Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 12-04-2010, 08:05 PM   #1
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Axles, driveshaft, ect.
The last time I hit the drag strip, I think I broke some things in my driveline... Everything was fine for a while afterwords, but slowly things got worse. At first, while making sharp 90 degree turns at intersections and putting the car under a little bit of load, it would feel as if only one wheel was being powered.
I knew something was up, but being the type of person that I am, I kept pushing the car hard.
I went to Mexico and the car was ALL over the place; I wasn't able to get any traction. Again it felt as if only one wheel was being powered.
The next night I went out and tried to do some 60-130 times, even though I knew something was up in the driveline. The car was SCARY, only one wheel was getting power and the car wanted to go sideways. On my way home, I hit a very small pothole and felt something break in the driveline and started to hear a rotating screeching sound.
I parked the car and haven't had a chance to really dig into it and find and fix the issue until this weekend.
Here is the first thing that I found, a shredded center support bearing:
Didn't have the correct hex's to remove the axles, will get to them tomorrow, but the passenger side axle definitely has a lot of play on it. I suspect that it is done for which makes sense since the passenger side tire looks practically brand new, while the driver side tire is nearly bald.
I am pretty sure I am going with the DDS axles and driveshaft
MSpired is offline   Reply With Quote
Old 12-04-2010, 08:11 PM   #2
bluejeansonfire
ninja editor
My Ride: shaken, not stirred
Send a message via AIM to bluejeansonfire
DSS?
sweet!
why doing the driveshaft?
hex?
i think axles are e10 or 12... and well, 36mm 6 or 12point (depepending on the nut you got)
2001 330ci TT turbo
e46nonm.com | TechniqueTuning.com | Precision-Sport.com
bluejeansonfire is offline   Reply With Quote
Old 12-04-2010, 08:18 PM   #3
MSpired
Originally Posted by bluejeansonfire View Post
DSS?
sweet!
hex?
DDS=DriveShaftShop
Why? Because:
A) Once I beef up the axles and get new beefier tires, the next weak link would probably be the driveshaft
B) I feel that the center support bearing will fail again, and I believe (I have to call DDS to make sure) the DDS driveshaft is a one piece unit and doesn't use CSB
C) Might as well do it when I have everything apart
Old 12-04-2010, 08:29 PM   #4
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Good idea.
Might seem like overkill to some, but we're talking about nearly triple OEM torque through the drivetrain.
Old 12-04-2010, 08:38 PM   #5
Forcefed M3
My Ride: HPF Stage 2.75
I kept my axles the weak link in my supra it was cheaper than a tranny
Forcefed M3 is offline   Reply With Quote
Old 12-04-2010, 08:55 PM   #6
bluejeansonfire
ninja editor
Why? Because:
Other than Taza, no one has ever done driveshaft damage in an e46, afaik. And that was a carbon shaft. However, I theorize that the damage he incurred was due to a broken front diff bolt, then tried to launch on crazy bias-ply drag tires. mtran also broke his diff bolt. But his car never did anything but clunk. I think he didn't do damage like Taza due to general lack of grip.
You may very well be right, at the power level you're pushing, the driveshaft is a logical part to become next in line to fail. But I think that before the driveshaft, the diff-mounting is a greater concern. There isn't an aftermarket addressing of the situation for the e46. However, AA makes a great brace for the e36, though I've read that sometimes with that part, the bolt still breaks, just less.
My theories on bearing failure:
a) old and needed replacement
b) rode with a old guibo for too long
c) driveshaft out of balance from impact
d) worn/damaged u-joint causing vibration
I could be wrong, but I really see no evidence that output kills these
but if it's c or d, it warrants a driveshaftshop piece.. do you have any ideas on this?
