Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Thread Tools Search this Thread Rating: Thread Rating: 89 votes, 5.00 average.
Old 11-09-2012, 02:30 AM   #1261
king kong
My Ride: mid-engine
Is there any benefit of going with a free float front rail over a drop in or something like that?
king kong is offline   Reply With Quote
Old 11-09-2012, 03:45 AM   #1262
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
Yes, very much so.
Drop-in rails trasmit heat faster and will get hotter than free float rails. Additionally, and ever more importantly, drop in rails allow you to deviate your barrel and change your point of impact (POI). If you pull or push on a drop-in handguard, you are applying pressure to the barrel and can cause it to bend ever so slightly under pressure. This won't make any difference at 25yds, but at longer ranges like 100yds and beyond, you can start to see a variation between intended POI and actual POI. Also, running a sling attached to the front sight post or rail is a NO-GO as well, as it can cause even more barrel deviation. The best is to run a free float rail, and use a sling attachment option or device on the rail for the front sling attachment on a 2-point sling (if that's what you choose to run).
Also, drop-in rails do not have RTZ (return to zero) capability. If you have a laser module or any type of aiming device on the rail, it won't be zeroed if you take the rail off. Also, it won't hold zero because drop-in rails are generally not very secure and can rattle, rotate and move around.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 11-09-2012, 11:31 AM   #1263
king kong
My Ride: mid-engine
Free float it is. Do you have any reccomendations <200?
Sent from my SAMSUNG-SGH-I777 using Bimmer App
Old 11-09-2012, 11:38 AM   #1264
Sentaruu
My Ride: Xterra
it really depends on what you are looking for but check out some of TROY's or Daniel Defense's rail systems.
Sentaruu is offline   Reply With Quote
Old 11-09-2012, 02:48 PM   #1265
Reedo302
Reedo302's Avatar
For inexpensive options that are high quality, I really can't think of a better option than Troy Industries. For under $200, they're the only brand that I would ever use.
I personally prefer Daniel Defense, and I know that LaRue, KAC, Centurion, PRI and several others are all excellent quality. They're all a lot more expensive, though. Troy makes a great real that's more in your price range.
http://troyind.com/rail-systemsacces.../ar15m16-rails
Glock Armorer
Old 11-09-2012, 04:26 PM   #1266
HiHoBrian
My Ride: 05 M3
Just got this in the mail today. Daniel Defense Lite 14. I can't wait to install it.
Edit: but I can't put it on yet because I'm still looking for a 16" complete flat top upper with low profile gb for it. Preferably Daniel Defence. I have an offer on one on ar15 com but seller is very slow to reply. If you have a lead on something let me know. Click image for larger version
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 11-09-2012, 05:03 PM   #1267
king kong
My Ride: mid-engine
I see the dd omega's are only about $70 more. What are the benefits I'd see for the extra 70?
Old 11-09-2012, 05:15 PM   #1268
king kong
My Ride: mid-engine
Correction, it's $40 more. I guess I should go with the dd.
Old 11-09-2012, 05:19 PM   #1269
Adam@Euro-Spec
My Ride: is slowww
Send a message via AIM to Adam@Euro-Spec
Somebody can probably explain better then me, but the Daniel defense rails are extremely strong and you get amazing customer service in dd. google Daniel defense torture test and watch that video. The fit and finish will be great. I have a ris ii rail and love it.
My next rail is most likely going to be a Gisselle smr mkii and then either another ris ii or a noveske nsr
Adam@Euro-Spec is offline   Reply With Quote
Old 11-09-2012, 05:20 PM   #1270
Chris-TK
My Ride: Mk VI GTI
DD Rails fit great, super strong and are lightweight.
K.
Chris-TK is offline   Reply With Quote
Old 11-09-2012, 05:48 PM   #1271
king kong
My Ride: mid-engine
Orderded my omega. $260 shipped
Old 11-09-2012, 05:51 PM   #1272
Sentaruu
My Ride: Xterra
i have a DD rail on one of my rifles and it is one of the most solid, lightweight and good looking rails i have personally handled
sometimes it is worth spending the extra coin and having something quality and durable that will last you
Old 11-09-2012, 06:58 PM   #1273
Reedo302
Reedo302's Avatar
Troys are good rails, but DD is just a little bit better. DD rails are very strong and rigid, both due to overall rail design, as well as the mounting attachments.
It's been my observation that Troy AR rails are essentially minimalist free float rail tubes with rails attached. Simple designs and simple attachments. Not a bad rail at all for a training or range gun.
In contrast, every Daniel Defense rail is designed from the ground-up to be a purpose-built rail system. They have different rail designs for different applications or shooters. Their rails are built as rails, and you can see the thought they put into each rail system they build. When I read about the development that went into the RIS II and LITE rails, for instance, I was very impressed because they designed them to work with the human hand and human body mechanics. Kind of neat stuff if you're a nerd like me.
The Omega rails are nice, and they're very easy to install. I think you'll be pretty happy with it.
Glock Armorer
Old 11-09-2012, 08:09 PM   #1274
04_e46
My Ride: 2004 325ci
Almost finished with my ar pistol build, and it so happens to be DD(upper). The rifle next to it is also DD, the same model as shown on the DD torture test. You made a good choice going with the omega rail King Kong.
04_e46 is offline   Reply With Quote
Old 11-09-2012, 09:16 PM   #1275
david05111
My Ride: drei hundert dreißig
Originally Posted by Adam@Euro-Spec View Post
You buying an AR soon? if so what color do you like
Tan, black or green?
Adam...uhascrabs??? just found your post on arfcom and didn't know your sn
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
Follow me on Instagram: yippee_ki_dave
david05111 is offline   Reply With Quote
Old 11-09-2012, 09:17 PM   #1276
Adam@Euro-Spec
My Ride: is slowww
Sbr ran perfect today, with blue spring and h2 buffer. Except my tango down arc mag is a piece of crap, would not feed at all. Steel mag and pmags worked perfectly.
Old 11-09-2012, 09:18 PM   #1277
Adam@Euro-Spec
My Ride: is slowww
I sell crabs for a living
Old 11-09-2012, 09:21 PM   #1278
david05111
sure...
Old 11-09-2012, 09:24 PM   #1279
Adam@Euro-Spec
My Ride: is slowww
sure...
http://www.bluepoint2go.com
Old 11-09-2012, 11:08 PM   #1280
Reedo302
Reedo302's Avatar
All of my ARC mags have been very reliable, but I can't get them to seat on a closed bolt unless I download to 27rds. Pretty stupid. I don't run them anymore and they've been relegated to my spare mag box in the back of the closet in the Man Cave.
Glock Armorer
Rate This Thread
