Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#561 |
Keep it clean
Very nice. You're going to love the car.
#562 |
Now if all that only showed up on my front porch! Lookin fwd to the install, videos & dyno!
#563 |
so if i want to do cams&VAC headwork, while keeping the possibility of going fi down the road, 264's are the way to go?
![]() KW Coilovers/ 3.38 Diff/ BMW SSK/ TMS Subframe Reinforcement/ VMR V710 |
#564 |
My Ride: ZHP Custom Stage 3.5
So what cams u get?
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#565 |
#566 | ||
My Ride: 04' 330ci & 99' 540i
![]() Quote:
Yup 264/248
#567 |
Cams are in.
I took the car out for a drive and it hesitates up to 4.5k rpms. Is the timing off? Or could it be that the computer needs time to adapt? There is no check engine light..I drove for about 20 miles.
#568 |
You could try pulling the battery connection which will reset the adaptions, but I think it could be that your timing is off =/
#569 |
Keep it clean
Something is wrong.
#570 |
I just drove back from a friends house and now the car drives normal. This is weird.
#571 |
Fyi not sure if it relates I forgot to tell you there's. specific way to start your car after removing cams to get oil around and primed of sort.. You have to crank it until the red oil light disappears on the dash maybe 10-15 seconds.. My car started right up with zero problems .. Good luck hopefully you figure it out
#572 |
Already started it lol.
------------------------ Ok so I got code p0014. I found this quote on bimmerforums "P0014 is the VANOS code, not the engine itself timing code (if there are such codes at all)". Is this true? If so maybe a solenoid?
#573 |
Timings off...
If you clear code it won't pop the cel until you restart...
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected Last edited by TrippinBimmer; 01-21-2013 at 11:28 PM. |
#574 |
Damn timing that's a bitch and what I was scared of
#575 |
Ya it really should run just fine right away. It may have adapted to run better in the condition it's in but as much as I hate to say it and as much as you probably hate hearing it, your going to have to tear back into it.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. |
#576 |
Ok thanks guys. Gonna re-do it again today.
#577 |
How long was the whole cam job? Is the timing hard to do and/or fix?
Sent from my A500 using Bimmer App
![]() Want a handmade shift knob or custom vinyl stickers? PM me I'm sixteen and like cars with three pedals. My ever small company... www.facebook.com/StgFabricationAndMolds |
#578 |
Took 4 hours or less to remove cams.. Took 2 days to get the new 1's in and timed because I had no idea what the hell I was doing lol
#579 |
If you have the tools and follow the TIS it really couldn't be easier. The TIS lists every step in painful detail.
John V
'03 330i ZHP 6sp street car '02 330Ci 5sp race car |
#580 | ||
