Has anyone tried these FCAB from ecs? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 02-19-2011, 09:02 PM   #1
Steven747
My Ride: 05 330ci
http://www.ecstuning.com/BMW-E46-330...ngs/ES1899439/
Wondering if anyone has these on there car? will these give a better feel than the regular rubber bushings?
Old 02-21-2011, 06:55 PM   #2
Steven747
My Ride: 05 330ci
bump any comments on those bushings? anyone have them installed?
Old 02-21-2011, 07:01 PM   #3
mvrk10256
My Ride: E30 325i
look exactly as the FCP groton cheap Chinese stuff.
Old 02-21-2011, 07:02 PM   #4
SalM
My Ride: Shhh
Nahh never tried them.
SalMPhotography
SalM is offline   Reply With Quote
Old 02-21-2011, 07:16 PM   #5
TxZHP04
My Ride: ESS TS2+ ZHP
Don't know those particular bushings but they are poly, so I'd give them a thumbs down. I'd recommend these instead:
http://www.ecstuning.com/BMW-E46-330...ings/ES205223/
Old 02-22-2011, 12:39 PM   #6
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
Definitely go with those^^
OEM feel but will last considerably longer. Made by Meyle which is the same as OEM anyways. I wouldn't go poly.
Tutankhamon is offline   Reply With Quote
Old 02-22-2011, 02:56 PM   #7
Steven747
My Ride: 05 330ci
great yeah thanks everyone for the comments, much appreciated! ... i guess i just wanted to test out a stiffer ride compared to the oem rubber bushings.. i know treehouseracing.com has some great bushings which are better than powerflex which dont have issues its just i dont think i can afford the price.. the oem's will have to do. thanks
Old 02-22-2011, 03:11 PM   #8
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
Erm...not a big fan of TreeHouse. I had my share of horrendous experiences (product quality + customer service). Their nylon moly deforms over time and the tolerance can be out of range. Soon enough you will heard a clunk everytime you brake.
IMO, go OEM rubber for street. Or go Delrin for occasional track. Everything else in between* seems to be a waste of time and $$$.
*That's right, I tried Powerflex as well.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 02-22-2011, 03:12 PM   #9
mvrk10256
My Ride: E30 325i
I dont agree I went with powerflex on my e30 autoX/DD car. very aggressive suspension set up. They work great.
Old 02-22-2011, 03:21 PM   #10
Steven747
My Ride: 05 330ci
the only things that puts me away from powerflex is the durabillity and life expectancy of it.. i dont mind the squeeking.. cant you mild out the squeeking by liberally applying anti seez? or something around there? i hear about 30% of premature powerflex failures but the other 70% dont and they love it so i really dont know what to do. I have eibach and bilsteins on and its really not that aggressive and im not in the market for sway's yet but i would like the idea of powerflex's ... what do i do ?
Old 02-22-2011, 04:25 PM   #11
FTWeisse
My Ride: has no hip-hop rimz
Get HD - this topic has been beaten to death. Many of us with full on racecars don't use polyurethane bushings - we either use rubber or spherical. Personally, I have all rubber bushings on my racecar except for the subframe bushings which are delrin/aluminum.
Get Rubber.
Old 02-22-2011, 04:45 PM   #12
Steven747
My Ride: 05 330ci
right and im not a noob on searching or anything theres just no deffinitive answer .. it seems to have equal pro's and cons for both but is there anyy bushings that have equal performance tooo powerfle's? or is there not and i just have to go with regular rubber
rubber equal to powerflex's firmness?
Old 02-22-2011, 06:10 PM   #13
FTWeisse
No - there is no comparable rubber - but you can COMPROMISE. And the best compromise is HD Rubber.
Old 02-22-2011, 06:18 PM   #14
mvrk10256
My Ride: E30 325i
If you install the powerflex correctly and use the grease they provide they wont squeek and will work perfectly. However you can use OEM, HD rubber, poly (80A or D), delrin, or aluminum.
Poly is dead center in that list for a reason - more firm than stock and HD rubber, but not as much noise or damage to other components as delrin or aluminum - remember all those vibration that is now not being absorbed goes straight into other components.
Old 02-22-2011, 07:22 PM   #15
TxZHP04
I'll be perfectly honest with you. I run a very aggressive suspension setup for street use with Meyle HD CABs. From a performance perspective, I have never once felt that my suspension isn't responsive enough or that I don't have enough road feedback. If you earn your living as a professional race car driver, then spherical is the way to go. For anything else, go rubber. Stick with the stock fluid filled rubber for the ultimate in isolation or HD rubber for longer service life and a touch more feedback. As for everything else in between, I have to agree with Mr. Paddle Shift.
Old 02-22-2011, 07:49 PM   #16
Steven747
My Ride: 05 330ci
ok ill be going with meyle hd's ..
is that the hd's?
Old 02-23-2011, 09:02 PM   #17
BruceJ
My Ride: 2007 Z4Si 2003 330i
is that the hd's?
Yep, they are the HD's. While you are spending money at ECS you may want to consider just picking up the Meyle control arms as well. Awesome replacement for the OEM. They sell the bushings with them as a kit:
http://www.ecstuning.com/BMW-E46-330.../OEM/ES205226/
Mods (E46)
MTECH II Bumper, Predator Chromiums, Homelink,
Bluetooth Retrofit, Miro 346 Wheels, First Aid Boxes, Orange TPMS
Repairs (E46)
GM5 Door lock relays
LCA's FCAB's, RTAB's
Cooling system overhaul
CCV annd OFMG
BruceJ is offline   Reply With Quote
Old 02-23-2011, 09:10 PM   #18
Steven747
My Ride: 05 330ci
my car does wonder on the highway sometimes which is slightely annoying but i think it might be because of my front bushings.. i just ordered the bushings today so i hope that will fix the issue. hey while im here i guess i can ask you guys.. you know how SOME i highlighted because not all beliieve this but some people say putting aftermarket sway bars on a stock suspension is a bad idea.. i have eibach springs and bilstein shocks and its really the same feel as stock.. would putting a uuc or hotchkis sway bar on make the ride quality bad? thanks
Old 02-23-2011, 09:28 PM   #19
TxZHP04
No, it won't affect ride quality very much especially if you don't set the rear bar too stiff. When the L and R wheels hit a bump at the same time, the sway bar has absolutely no affect at all. When one wheel hits a bump and the other doesn't, the suspension will suddenly feel a little stiffer though. I would recommend the H&R or Turner bars simply because they require no maintenance.
Old 02-23-2011, 09:53 PM   #20
Steven747
My Ride: 05 330ci
right so it wont have that much effect on ride quality but when in turns it will improve handling alot correct?
