Closed Thread
Old 02-16-2011, 03:29 PM   #21
sprintman
My Ride: Ex 325CI owner
Ol is a basestock and additive package. Oil basestock type is split into
Group I, Group II, Group II+, Group III, Group IV, Group V. Use RX with anything up to Group III, not IV and V.
sprintman is offline
Old 02-16-2011, 04:34 PM   #22
shortyb
My Ride: Has blue lights
Originally Posted by danewilson77 View Post
Do I think it will cause damage if you do use it for a short period of time? No. How long does Auto-Rx take to work? A long time. Quite a cunundrum isn't it?
That why it's broken down in phases, ie; clean and rinse. In a larger sump like our cars, you can go as far as 5K on either phase. ANY current crop of group III oil (sprintman makes a good recommendation with a 5W-40) will easily go 5K without, putting it like our favorite forum "expert" would say, blowing up your engine. I will throw in my .02 and say go with any non-syn HD diesel oil. If you're concerned about lots of stuff in there, run another clean/rinse cycle (which is recommended for engines over 100K anyway).
shortyb is offline
Old 02-16-2011, 09:03 PM   #23
sprintman
I ran my last lot of RX about 12,000kms from memory. 10,000kms/6,000 miles this time. My shop says it's the best running E46 they see period. RX is my little secret!
Old 02-16-2011, 11:43 PM   #24
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Ive been using M1 0W40 every 7500 miles.
http://img232.imageshack.us/g/dsc02119o.jpg/
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline
Old 02-17-2011, 04:08 AM   #25
sprintman
mine had M1 0W40 every 5,000 miles/8,000kms. RX made it much much better. Rejuvenates seals too (think VANOS)
Old 02-18-2011, 03:02 AM   #26
VECTOR
My Ride: 2004 330CI auto vert
Question
So you are using RX with the Mobil1 0W40 ?
VECTOR is offline
Old 02-18-2011, 03:56 AM   #27
faceface
Banned
My Ride: e46
Originally Posted by antonmn View Post
Well, I don't think the crap in the filter was life or death... here's a pic:
https://picasaweb.google.com/lh/phot...eat=directlink
I just wouldn't leave it in for 2500 miles like I did.
looks cool
faceface is offline
Old 02-18-2011, 04:36 AM   #28
sprintman
Best not to use M1 0W40 with RX as it has ester content. I use Shell Helix Ultra 5W40, a Group III basestock oil with no ester or PAO content.
Old 02-18-2011, 09:11 AM   #29
Drewfus2101
My Ride: N/A
Nothing can rejuvinate rubber/plastic/whatever seals after they have been run down over thousands of miles.
Drewfus2101 is offline
Old 02-18-2011, 09:13 AM   #30
Drewfus2101
My Ride: N/A
Last year I ran with 2/3 of a can of SeaFoam (basically a solvent) in the the crankcase for about 2500 miles. It really loaded up the oil filter with flaky crap, and caused the filter pleats to distort, as though they were under a lot of backpressure.
Long story short, it loosened a lot of garbage and sent it to the filter, which is what we want. But I'd probably only run it for maybe a thousand miles at a time. Maybe do that a few cycles with a cheaper dino oil.
I use SeaFoam as well. I usually dump in about 1/2 a can and then drive about 50 to 100 miles, then pull right up on the ramps for an oil change. Then change the oil while it is still smoking hot, so that it is still real thin. Also using M1 0W-40.
Just changed my valve cover, not a DROP of sludge.
I agree that 2500 miles is too long.
Old 02-18-2011, 12:19 PM   #31
hummer
My Ride: 2001 330CI
Did I miss it? What oil are you using? I had the mayo anound my cap with M1. But, after swithching to Castrol Syntec, it's gone!
hummer is offline
Old 02-18-2011, 05:19 PM   #32
sprintman
Drewfus2101 you are wrong about seals. How about posting your data to prove your theory?
Old 06-04-2011, 04:45 PM   #33
jkahng
My Ride: 02 330ci 5spd zsp
Hello Sprintman, everyone,
Class of 2011 reporting in...
Bought an 02 330ci zsp 116k miles on it abt 2 months ago.
The it was dealer maintained by a mature previous owner. But he only fixed stuff that broke. (power seat motor, windshield, door seals etc..)
No preventative maintenance done to it.
I can deal with other things that need to be done to it, but it took 1 quart after 700miles!!!
