Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 4.90 average. Display Modes
Old 12-22-2012, 04:47 PM   #501
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Originally Posted by serdar255 View Post
Thanks!
No problem. If you want one done for your sedan let me know. I can do any color/material
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 12-22-2012, 06:27 PM   #502
sgplayer69
My Ride: 2003 CB M3 Coupe
Jesus, after the next upgrades this is gonna be a whole new beast
Coming Soon...?
sgplayer69 is offline   Reply With Quote
Old 12-22-2012, 07:42 PM   #503
SoloII///M
My Ride: Many
If you don't have one already get an ATI damper especially with a light flywheel.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 12-22-2012, 07:49 PM   #504
secono330ci
Will do. I just hate the fact that it takes three to make.
Old 12-22-2012, 10:29 PM   #505
serdar255
My Ride: '01 325ci / '90 325i
Coupe, and what did you use, plywood?
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 12-22-2012, 11:07 PM   #506
secono330ci
Plywood for the bottom part (a certain type of wood to retain the weight loss) and styrofoam for the top part.
Old 12-23-2012, 02:15 AM   #507
Steven747
My Ride: 05 330ci
Nice I just put in the Bimmer world and rogue tranny mounts great combo not a lot of vibration and deff noticeable .. Your going to love the cams man they are awesome. I think your out doing me with that clutch though
Old 12-23-2012, 02:53 AM   #508
secono330ci
Yea they seem to be the best mounts for a street driven car. Everyone who has them, love them. I kept debating on whether to get those or the AKG ones, but I think poly would be too harsh, especially since I already have the poly subframe bushings. I can't remember, did you install the cams yourself? If so, how hard was it?
I might have the clutch but you still have the damper!
Old 12-23-2012, 10:00 AM   #509
DarkJoker
My Ride: 01 330ci
i have vorschlag poly motor and trans mounts with powerflex poly subframe mounts its not that bad
little bit of rattle every once and a while to go along with the lightweight flywheel
why not go with the 4 bolt oil pump
its just future proofing yourself/car
DarkJoker is offline   Reply With Quote
Old 12-23-2012, 02:04 PM   #510
secono330ci
I want to, but I might have to hold off for a few months. Gotta save up some money first. I should be fine with the safety wire until then.
Old 12-23-2012, 02:11 PM   #511
Steven747
My Ride: 05 330ci
Yeah the mm are pretty sweat.. Cams I did everything myself except for the exhaust timing which was way over my head and the tools aren't common. Had a german auto place do it.. I think some company has the tools for cheap though now like German solutions or something
Old 12-23-2012, 05:21 PM   #512
SoloII///M
My Ride: Many
It's a lot better to fix the cause of the oil pump problem (harmonics) than try to band-aid a solution (safety wire, welding, etc the OPN).
John V
Old 12-23-2012, 06:24 PM   #513
Steven747
My Ride: 05 330ci
I fully understand what's going on with the oil pump nut I just don't feel the need at the moment even with my mods as well to do p.m. On it ..maybe a good thread of someone's engine blowing because of it ill do it
Old 12-24-2012, 11:09 AM   #514
///Mvious
My Ride: E46 330
Ordered yesterday:
-Clutchmasters fx100 clutch/JB lightweight flywheel
-Schrick 264/248 cams
-OS Giken super lock LSD!!!
Waiting to be installed:
Vanos Seals
Vanos Anti-Rattle Kit
Vanos Gasket
Valve Cover Gasket
Bimmerworld Group N Motor Mounts
Rogue Transmission Mounts
Meyle RTAB's
Fuel Filter
Steering Coupler
AKG Derlin Clutch & Brake Pedal Bushings
AKG Subframe Bushings
Meyle Diff Bushings
Maximum PSI Subframe reinforcement
As for the Oil Pump Nut, I was thinking of getting Greg Smith's 4 Bolt solution...but I don't know if it's worth it now since it's only a street car. Might just do Bimmerworld's safety wired OPN for now.
Beautiful! Decided against the 272's? Plan on DIYing the bushings & mounts?
///Mvious is offline   Reply With Quote
Old 12-24-2012, 12:54 PM   #515
Steven747
My Ride: 05 330ci
engine mounts take less than 20 minuets lol so do tranny
Old 12-24-2012, 01:45 PM   #516
///Mvious
My Ride: E46 330
Good to know...guess I was more curious about the diff mount bushings and subframe...bit more of a PITA no?
Old 12-24-2012, 05:52 PM   #517
Steven747
My Ride: 05 330ci
Lol if my diff bushing fails again I'm selling the car before I do that job again.. Epic epic pita.. Get the oem tool or trying to get it out will eat you alive. I've never touched my subframe or bushings though and I don't Plan on it really
Old 12-24-2012, 06:08 PM   #518
secono330ci
I said fuck it and started it yesterday..not bad at all..so far. I removed the Vanos, installed the new seals and rattle repair kit. Now just waiting on the GAS cam tools to come in
Absolutely. I'm going to try and get the 4 bolt ordered later this week.
Yes. I don't see the reason for them now since I won't be touching the head or block. The motor and tranny mounts yes, the subframe and diff (including the LSD) no. Maximum PSI will be doing the work for me. It's not a matter of difficulty, but more so that I don't have a lift at home. I'm certainly not attempting it on jack stands lol.
Old 12-24-2012, 07:59 PM   #519
rcsummers
My Ride: M3
Stav, do you still have the templates for the rear seat delete. im planning on doing this soon.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 12-24-2012, 08:08 PM   #520
DarkJoker
My Ride: 01 330ci
subframe bushing are a bit of a bitch to do
i took out the whole rear end and burnt/pressed out the old ones and installed new powerflex subframe bushings as well as M3 rtab's + limiters +alignment in 10.5 hours with a lift
first time doing it
i didnt think that was to bad
