E46 Xi Forum
Old 02-10-2011, 11:42 PM   #1
mreuroworld
Account Under Review
My Ride: E46
01 325xi changed brand new front axles from autopartsway but shakes til i do over
i just bought left and right front drive axles. i removed them saw black style oil all around the wheel wall. Anyway i installed both of them and now the left side when I give it gas(sometimes) the whole front end will wobble and shake at low rpm's but the shake will go away over 3000rpm. It will shake and wobble but when I let go of the gas pedal, it goes away and then when I give it gas its fine.
i was reading about greasing them which i didn't do.
do i need to grease the drive axles?
if so which parts do I grease.
also what type of grease should i use?
what did i do wrong and how do i correct this?
thank you fellow members!!!!!!!please help me
mreuroworld is offline   Reply With Quote
Old 02-11-2011, 06:34 AM   #2
TCSKIBIKE
My Ride: 2001 325XIT m5sp
You bought the whole axle? Was there rubber boots on each end which were sealed? If so the grease should be in there and I would imagine it is already.
TCSKIBIKE is offline   Reply With Quote
Old 02-13-2011, 08:32 AM   #3
mreuroworld
My Ride: E46
ya your right it wasn't grease. it was front differential oil spilled out
Old 02-14-2011, 11:01 AM   #4
mreuroworld
My Ride: E46
Kubica is a great e46 fanatic member and a good friend
