive to make sure the seals were sealed at full heat/oil pressure. After a little weepage I ended up tightening both of them down more.
Then it was time for wiring. These instructions were very helpful: http://www.csua.berkeley.edu/~lleong/vdo_install/
Notes:
1. I used an Add-a-circuit crimped to the three red gauge wires to get switched power to the gauges. Also, each red wire was given a separate inline Littlefuse per Autometer's instructions.
2. I couldn't get the dimmable face lighting to work by splicing into the ash tray light's positive wire (the non brown one?). Whenever it was attached the gauges went crazy and turned on and off every second displaying weird numbers. I decided I was happy with the red digital numbers anyway and left those wires unconnected.
3. The wideband connector was too big for the usual nipple firewall entry point so I used the larger grommet nearby and popped out the sound insulation knockout with a long screw driver. This larger opening was way easier with all the chunky Autometer connectors.
4. There was a grounding problem with the oil pressure sender initially. It caused the pressure gauge to show a no-sender-connected 'E0' error code if the pressure was below 30 psi:
I read that teflon tape (and oil?) can sometimes prevent a sender from grounding perfectly through its threads and cause this kind of problem. The Autometer instructions suggest grounding to somewhere on the body of the sender in this situation. This is my workaround for the time being:
Everything else was straightforward.
Here's the wiring path until I get around to tubing it up and/or extending it so it doesn't have to pass over the washer fluid tank.
And here's the payoff for staying up till 3AM last night (note that the wideband sensor is not plugged yet so it's just making up AFRs):
ID:	401410   Click image for larger version
ID:	401417   Click image for larger version
ID:	401418   Click image for larger version
ID:	401420   Click image for larger version
Old 04-24-2011, 02:34 PM   #25
bluejeansonfire
ninja editor
My Ride: m5xual
sick ish! that 3-gauge bezel looks mighty familiar. Everything looks really nice, from the gauges down to the filter cap. One thing I never considered about this cap, that doesn't apply for the metal cap, bolt-through setups is that you have to unthread the senders to change the filter.
Old 04-24-2011, 03:11 PM   #26
InDiGlOM3
My Ride: HPF M3 stg 2.5
Thats a huge ugly sensor.....but its functional so I suppose thats all that matters. they have a special teflon type tape that is conductive......
Old 04-24-2011, 03:33 PM   #27
SweTurbo
Big Pimpin'
My Ride: 323i -98
Just a tip here:
Run the wires behind the engine and though the fuel rail cover , just remember to heatwrap/sokcet them first
The grounding issue can be solved by soldering a wire to the unit and then clamping a O-clamp on the other end and then connected to the engine hinge nut
Apart from that it looks pretty nice
Old 04-24-2011, 07:52 PM   #28
McSpeed
Thanks. That's the good ole LeatherZ bezel alright. Yeah- I'm not sure why they did the side mount vs. top, but the caps were under development for long enough that there must be a reason...
I don't mind the looks but I do wonder why it has to be freakin humongous. Good to know on the conductive teflon.
Originally Posted by Pir4t View Post
Just a tip here:
Thanks. Smart grounding idea. Going under fuel rail cover would be super clean.
Has anyone else wrassled with the dimming function on Autometer gauge faces?
Old 04-24-2011, 08:53 PM   #29
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I think you have to grab the dimmer lead from the LCM. That's where I got it for my Defi gauges.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-26-2011, 08:10 AM   #30
McSpeed
The sensitive LED lighting of these gauges seems to be the issue. Followup here: http://forum.e46fanatics.com/showthr...8#post13088908
Old 04-26-2011, 12:24 PM   #31
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
An oil change looks fun.
jbfrancis3
jbfrancis3 is offline   Reply With Quote
Old 02-19-2012, 05:14 PM   #32
McSpeed
Any idea where I could get that tape, InDiGlOM3?
Old 03-22-2012, 06:46 PM   #33
McSpeed
Followup:
Permatex High Temperature Thread Sealant works awesome. Provides both a solid ground and a perfect seal:
http://www.permatex.com/documents/td...tive/59214.pdf
Old 03-22-2012, 06:58 PM   #34
TrippinBimmer
My Ride: Just Fast!
I guess u take this everytime u do oil change? Worried about the threads wear out?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 03-22-2012, 07:05 PM   #35
McSpeed
nah - brass on billet aluminum - those NPT threads aren't goin anywhere. With the slick sealant and a normal wrench it's a smooth tightening process and you can feel right when they bottom out.
Old 01-20-2013, 12:55 AM   #36
IrocThe325i
My Ride: is turning japanese
i was about to do this but that looks like a PITA every time you want to change you're oil filter...
IrocThe325i is offline   Reply With Quote
Old 01-20-2013, 07:02 AM   #37
McSpeed
eh it's a little more work but it's not bad: detach wires -> clean old sealant out of threads with a paper towel...reapply sealant -> screw senders in till bottom out -> reattach wires.
I'd say it's worth it for the ease of sender install, i.e. better than having a leaky sender block in a nearly unreachable place imo
Old 01-20-2013, 09:08 AM   #38
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Good to see you are still around.
Old 01-20-2013, 09:51 AM   #39
McSpeed
likewise
