Old 02-11-2011, 06:47 PM   #1
xxarmoxx
My Ride: 2005 BMW 325i
Mirror Switch not Working
The powered side view mirror switch isn't working on my 2005 325i. I had a mechanic look at it and he said that all the fuses were fine and they thought that the switch needs to be replaced. Does anyone know where I can order that part? I would like to try and fix it myself.
2005 325i 45k miles.
xxarmoxx is offline   Reply With Quote
Old 02-11-2011, 11:43 PM   #2
dephantn
Location: Toronto Canada- Family's EX :745i & X5 - 525i-323i
My Ride: 740iL-325xi
Search online, cost small
dephantn is offline   Reply With Quote
Old 02-12-2011, 12:52 AM   #3
danewilson77
My Ride: 2004 zhp
You need either of the two that I have indicated...depending on your application.
danewilson77 is offline   Reply With Quote
Old 02-12-2011, 01:46 AM   #4
xxarmoxx
#13 is what I need, is there anywhere to order it online?
Old 02-12-2011, 01:50 AM   #5
jetjockey
My Ride: Bus...a big one.
try bimmerspecialist.com They've worked well for me in the past...not sure if they will have that part or not...just search by part number
jetjockey is offline   Reply With Quote
Old 02-12-2011, 01:57 AM   #6
danewilson77
My Ride: 2004 zhp
http://www.ecstuning.com/BMW-E46-330...9058/ES165037/
or this
http://www.ecstuning.com/BMW-E46-330...3691/ES168205/
Old 02-12-2011, 02:11 AM   #7
xxarmoxx
Cool, the bottom link looks like a winner. Any idea on how to install it? How can I pop out the broken switch?
Old 02-12-2011, 09:53 PM   #8
dephantn
use flat screw driver /hard thin plastic pry on top & bottom of switch, pull it out, pull out the wire, insert new one.
Old 02-13-2011, 12:38 AM   #9
xxarmoxx
Sounds easy enough. Do I need to unplug the negative power connection on the battery first?
Old 02-13-2011, 01:41 AM   #10
danewilson77
My Ride: 2004 zhp
I would.
Old 02-13-2011, 01:59 AM   #11
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
I have a spare switch. PM me.
delmarco is offline   Reply With Quote
Old 08-22-2011, 07:14 PM   #12
Spinmaniac
My Ride: 2005 325i
im sure curious to know whether or not this was the actual problem solution. There's so many threads with this issue and no one has ever posted what their final fix was (if they ever did fix it).
Spinmaniac is offline   Reply With Quote
Old 08-23-2011, 02:08 PM   #13
xxarmoxx
I had trouble finding the right part online and the one delmarco had is the wrong part number. I am gonna have my rear brakes changed soon and I'm gonna have that same mechanic order the part for me and install it. I let you know if the new switch fixes the problem or not. I'll maybe take care of it in a few months.
Old 08-23-2011, 02:23 PM   #14
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You hadn't happened to have had that window regulator fixed sometime prior to the switch not working, did you? If so, bet it's just a loose connection.
It can be a pitb if you don't loosen the wires first to install...and if they didn't do that, the connection might have just wiggled out because it was never really in well.
Been there, done that!
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-23-2011, 02:49 PM   #15
xxarmoxx
Not sure, bought the car used like that.
Old 08-23-2011, 03:45 PM   #16
dmax
dmax's Avatar
Lift up switch and see if the connections just beneath seem all the way.
I used hemostats the first time, since there was very little play between switch and the wires.
Easy enough to lift up and push up on the connections if you don't yank it up too hard. If you can't get them in, open up door and feed yourself a little more play in the wires.
Didn't read everything in detail, but you did check its fuse already, right?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 11-22-2012, 07:57 PM   #17
joedaddy
My Ride: OCTA
did anyone actually fix this issue?
i have the same problem right now.
it tilts when i put the car on reverse.. but no action when I am trying to switch the mirror position...
joedaddy is offline   Reply With Quote
Old 01-04-2013, 10:02 PM   #18
slvr325ci2004
My Ride: 2004 325ci
I'm having same issue. Bought the car in Novemeber. Passenger side mirror moves down when I put it in reverse, but can't adjust mirrors with the switch. I like the info and will check it out next weekend. If I'm able to fix it, I will post.
slvr325ci2004 is offline   Reply With Quote
Old 01-04-2013, 10:03 PM   #19
joedaddy
My Ride: OCTA
great.. i have a 2004 coupe also.. please let me know if you figured out how to fix it.. thanks!!!
Old 01-05-2013, 01:00 AM   #20
joedaddy
My Ride: OCTA
hmmm... found this old post:
http://forum.e46fanatics.com/showthr...=871823&page=2
check out the post #30.. it makes sense that the issue could be more of the ribbon (wire) that goes into the mirrors.. one of them must be shorting.. seems like 2003 to 2005 cars have a exposed wire ribbon.. and it was fixed in later models with rubber insulators.
