Old 02-17-2011, 12:03 AM   #1
gurov
My Ride: 2004 325XI Turbo
Send a message via AIM to gurov Send a message via MSN to gurov
bmw scanner 1.4
this may be a repost of similar information, but i thought i'd share.
below are a few useful screenshots from a bmwscanner 1.4, which can be had off ebay from greater asian countries for fairly cheap. this thing has already paid itself off in saved frustration of being able to turn certain things off:
central body electronics control, i was able to turn off the autolocking after certain speed here:
EWS starter lock parameters:
adding/removing keys , says i have 3 keys, i only have 2. what the ****.
instrument cluster coding, i turned my "automatic transmission" off, which basically turned the gear number/steptronic indicator and the gear thing dark
i guess you can change the service intervals as well. also notice the distance/speed stuff in the 2nd column, looks like that's a way to recalibrate the speedometer/odometer.
and the light control module recoding, this is where i turned off the daytime running lights, i guess a bunch of other things are also possible, but i've not bothered with them:
hopefully some people will find this useful. there are a bunch of other modules that have option to change the coding in them, but there's no gui to do so, it would have to be done in hex, for that one has to know the format of the small bit of hex that is downloaded, and then upload it back to that module to make the changes permanent.
i should also mention that this device will give you all the errors returned by all the modules, as well as show you more engine information (live data) than you could possibly know what to do with (oil temperature also, which is neat)
2014 X1 - m-sport - stock
2004 325xi top mount turbo - megasquirt3 for engine, 5 speed swap. build thread
1994 supra MKIV - single 72mm - bc272 cams - super spec twin plate clutch - aem v2, 1000CC ID, dual denso pump, j&s ultrasafeguard
2004 SE-R SpecV turbo - megasquirt3 j&s ultrasafeguard - SOLD
gurov is offline   Reply With Quote
Old 02-17-2011, 12:11 AM   #2
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
interesting...much easier to read than ncs expert and easier to install than dis/progman/sss...i'm intrigued
EDIT: link to download bmw scanner:
http://www.bmw-scanner.com/?page=bmw...files_download
-Chris
chris98891 is offline   Reply With Quote
Old 02-17-2011, 12:12 AM   #3
gurov
what are those things you mentioned? perhaps i could adapt some of the info from that to the data downloaded via this program ? could you please provide some links to basic info ?
Old 02-17-2011, 12:18 AM   #4
chris98891
My Ride: '16 X6 50i
sure thing. bf.c has a huge forum devoted to 'em
http://forums.bimmerforums.com/forum...play.php?f=233
the stickies have tons of info
-Chris
Old 02-17-2011, 12:25 AM   #5
HakenTT
My Ride: 323i with S54
Thanks to you, I got the same scanner. It is a china copy of expensive P.A.soft scanner. If you plan on being around E46 cars for while it is well worth the investment.
Gurov can you provide info on pinout to make a bench conections for DME?
HakenTT is offline   Reply With Quote
Old 03-07-2011, 03:25 PM   #6
Robinson
My Ride: '99 323i
Send a message via MSN to Robinson
Hi Guys. I have this scanner from china and have a Problem: in my car 1999 323i Manual it only detect DME Module and on another 2000 323i Auto it only detect DME and Electronic Transmission (Gearbox) modules and in a 2002 X5 it detects all the modules.
What can be the problem? Maybe This scanner only work with latest E46?
PD: I Test in Windows 7 and Vista same problem.
Robinson is offline   Reply With Quote
Old 03-08-2011, 02:13 AM   #7
gurov
flip through these: http://gurov.us/shoebox/index.php/th...2011-02-05-bmw
Old 03-09-2011, 04:11 AM   #8
B33MER
My Ride: 330i SMG M-Sport
Gurov, if you look at the gearbox option it states "Sequential AG and Sequential M-Sport" Do you have any idea what it means especially the M-Sport. Cause when i hook mine up it show Sequential AG what happen if i choose Sequential M-Sport?
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 03-09-2011, 04:52 AM   #9
TerraPhantm
My Ride: M3 & ZHP
You need a OBD to 20-pin socket adapter to access the other modules.
Old 03-09-2011, 08:47 AM   #10
Robinson
My Ride: '99 323i
20-pin is the Round Socket in the front? And do you have any pinout to convert it?
Old 03-09-2011, 11:24 AM   #11
TerraPhantm
My Ride: M3 & ZHP
Yea the round socket under the hood. I don't personally know the pinout (my car's new enough for everything to work through the OBDII port), but I'm sure a google search could find it. You can also probably just buy an adapter on eBay for a couple dollars
Old 03-09-2011, 12:00 PM   #12
Robinson
My Ride: '99 323i
Ok Thanks I got for 12 in eBay.
And what is "Adaptation" in this software?
Old 04-11-2011, 05:27 PM   #13
dsblk93gt
My Ride: '01 325i
So what do you select to shut off the auto locks completely??
'01 325i Sedan - Alpine White, Sport Package, 5spd - daily driver 144k miles
'93 Mustang LX 5.0 - Reef Blue, 5spd, Vortech Si-Trim and alot more....
dsblk93gt is offline   Reply With Quote
Old 04-11-2011, 08:51 PM   #14
darksideracer69
My Ride: 01 325ci
Could i use this to code for the manual swap i did?
IMAG02051
Old 04-12-2011, 11:11 AM   #15
murph1379
My Ride: 2006 M3
Interesting stuff, do you know if this can be used to get the traction/stability control to "hold" its' setting after the car has turned off?
murph1379 is offline   Reply With Quote
Old 04-14-2013, 08:30 PM   #16
clarkson23
My Ride: 325i
Say I got a new key and got it cut by a lock smith and can i program the key using the bmw scanner 1.4 to have the key turn on the car?
clarkson23 is offline   Reply With Quote