(CCV is clean, no leaks in the valve cover or oil pan. I do get a puff of white smoke on cold start but very little)
Not knowing this as the previous owner neglected to mention it... I've done other obvious stuff such as; 2 front tires, alignment, diff and tranny fluids w/ auto rx.
Now i just started the engine oil. I have castrol gtx 10w-40 dino w/ 2 bottles of auto-rx in the sump.
Sprintman,
can you tell us what the "results" of your treatment/flush cycle did for you?
i will update my findings soon (doing a x country trip tomorrow NJ=>CA)
jkahng is offline
Old 06-04-2011, 05:56 PM   #34
Guest021715
Account closed.
tsk tsk tsk. I bet the oil you took out of there was thicker then gear oil. You shouldn't have driven it more then 100-200 miles tops with seafoam, you were just asking for trouble.
Originally Posted by OrientBlau View Post
Ive heard Sea Foam is all placebo.
Sorry to say, you've heard wrong. All that smoke produced with seafoam is cleared carbon build-up. It stabilizes idle, cleans the injectors, and it has personally given me improved gas mileage.
Guest021715 is offline
Old 06-04-2011, 07:49 PM   #35
WheyArea
My Ride: '03 TiAg ///M3
It was on the internal engine metal I could reach with my finger, not the cap itself. It came off like a paste more than a lite film of oil. I cannot say it looked like mayo, but lets assume for the moment it is. What do you guys use(if anything) to loosen or break it down right before an oil change?
What is there to worry about as you put it if it is more like mayo, and what is typically done to get rid of it?
This sounds pretty normal for the top of the engine cover. Years of build-up will cause that thick muddy grease. Most synthetics actually contain detergents to keep sludge from building up. You can either:
- change your oil more often
- use something like Auto-RX (don't think it's that drastic, but wouldn't hurt)
I suggest opening the valve cover and check to see if it's the entire engine or just the inside of the cover.
/// Dinan ECU /// Brembo BBK /// BBS LM 19" /// Bilstein PSS10
/// Eisenmann Exhaust /// Supersprint Mid Pip /// AC Schnitzer Spoiler
/// Hamann Lip /// AC Schnitzer CF Diffuser /// K&N CAI /// Valentine 1
Coming Soon...... OEM SSK, CSL bootlid
WheyArea is offline
Old 06-04-2011, 08:55 PM   #36
sprintman
Sprintman,
VANOS seals rejuvenated, compression up, smooth as silk, zero oil consumption now. Run it at leat 5,000 miles and if you add oil add some RX too.
Old 06-04-2011, 10:15 PM   #37
Guest021715
Account closed.
How long have you been running it with AutoRX? I've heard pretty good things but if I'm remembering right its teflon based, and that tends to be a temporary fix.
Old 06-04-2011, 11:38 PM   #38
jkahng
Thanks for the info!!
Very nice to hear that auto rx works on the M54.
I had a pretty severe vcg leak on my maxima that auto rx cured... My auto tranny became silky smooth as well.
The only thing is....
I'm using US spec Castrox GTX 10W-40. Where as the euro spec Castrol GTX 10w-40 dino IS good for A3/B3, US spec is not.
I couldn't get my hands on PP 5w-30 which is group III
I'm not sure I want to leave it in so long.
I'll be changing the oil filter at abt 1,200miles into the treatment and changing the oil at abt 3200miles I don't want to harm the engine.
I'll just do another treatment if i'm not satisfied....
Again, Thanks for the info.
jkahng is offline
Old 06-04-2011, 11:43 PM   #39
jkahng
Auto RX is a cleaner. It was developed for cleaning printing presses and invented by mistake.
I will slowly dissolve sludge over a 6000mile treatment/rinse cycle.
I don't think there's any teflon in it at all.
There's a religious following on bob's the oil guy forum. I would use it on any car that doesn't require synthetic oils but I had to do some research before I did it on my 330ci.
jkahng is offline
Old 06-05-2011, 12:02 AM   #40
Guest021715
Account closed.
You're right, I must have been thinking of another product.
During the treatment, they say you're supposed to run your car with conventional oil, and attribute oil burn to leaky seals stiffened by synthetic oil. I'm not sure if I believe their information about synth-oils, however I have seen the product work successfully. Guy had an older Honda with ~250k miles, and was burning a quart of oil every 800 miles. After the treatment, which took quite a while, it eventually stopped or slowed to the point where the burn was no longer noticeable.
So +1 for AutoRx. Not sure how many people on this forum would be brave enough to use it as our BMWs call for synthetic.
Closed Thread
