Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Thread Tools Search this Thread Rating: Thread Rating: 89 votes, 5.00 average.
Old 05-25-2013, 03:19 PM   #3121
viper7180
My Ride: 06' M3
Thanks for the input on my build. For the trigger I was thinking about saving some cash now as that can be changed easily. My primary concern is with the upper. I'll still have to pin and weld any muzzle device per NJ laws. Please bear with my basic knowledge...Would a two piece rail be able to be removed with a "permenant" muzzle device? Is it the barrel nut that won't pass over the muzzle device?
viper7180 is offline   Reply With Quote
Old 05-25-2013, 06:32 PM   #3122
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
I would still advocate buying a 16" middy, as it's going to be more tolerant of varying loads. If you buy a pre-built dedicated upper with everything already attached like the rail and whatnot, a 14.5" setup is a good option if buy from a reputable manufacturer like BCM or Noveske. You're in a unique position where you have to pin/weld the muzzle device anyways, so in that respect, barrel length is sort of a moot point. If you do get a 14.5" setup, make sure to get a standard carbine buffer, not an "H" or "H2". For the 16" middy, you can do either a standard or "H".
Thing is, if you buy at 14.5" setup, BCM will pin/weld that prior to shipping unless you tell them otherwise. The barrel nut generally doesn't fit over the gas block, and the gas block can't be pulled off due to the muzzle device. That's where you get held up. The same with a fixed FSP. Rails will fit over no problem.
The other way to mitigate this issue is to buy a railed handguard that works with the standard mil-spec style barrel nut design. Things like the DD Omega and what not.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 05-27-2013, 05:35 PM   #3123
Adam@Euro-Spec
My Ride: is slowww
Send a message via AIM to Adam@Euro-Spec
oh herro to my new friend...I really like the fortis rail..hopefully ill be able to shoot it soon and it will probably end up wearing a 1-4x scope.
Adam@Euro-Spec is offline   Reply With Quote
Old 05-27-2013, 05:56 PM   #3124
Reedo302
Reedo302's Avatar
With the UBR on the back end and Fortis on the front, does that front end basically feel weightless?
Glock Armorer
Old 05-27-2013, 05:59 PM   #3125
Adam@Euro-Spec
My Ride: is slowww
The pig is like a lead weight on the front end. So it feels pretty good, plus the barrel is a stainless steel match barrel. I actually like the balance it feels really nice in my hands.
Old 06-25-2013, 08:58 AM   #3126
Serbonze
Master of his domain.
My Ride: My wife
Latest build (top):
LMT 10.5" Upper
Noveske Gen 2 N4 Lower
9" VTAC Alpha handguard
Syrac Adjustable Gas Block
BCM Buffer Tube
PSA LPK
AGL ACT Trigger
BAD ASS Safety Selector
BCM BCG
BCM Charging Handle Mod 4
B5 Bravo Stock
Magpul MBUS Gen 2 Front and Rear
Aimpoint Micro H-1 2moa
Daniel Defense Micro Mount
BCM Grip Mod 1
BCM Compensator Mod 0
Novekse QD Endplate
BCM Carbine Buffer Spring
BCM H Buffer
BCM Castle Nut
Cerakoted in Sniper Grey
Serbonze is offline   Reply With Quote
Old 06-25-2013, 09:40 AM   #3127
GasKing
My Ride: 1990 Yugo GVC
The General AR Discussion Thread
Nice
GasKing is offline   Reply With Quote
Old 06-25-2013, 11:13 AM   #3128
Adam@Euro-Spec
My Ride: is slowww
Re: The General AR Discussion Thread
^^ very nice! Well done sir!
Sent from my DROID RAZR using BimmerApp mobile app
Old 06-25-2013, 12:56 PM   #3129
NFRs2000nyc
My Ride: S2000+Wrangler
Just ordered a White Oak 18" Varmint Upper...bad news is it's an 8 month lead time. Anyone have a line on an in-stock complete upper that's a little more bargain basement but still decent quality?
NFRs2000nyc is online now   Reply With Quote
Old 06-25-2013, 01:23 PM   #3130
david05111
My Ride: drei hundert dreißig
Originally Posted by Serbonze View Post
Latest build (top):
LMT 10.5" Upper
BCM Buffer Tube
PSA LPK
AGL ACT Trigger
BCM BCG
B5 Bravo Stock
BCM Grip Mod 1
Novekse QD Endplate
BCM H Buffer
BCM Castle Nut
Still stunned it's not FDE
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
david05111 is offline   Reply With Quote
Old 06-25-2013, 09:42 PM   #3131
Reedo302
Reedo302's Avatar
Nice...very nice.
Glock Armorer
Old 06-26-2013, 07:57 AM   #3132
Serbonze
My Ride: My wife
I loved the Sniper Grey on the Glock, so I had to go that route.
Nice...very nice.
I figured that you would like the H-1.
Old 06-30-2013, 12:31 AM   #3133
Reedo302
Reedo302's Avatar
I just finished TD1 of a 2-day carbine course (and than drank some beer), and just wanted to share that the lone DPMS went Tango Uniform (shocking!!!).
Proof positive once again that if you put garbage in, you get garbage out. At least they're consistent(ly bad).
Glock Armorer
Old 07-08-2013, 11:10 AM   #3134
Serbonze
My Ride: My wife
Any suggestions for a muzzle device that has the same dimensions as an A2 but does not need to be timed?
Old 07-08-2013, 08:42 PM   #3135
Reedo302
Reedo302's Avatar
What kind of muzzle device do you want? Comp? Brake? Flash Hider? And why don't you want it timed?
Glock Armorer
Old 07-08-2013, 08:44 PM   #3136
Serbonze
My Ride: My wife
It's for a dedicated suppressed SBR so it doesn't matter.
I see your edit and I raise you an edit.
Because I'm lazy.
Old 07-09-2013, 12:22 AM   #3137
Reedo302
Reedo302's Avatar
Why not just get a threaded suppressor threaded for 1/2-28?
Glock Armorer
Old 07-09-2013, 12:38 AM   #3138
Adam@Euro-Spec
My Ride: is slowww
He has a halo already I believe that's the one.
Options I think work with your suppressor
Bcm comp
Pws fcs556
Vltor vc-1
Battlecomp 2.0
Old 07-09-2013, 07:35 AM   #3139
Serbonze
My Ride: My wife
Correct, I already have a Halo.
BCM, BC, and PWS all need to be timed. I hadn't thought about the Vltor VC-1, that may be a winner.
Old 07-15-2013, 01:09 AM   #3140
david05111
So, oiling/lubing the buffer/spring/tube. A go or no-go? I've read arguments on both sides.
Rate This Thread
