Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 4.56 average. Display Modes
Old 04-18-2011, 05:17 PM   #161
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
Yeah, there's a problem. You're missing some power.
Can you email me the runfile? I want to overlay. Whoever has it, PM me. I'll give you my email address.
Originally Posted by ferrarix99 View Post
Hey guys, I went to the dyno with stav to do my car too, here are his numbers. He was misfiring at idle still and I think that his o2 sensors are mixed up. However he still put down 203 with those problems which is pretty damn good. Here is the graph...
also if you notice his car is running really rich because of it, im sure once he gets it fixed these numbers will shoot up
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-19-2011, 10:51 AM   #162
aggieE46
Keep it clean
aggieE46's Avatar
You're definitely missing some power. This is us compared before I had my new exhaust on (So, same exhaust, same headers, same cams.. but this was also with my DIY intake and my TB that "lost" power, Shark Injector, Evosport pulleys).
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-19-2011, 11:24 AM   #163
Iceman00
I screwed up and can't post
My Ride: ghey
What's with the DISA change over? Is that changed when the car is tuned? It will be interesting to see how SHARK vs AA handles it.
Old 04-19-2011, 11:29 AM   #164
secono330ci
My Ride: 04' 330ci & 99' 540i
My bad I just saw your post about sending you the runfile. I'm guessing nick already did that (my comp at home is broken).
I worked on the car all last night because I realized that both pre cat sensors were on the same header...don't ask lol. I switched everything last night and drove 25 miles with no problem. I don't have cams yet, but when I was on the dyno it wasn't close to running right. I'll try and go this Friday so w'e can get an accurate comparison
secono330ci is offline   Reply With Quote
Old 04-19-2011, 11:31 AM   #165
aggieE46
Keep it clean
aggieE46's Avatar
I've been told that it CAN be changed. Adam and Asbjorn discussed it. I think you can work the vanos to get it smoothed out.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-19-2011, 11:32 AM   #166
aggieE46
Keep it clean
aggieE46's Avatar
Ahhh, I'll do one before cams, then... I thought you aleady had them in. At least you can see what you have to look forward to.
This was before my cams... so, you're still missing some power
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-19-2011, 11:45 AM   #167
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
I wonder if you can remove the disa, or make the valve stay open all the time
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 04-19-2011, 11:54 AM   #168
aggieE46
Keep it clean
aggieE46's Avatar
It's been tested. You lose a lot of low end for no gains up top.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-20-2011, 12:04 PM   #169
secono330ci
Since Brady got good numbers on the intake I might just skip the before dyno and get an after dyno once
it's in...no need to waste another $80.
Old 04-24-2011, 11:45 AM   #170
secono330ci
Here's some pics
Got the summer tires back on and received the AEM filter + velocity stack. I'm REALLY impressed with AEM's quality. Btw this is a dryflow filter Now I gotta find some time to install this thing.
Yea, that's a pineapple.
Comparing Dinan filter vs AEM
Time for breakfast!
Old 04-24-2011, 07:52 PM   #171
aggieE46
Keep it clean
aggieE46's Avatar
Looks good. I want to see how it fits. Not a lot of room in there!
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-24-2011, 08:13 PM   #172
secono330ci
I know that's what I'm worrying about...
Old 04-25-2011, 12:05 PM   #173
secono330ci
Do you think it's necessary to get one of those pre filter wraps?
Old 04-25-2011, 12:14 PM   #174
xixixi
Banned User
My Ride: 01 330x-xi
It's safer. However, if you drive that car into deep enough water it won't matter what you have over the filter. A wet filter is nothing to worry about, unless it's completely emerged in water. I hope that filter fits. I was talking to K&N about making on for that same velocity stack but I backed out.
Old 04-25-2011, 12:15 PM   #175
darksideracer69
My Ride: 01 325ci
Just in case, i don't see a reason why not
IMAG02051
Old 04-25-2011, 01:00 PM   #176
secono330ci
I think it'll fit..knock on wood. I don't want the sock blocking any airflow especially considering the dryflow filter is already at a disadvantage compared to an oiled one.
The benefit is that it keeps the filter a bit cleaner, but I cant see it NOT affecting airflow.
Old 04-25-2011, 01:04 PM   #177
xixixi
Banned User
My Ride: 01 330x-xi
Take it off before the dyno? Also if you want some better numbers... look at your crank pulley and see what belt you don't need for the dyno
Old 04-25-2011, 01:59 PM   #178
secono330ci
I want that power all the time!!! I guess before I get it I need to see if the filter even fits first
Old 04-25-2011, 02:27 PM   #179
aggieE46
Keep it clean
aggieE46's Avatar
Maybe you'll get more room with the Mtech bumper, but the stock bumper is tight for the Dinan filter.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 04-25-2011, 05:01 PM   #180
secono330ci
I feel like you know it's not gonna fit but don't want to be a buzz kill
