Old 02-13-2011, 07:48 AM   #1
astonmartini03
My Ride: 2005 330Ci ZHP
Clutch PEDAL vibration
Hi all, I've been wondering why my clutch pedal vibrates for a couple months now, and when it felt the worse today than ever before, I got down under the wheel and figured out that the pedal itself has a decent amount of play in it. It will move in all directions about 1/4" and when I first got the car about 3 months ago, there was absolutely no vibration at all (and therefore, probably no play).
I read a few posts where people started replacing all kinds of complicated parts in their transmission, but has anyone with this problem actually inspected the pedal, associated bolts, bush bearings, and the supporting bracket with the pedal 'axle', or pin that the pedal rotates on?
I found the diagram on realoem.com and am hoping that the bracket or bearings are bad, but nothing else.
Shifting seems fine. There is no slipping or other unusual symptoms.
My shift knob vibrates too, but I probably need to replace the transmission mounts by now. It's a 2005 330Ci 6sp with 45k miles.
astonmartini03 is offline   Reply With Quote
Old 02-14-2011, 02:08 AM   #2
astonmartini03
Nobody's had an annoying pedal like this??
Old 02-14-2011, 02:36 AM   #3
deadpass
My Ride: 01 330i
If i push my clutch pedal all the way in as far as it will go I will feel a pulsing in the pedal, as soon as I back off a bit but well before the friction point it goes away. Do you only notice this when you push it all the way down?
deadpass is offline   Reply With Quote
Old 02-14-2011, 02:59 AM   #4
SweTurbo
Big Pimpin'
My Ride: 323i -98
I have some vibration in the pedal aswell , i believe this is due to the clutch hasn't been really broken in yet.
As for an old clutch the vibration can come from a warped flywheel/pressure plate or a broken friction plate.
The bushing i would replace first , it's a PITA bushing to do with the brake/clutch sensor.
http://www.uucmotorwerks.com/html_pr..._arm_bushings/
I can't find it in their webshop though , you should hurry up if you're gonna order one as their 15% off ends today iirc.
I can vouch for the bushing , i installed mine about 18 months ago and it still is dead on.
Old 02-14-2011, 05:30 AM   #5
astonmartini03
Thanks for the website. But why are they $20??? realOEM.com lists them as $1.52 a piece.
My clutch pedal is broken it - it has 45k mi.
Are there any other components down there that should be replaced while I'm at it?
Sorry, my first description was really bad. I feel the vibration mostly when I just rest my foot on the pedal, like right before I'm about to shift. I suspect the bushings and bearings because once the pedal is pushed in, it doesn't really vibrate. I'm guessing this is because when the pedal is pushed in, it's seated firmly in one position with a lot of pressure from my foot, as opposed to resting there and having the opportunity to vibrate. I don't have any tranny problems as far as I can tell and the pedal doesn't really have any vibrations when I depress it and shift.
Old 10-23-2013, 06:55 PM   #6
AutoHaus24
My Ride: 2004 330CIC
[QUOTE=astonmartini03;12806787]Thanks for the website. But why are they $20??? realOEM.com lists them as $1.52 a piece.
Sorry, my first description was really bad. I feel the vibration mostly when I just rest my foot on the pedal, like right before I'm about to shift. I suspect the bushings and bearings because once the pedal is pushed in, it doesn't really vibrate. I'm guessing this is because when the pedal is pushed in, it's seated firmly in one position with a lot of pressure from my foot, as opposed to resting there and having the opportunity to vibrate. I don't have any tranny problems as far as I can tell and the pedal doesn't really have any vibrations when I depress it and shift.[/QUOTE
My clutch pedal has VERY similar symptoms. I money shifted last march. Flywheel, clutch kit the works were replaced by an indie shop here in chicago. Freaking out. Taking it back to them in the morning to have them take a peek. I've only put on less than 4k miles since my terrible mistake. What was the end result with yours?
AutoHaus24 is offline   Reply With Quote
