Old 02-15-2011, 12:40 PM   #1
jahansg
My Ride: BMW 330ci
Smile Need Help with negative camber
Hi,
I had an accident, and my strut and tire came off the car. I got a new aftermarket control and I replaced it. I put back the strut, it was in working condition. The car runs fine however it pulls to the right a bit. I notice there is negative camber on the passenger side where I had the accident.
I understand that a bent strut or shock tower could be the reason for negative camber. But how can I find out which is the case and what are possible solution.
And if there is problem with shock tower, can I use adjustable camber plate such as tuner motorsports adjustable camber plate to correct the problem.
I appreciate taking the time and helping me out.
Jahan
jahansg is offline   Reply With Quote
Old 02-15-2011, 02:50 PM   #2
DangerousMind
My Ride: Sierra 1500 SLT
I would take it to an alignment shop and get them to assess it. There is a pin in the upper strut mount that can be punched out to provide more camber adjustment.
DangerousMind is offline   Reply With Quote
Old 02-15-2011, 02:55 PM   #3
jahansg
My Ride: BMW 330ci
Could you tell me a little more about this Pin. I have 2004 330 ci.
Old 02-15-2011, 03:08 PM   #4
OrientBlau
My Ride: 2003 330i
Your strut tower should have a rounded off blunt pin protruding from it. The pin is part of the strut mount itself.
This pin is drilled out to provide more adjustment range.
EDIT:
Photo - the pin which appears to be marked in green below:
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 02-15-2011, 03:09 PM   #5
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
If you look at your strut tower you'll see it there. It's a little silver "dimple" that sticks through from the shock mount into the metal of the shock tower.
Sorry probably not describing it well, but it's pretty easy to spot
Drew@Swift Motorworks is offline   Reply With Quote
Old 02-17-2011, 03:34 PM   #6
MitchSF
My Ride: 11 M3 DCT
I just returned from the alignment shop. My right front is at -1.1, slightly out of range. If we drill out the pin, do we also have to enlarge the three bolt holes to give enough room to adjust the camber?
MitchSF is offline   Reply With Quote
Old 02-17-2011, 03:37 PM   #7
My Ride: Lexus
The holes are elongated from the factory--no modification necessary.
Old 02-17-2011, 03:59 PM   #8
MitchSF
My Ride: 11 M3 DCT
Great, thanks!
camber, control arm, negative camber, strut
