E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 02-15-2011, 05:33 PM   #1
Kubica
My Ride: 2003 325xi
Xi Front Wheel Bearing
Since all the xi threads today seem pointless . . . .
Who has replaced a front wheel bearing without taking the knuckle off the car?
I did the right front bearing last winter by removing the whole knuckle and pressing it out. I'd like to do the left side without taking the knuckle off, since i just had a very expensive alignment done.
I know the B90 bearing toolkit should be able to get the job done- who has done it?
Old 02-15-2011, 08:25 PM   #2
Kubica
My Ride: 2003 325xi
OK looks like I forgot about this thread in the DIY section:
http://forum.e46fanatics.com/showthr...+wheel+bearing
Old 10-07-2011, 04:27 PM   #3
Ivanhoe
My Ride: BMW 330 xi 2005
Question, to replace the rear wheel bearing its the same that on the front ?
Ivanhoe is offline   Reply With Quote
Old 10-07-2011, 04:57 PM   #4
Kubica
My Ride: 2003 325xi
^no. Same as rwd though.
Old 10-07-2011, 11:06 PM   #5
markusvt
My Ride: 330xi
There is a reason shops DON'T do it this way. Good luck with step 11, it's a lot of fun. If your ABS sensor is rusted in, and you use any heat to get the bearing out, 100% chance of ruining it, and it's not easily available aftermarket, and OEM is expensive. All the beating you will give it trying to do it in the car, you want to get it aligned anyway. Don't miss step 24, or you will hate life. Make sure everything is AMAZINGLY clean, or no joy on seating the bearing in step 21.
It's doable, may the force be with you.
markusvt is offline   Reply With Quote
Old 10-10-2011, 06:45 PM   #6
Ivanhoe
Kubica, what do you thing about this procedure ?
I did not find any DIY of removing rear bearings on a xi and I do not know the difference between xi a rwd for this issue and following your advice I found this video of a rear bearing on a 325i
I just order the bearing kit from Pelican Parts and looking for the rest of the tools.
For example I found the Bearing Separator :
http://cgi.ebay.com/ebaymotors/PERFO...item4841f84a98
And the harmonic Balancer Puller :
http://www.sears.com/craftsman-harmo...p-00947626000P
Please your thoughs
Ivan.
Old 10-10-2011, 07:23 PM   #7
markusvt
My Ride: 330xi
Re-read my post. To do this in the car, you have to break the bearing apart, and chisel the rest out. Do yourself a favor and take it out, and have the bearing pressed out and a new one pressed in. Very easy.
Old 10-10-2011, 07:29 PM   #8
Kubica
My Ride: 2003 325xi
Yeah that video looks good. Remember to buy a new snap ring and axle nut and wear goggles when you take it off. I've never done a rear bearing myself but I've seen it done on other BMWs. Removing the bolts that hold the axle to the diff is tougher than it looks in that video. Make sure you reinstall these tight, or use loctite. Hit the rotor near the retaining screw before you remove the screw to get the rotor off easier. You may have to contract the parking brake too.
Post the installation video too.
Old 10-10-2011, 08:28 PM   #9
john311tran
My Ride: awd + 5 doors
kub,
my father is a mechanic and we took both mine out this weekend without taking the knuckle apart. pm me for e-mail and pics of the process.
john
john311tran is offline   Reply With Quote
Old 10-11-2011, 09:03 AM   #10
Ivanhoe
Originally Posted by john311tran View Post
kub,
john
PM Sent, thanks for your help.
Old 10-11-2011, 11:23 AM   #11
Rickna
My Ride: '01 330xi - '09 IS-F
Wow! The B90 kit is $350. I saw on Bimmer Forums a member has it for rent-B90_Toolkit_Rental
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-12-2011, 09:54 AM   #12
Ivanhoe
kub,
john
John, I sent a pm for the email, please send those pictures. I am planning to do this job on weekend. Thanks
Ivan.
Old 10-12-2011, 09:59 AM   #13
Kubica
My Ride: 2003 325xi
^there's a link with a full write-up in the second post of this thread.
Old 10-13-2011, 07:55 AM   #14
Tele
My Ride: E46 330XIT MTech II
Am I to late with this:
http://forum.e46fanatics.com/showthread.php?t=610725
Tele is offline   Reply With Quote
Old 10-13-2011, 09:25 AM   #15
Ivanhoe
Thanks, but all of them shows front wheels or rear wheels on a fwd, if all my parts arrive on time I would do it this weekend or the next one and would put pictures and or video. I am replacing rear wheel bearings on a xi.
