Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum. |
Thread Tools | Search this Thread | Rate Thread |
#1341 | |
#1342 |
Master of his domain.
That's why I picked up the X300. Check out that one if you get a chance.
#1343 |
I was worried about not liking it mounted and it being to big, but it feels great and is extremely easy to manipulate. The only downside is it's very hard to press the button to flip my Troy buis down
Sent from my DROID RAZR using Bimmer App |
#1344 |
I had that same issue when I was trying to use my G2. It's the mount. Wherever you attach it, there is a clearance issue.
#1345 |
Time to clean my ARs.
http://www.eyehandy.com/sports/how-t...e-with-ashley/
#1346 |
now that you mention it, my ARs are pretty filthy too...
#1347 |
Location: Tampa/Daytona/J-Ville, FL; New York, New York
My Ride: drei hundert dreißig
Outstanding video, all around
"You'll Never Walk Alone" |
#1348 |
ASA NO MO
Do you really need to break in a new AR?
#1349 |
Yes and no. Calling it a "break in" is not quite accurate IMO. It's more of a case of "priming the pump" and a "shake down".
Giving it a shake down is basically shooting it to make sure everything works. Then, after shooting it, you take it apart and make sure it held up okay without any issues or mechanical problems. Priming the pump is initially shooting it for the purpose of distributing and absorbing lubrication. Most ARs don't have enough lube in them off the shelf to function correctly, and I've actually watched people shoot a new Colt AR and the thing was having failures to feed galore. I could hear the bolt scraping like fingernails on a chalkboard everytime they manually cycled it. When you initially shooting a new gun, over-lube the thing. Shoot it to get it nice and hot so that the metal pores will open up and absorb some of the lubricant. Lube will spread all over and it'll run like a Swiss watch. If you've ever watched one of the videos of how to apply Frog Lube, they talk about the need to heat up the metal part before applying the lube. This is another variation to my "priming the pump" analogy. I guess you could call that a "break in" if you wanted to, but you're not really needing to loosen any springs up. It's more of an issue of just making sure everything is lubed and working correctly.
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer Gunfighter Training YouTube Channel FS: Dunlop Graspic DS-2 185/65R15 winter tires/wheels off Honda Civic - $250/OBO Last edited by Reedo302; 11-17-2012 at 09:33 PM. |
#1350 | |
ASA NO MO
BTW mine appears to be well lubricated as I can see some areas have excess on it. The first time I picked it up I had to whipe my hands. |
#1351 |
ASA NO MO
Is this magpul decent for my colt 6920?
http://www.ebay.com/itm/Magpul-Black...item2ec2fe2f9d |
#1352 | |
#1353 |
ASA NO MO
#1354 |
What do you want. I'm not a huge fan of the moe stock and would recommend the vltor imod or magpul str but this and everything is person preference. For a grip I'd look at the bcm gunfighter grip. Trigger guard I like the magpul enhanced. The rail is up to you, for the money the magpul rail is a great price, but if you want a free float quad rail it's going to cost a lot more $$.
#1355 | |
About Magpul; I like alot of their stuff. In fact, their grips and trigger guards have accessorized my rifles for a while. But they make several "levels" of accessories and quality with different features. "MOE" is their lower end and stands for Magpul Original Equipment. They're short on some features that their higher end stuff has, as well as other manufacturers. For instance, their MOE and CTR stocks look the same, but they have different lock-up features and I think some other minor tweaks. The lockup helps it stay on the gun without "wobble.". The improvements are slight, but there are a few of them. That being said, I think there are better options for each accessory. That's a nice hodgepodge of all of them in one purchase, but individual pieces will give you a better result in the end IMO. Stocks: Magpul, LMT, VLTOR. Those are basically the big three and for carbine stocks they range in price from like $60 to more than $200. You just have to decide what's important. The LMT SOPMOD is loved by most everyone who uses one, but they're expensive. Every one of my rifles has a VLTOR on it; they're incredibly good IMO and run around $100 depending on the model. Grips: Magoul and BCM are the standards at the moment. BCM is getting rave reviews and loads of people that have long used one of the 3 Magpul grips are switching to the BCM. Trigger guards are all the same for me...someone else can come up with an answer to that if they want, but I've been happy with my MOE trigger guards. Handguards/rails: if you just want a hand guard, have at the Magpul. It's a good piece of kit I think. But, odds are you'll want a quad rail up front at some point so you should start looking at that option. A quality rail like daniel defense, Troy, etc. Will run you $250-300 I think. Depending on what you decide to do, you can get away with a hand guard or rail anywhere between $40 and $350.
