Sponsored by BimmerWorld
Old 02-11-2011, 01:38 AM   #1
1nyce46
My Ride: 02 bmw 330i
Send a message via AIM to 1nyce46
shaking at over 65mph
hey guys quick question i just brought a bmw 330i. previous owner said it needs a driver side bushing only thing it does is that at 65mph or higher it shakes alot when hitting a curve or following the roads turns at those speeds,however if i slow down to about 50-55 it doesnt shake on regluar city driving everything feels good, just wondering in your opinions does this sound like like it could be the problem cuase i searched and even saw a video posted here on bad control arm and mine doesnt have those sythoms just what i described.....also is it easy to tell just by visual inspection if it could be bushings or control arms?thanks in advance for any help
1nyce46 is offline   Reply With Quote
Old 02-11-2011, 01:43 AM   #2
E46Moonlight
My Ride: 2000 323i
take it to a shop. it's better to diagnose it at a shop instead of having someone over the internet diagnose it and spending money on random parts hoping to fix the problem. Impressive Auto Center Inc. 718-335-0212
Martino Auto Concepts 516-676-7985
Motorcepts 917-287-2116
on that note. it can be a number of things. Bushings, control arm, wrapped rotors, alignment, bad tire, etc//..
E46Moonlight is offline   Reply With Quote
Old 02-11-2011, 01:55 AM   #3
1nyce46
thanks will do... i already pmd motorcepts however rotors,tires look good and dont think alignment cause car runs good and straight. its just at high speeds making those sharp turns hey in your opinion which shop is more affordable money is a lil tight at the moment
Old 02-11-2011, 01:57 AM   #4
E46Moonlight
My Ride: 2000 323i
Motorcepts is the way to go. They'll work with you if your tight on $$
Old 02-11-2011, 02:04 AM   #5
aphhpa
My Ride: 2001 330Ci
Send a message via AIM to aphhpa
I had this problem. I replaced control arms and bushings. So it's Probably one or the other
aphhpa is offline   Reply With Quote
Old 02-11-2011, 02:05 AM   #6
1nyce46
thanks taking a trip this week then
Old 02-11-2011, 02:06 AM   #7
1nyce46
yea i figured hope its whatevers cheaper lol
Old 02-11-2011, 03:03 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
It could be as simple as an out of balance set of wheels, or even the bushings and control arms as mentioned above.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-11-2011, 10:34 PM   #9
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
If not these check tie rods while you're down there.
Sent from my DROIDX using Bimmer App
Jon Estrella
ESS TS2 - VMR V710 19" wheels - KW Coilovers - 3.46 Diff - Macht Schnell 5mm Rear Spacers - BMW Performance BBK w/ floating rotors -
BMW Performance Strut Brace - BMW Performance Air Intake - BMW Performance SSK/DSSR - Hawk HPS Brake Pads - SS Brake Lines -
OEM M3 RTAB w/ Vorshlag Limiters - Meyle HD FCAB - TMS Sway Bars w/ adjustable links - AEM Digital Boost Gauge -
Stewart w/p - 6K HID Fogs - Swain Coated Magnaflow headers
Au2bahn is offline   Reply With Quote
Old 05-09-2011, 09:08 AM   #10
e46mook
My Ride: 2004 330cic
this happened to me and ended up being a tire problem..the inner side walls were f'ed Nitto NT555s
e46mook is offline   Reply With Quote