But, if you're interested, I know where to balance/rebuild the driveshaft or get a warrantied one for 1/3 price of the aftermarket piece
DDS=DriveShaftShop
hmm
2001 330ci TT turbo
Old 12-04-2010, 09:03 PM   #7
yellowssm
My Ride: 2005 M3
Does your rotating screeching sound sound like a supercharger whine? And it only does it in get under boost? This might be my problem. Let me know
yellowssm is offline   Reply With Quote
Old 12-04-2010, 09:05 PM   #8
faelar
Big Pimpin'
My Ride: M3
With the power the HPF kits are putting down I figured the OEM drivetrain wouldn't hold up.
My driveshaft and axles were sent to DSS by HPF. The driveshaft is a one piece chromoly and the axles are treated and rated up to 1,000 HP. The weak link now will be the transmission and Diff mounting. I'm going to have a shop local to me custom fabricate a "torque arm" for the rear diff.
Billet PT6765, ProEFI, SAAD Racing, 805 WHP 692 WTQ
Originally Posted by Saad@SaadRacing View Post
Chad's car is being taken care of and I can tell you when it comes back he and his car will be your worst f***ing nightmare.
faelar is offline   Reply With Quote
Old 12-04-2010, 09:10 PM   #9
Forcefed M3
Mine has held up under 80,000 miles of Hpf abuse so far.
Old 12-04-2010, 09:13 PM   #10
bluejeansonfire
ninja editor
I think he's talking about the noise of the collapsed dirveshaft not being supported by the bearing
2001 330ci TT turbo
Old 12-04-2010, 10:10 PM   #11
MSpired
Other than Taza, no one has ever done driveshaft damage in an e46, afaik. And that was a carbon shaft. However, I theorize that the damage he incurred was due to a broken front diff bolt, then tried to launch on crazy 295 bias-ply drag tires. mtran also broke his diff bolt. But his car never did anything but clunk. I think he didn't do damage like Taza due to general lack of grip.
hmm
I agree with you, there isn't much evidence that the OEM driveshaft can't handle the power, and the CSB could have been on it's way out already, especially since I have beat on my car since I bought it new.
But, I do think that hard launches, which cause a lot of flex in the driveline might have caused the CSB to fail and I can see it happening it again if I want to continue driving the way I do... I'd rather just fix it right, right now, rather than have to worry about it breaking again.
Old 12-04-2010, 10:12 PM   #12
MSpired
Very interested in the torque arm, keep me updated as I might be interested in having your shop just make me one at the same time.
Old 12-04-2010, 11:19 PM   #13
faelar
Big Pimpin'
My Ride: M3
Then your not launching the car hard enough
IF you ain't breaking stuff you ain't driving it hard enough.
Old 12-04-2010, 11:20 PM   #14
faelar
Big Pimpin'
My Ride: M3
Will do.
Old 12-04-2010, 11:40 PM   #15
Forcefed M3
Haha
Old 12-04-2010, 11:47 PM   #16
bluejeansonfire
ninja editor
did you take it apart for fun or did you break it? I don't see any obviously damaged parts
2001 330ci TT turbo
Old 12-04-2010, 11:55 PM   #17
bluejeansonfire
ninja editor
Considering the reports on bf.c regarding driveshaftshop driveshafts, I would try to stick to the stock part. I mean, unless you replace the guibo for a solid piece, you'll still need to replace it, I think wear items on the driveshaft aren't a big deal anymore (I can't account for the number of guibos i have gone through, i can do a range, 15-20). The csb is a cheap and easy part to replace. To replace it, just remove guibo, drop csb, one bolt! I don't think anyone has complained about the halfshafts. The driveshafts are known to wobble wildly, even when rebalanced several times over.
2001 330ci TT turbo
Old 12-05-2010, 12:00 AM   #18
MSpired
Any links about what you are referring to?
Easy if you have a lift... I hate working on the ground
Old 12-05-2010, 12:05 AM   #19
bluejeansonfire
ninja editor
http://forums.bimmerforums.com/forum...&highlight=dss
2001 330ci TT turbo
Old 12-05-2010, 01:15 AM   #20
MaverickM3
My Ride: gets Badge
Same here Faelar
Photobucket Pictures, Images and Photos
MaverickM3 is offline   Reply With Quote