"You'll Never Walk Alone" Last edited by david05111; 11-17-2012 at 11:53 PM. |
#1356 |
Never buy any gun stuff off of eBay. Half the gun stuff on there is Chinese knock-off stuff being passed off as legit OEM.
The MOE equipment is good kit, but it has limitations. The MOE equipment is designed to work with Magpul accessories only, which is sort of annoying, depending on how you look at it. The handguard for example, does not have rails and you need to buy Magpul mounts and accessories for it in order to mount a light or a vertical foregrip. They have small rail sections as an option, but they're very basic. Some companies have made stuff to fit MOE kit, but not many. The stock and grip are generally fine, supposing that they fit your hand. Keep in mind that the MOE grip generally only fits people with larger hands. You need the MOE-K grip if you have smaller hands. I would also steer your towards the BCM Gunfighter grips, as they are ergonomically better and have a better compartment in the grip. The stock is good, but if you get a MOE stock, invest in an aftermarket accessory sling swivel mount by IWC. Impact Weapons Components (IWC) is the only company that I'm aware of making MOE-specific accessories. Compare that to a CTR or STR stock, which have everything built in. Or, with the forearm, look at something bit more utilitarian with full rails. Getting picatinny rails will make your life a lot easier when searching for accessories to mount on the rifle, like grips and lights and such. A good rail to start with and consider is the Daniel Defense Omega 7.0 rail. It's going to cost a little bit more, but you'll find that the added cost will pay dividends later when trying to attach accessories. Also, it's a lot more durable than a plastic handguard, and it's free-floating for better accuracy and less heat transfer to the grip. I understand that money is always an issue, and I'd rather have MOE handguards over stock M4 style ones, and I'd rather have a MOE grip and stock over the corresponding M4 components. It's basic stuff though, and I can guarantee that it'll only be a matter of time before you start looking at replacing stuff like the handguard with a proper railed handguard. Partly out of necessity for accessories, and partly out of just wanting something more HSLD.
Glock Armorer Gunfighter Training YouTube Channel FS: Dunlop Graspic DS-2 185/65R15 winter tires/wheels off Honda Civic - $250/OBO |
#1357 |
if you plan on adding a VFG i wouldnt go with the MOE handguard. i have one on one of my rifles with their MOE VFG and there is a little bit of slop in it. its just the nature of the drop in handguard system. if you dont plan on running a VFG, then the moe handguard would work well. it is very comfortable to shoot, it just tends to get very hot after about 90 rds.
#1358 | ||||
ASA NO MO
If I can get started with a decent kit for about 200.00 that would be great (I have smaller hands). I can add the optics, flashlight, and forward hand grip later one. Thanks for you guys rock and I will definately not buy from ebay Last edited by Nt_loader; 11-18-2012 at 10:40 AM. |
#1359 | |
![]() Last edited by M3_POWER; 11-18-2012 at 10:40 AM. |
#1360 | |
I guess my thought is to take some time to figure out what you may not like, or what changes will improve the feel of the AR or your shooting ability. If you can shoot someone else's at the range, or borrow parts and spend some time with them and then make a decision that's even better! I wish that I had done this when I first started. I would have saved a lot of time and money! You may be influenced by a bunch of us posting in this thread about different components that we are adding, but most of the time those changes are only made after thousands of rounds, many hours on the trigger, and much research from others doing the same thing. If I had to prioritize: Optic Light Sling Replacement Handguard (quad rail or tube, your choice) Then I would look at a replacement stock, maybe a vertical grip, etc.
| Rate This Thread | |
