Sponsored by BimmerWorld
Old 02-16-2011, 02:02 AM   #1
mikehundreds
My Ride: 2000 323i
Rear Camber
Hey guys, just was wondering how much negative camber can i run in the rear with stock arms? i know ill need plates for the front, but what about the rear?
thanks mike
M-TECH 2-ROKKOR COILOVERS-KONI REAR SHOCKS-DINAN-ROGUE-POWERFLEX-TURNER MOTOR SPORTS-BREMBO-VIBRANT-VARRSTOEN 2.2.2 19X9.5 ET20 19X10.5 ET22-
mikehundreds is offline   Reply With Quote
Old 02-16-2011, 02:45 AM   #2
LivesNearCostco
My Ride: 2003 ZHP 6MT
The conventional wisdom I've been hearing on bf.c is that you can get up to about -1.9 or -2.0 degrees per wheel using the stock arms, and that is enough for most track and AutoX drivers. The limit in the front without camber plates is usually somewhere between -0.8 and -1.6 degrees (mine maxed out at about -1.3 per side in front).
Occasionally a hard-core autocrosser running -3.5 degrees in front wants -2.5 in the back, or they want to adjust camber easily for different tires and track conditions, so they get the adjustable rear control arms. If you lower the car a lot, you might need after market control arms to reduce the negative camber.
LivesNearCostco is offline   Reply With Quote
Old 02-16-2011, 11:40 AM   #3
mikehundreds
My Ride: 2000 323i
Thanks for all the info!! how do you adjust the front tho? i thought you needed plates to do anything in the front?
Old 02-16-2011, 04:43 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
If your looking to get the most out of your suspension consider upgrading rear adjustable control arms...
Best,
Joe
Old 02-16-2011, 06:12 PM   #5
Minnoe07
My Ride: 2004 BMW 330Ci
Pretty much right on the head.
If you remove any of the 3 nuts on the strut tower, you will see that the holes are slotted. Through those slots, you can adjust camber in the front.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 02-16-2011, 06:18 PM   #6
LivesNearCostco
The front strut mount holes are slotted, allowing for about 0.5 degrees of adjustment if you knock out the alignment pins with a roll punch. (I used a nail set.) Then loosen the 3 strut mount nuts and slide the top of the strut. If you were at -0.8 degrees, maybe you can go between -0.5 and -1.1. Any more than that and you need camber plates. You may have to raise the car front (to unweight the wheels) to do this, and I found it easier to do if you remove the front wheels.
ECS Joe also sells UUC front camber plates that should let you get to at least -2.5 degrees of front camber. Vorshlag or Ground Control camber plates get to -3.5 degrees (or more) but cost more. I do buy stuff from ECS Tuning and UUC, but have never tired their camber adjustment products.
(Joe, how do you manage to be in every one of these threads? How many forums do you cover? Is there more than one of you? )
Old 02-18-2011, 11:53 PM   #7
mikehundreds
My Ride: 2000 323i
thanks for all the help guys!
