Old 02-21-2011, 04:21 PM   #1
mikel325xi
My Ride: 2001 325xi
Window regulator best brand???
I have 3 Window Regulators to replace on my 2001 325XI. Best brand other than BMW??? that might save a few dollars or is BMW superior????? I have read the DIY's and seen the Video's and am ready to go. Go for the aftermarket doorman?? or other brand??? Thanks, Mike
mikel325xi is offline   Reply With Quote
Old 02-21-2011, 04:31 PM   #2
xi_ter
My Ride: 2003 325xi
VDO, probably OE.
Available at Pelican and probably other sources
http://www.pelicanparts.com/bmw/cata...pg4.htm#item14
Old 02-22-2011, 03:32 PM   #3
mikel325xi
My Ride: 2001 325xi
Thanks Xi ter!, anyone else had a good experience with any aftermarket brands???? Thanks, Mike
Old 02-22-2011, 11:50 PM   #4
hammerheart
My Ride: 02 330XI
just buy OEM, around $100 from the sponsors here.
hammerheart is offline   Reply With Quote
Old 02-23-2011, 09:26 AM   #5
99
My Ride: 2013 Sonata 2.0T SE
Well the OEM parts were **** to begin with and fail all the time so I'm not sure that there's an advantage to paying more for them unless you can get a good deal from a site sponsor.
I bought a driver's side rear window regulator from this website and it's been fine for over a year.
http://www.1aauto.com/1A/WindowRegulators/BMW/330i
Good luck on the DIY. It's easy but takes a lot of time. I have 2 pieces of unsolicited advice for you.
1. As you remove screws, use masking tape to tape the screws to the door panel near the place where you'll replace them.
2. Take your time when removing the vapor barrier and use a box knife or razor blade to cut through the adhesive.
99 is offline   Reply With Quote
Old 02-24-2011, 12:35 PM   #6
Rickna
My Ride: '01 330xi - '09 IS-F
I've had to replace 2 regulators pass/front & rear. I got the replacements from FCP Groton. I know that FCP is notorious for selling Chinese parts. It's more than likely that the regulators are from China. However, they have working perfectly for over 2 years.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-24-2011, 02:16 PM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We have Genuine BMW as well as OEM equivalents available as low as $37.95 below...
Best,
Joe
Old 02-25-2011, 03:34 PM   #8
99
^ECS prices look great. OP: You should buy from them.
Old 02-28-2011, 11:39 PM   #9
beyondd
My Ride: 02 bmw 325xi
Me & a buddy just replaced my driver side today with non-oem and when we took the old one out you can see there is no grease or oil along the stock regulators. We installed the new one with new motor and it was still slow and stopped every 2 inches on the way up; so we took some some kind of brake grease and ran it up and down the regulators & after a few runs up and down the window works great. Try greasing up stock and see if it starts working better if you wanna try to save a few bucks.
beyondd is offline   Reply With Quote
Old 03-06-2011, 09:57 PM   #10
JosephZ
My Ride: 2001 325i
Not the Ebay ones..well the inexpensive ones..I put one in yesterday and within 1 hour of use,,it snapped..
JosephZ is offline   Reply With Quote
Old 03-07-2011, 01:37 PM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Thanks for the support!
Old 03-07-2011, 05:42 PM   #12
Rickna
Definetly. Fast service and reasonable shipping.
2001 BMW 330xi
2009 Lexus IS-F
Old 03-07-2011, 05:59 PM   #13
SamDoe1
My Ride: 4cyl of fury
Which brand from ECS? There are three of them...
Old 03-07-2011, 06:08 PM   #14
Romanian
My Ride: 03 325i
Best brand is use two zip ties.
http://www.skene.org/bmw/window/
Two zip ties here and you won't have any problems with the window regulator again. If you buy the OEM piece your buying the same piece with the same design flaw.
Better to actually fix it so you don't just have to replace it again.
Used this method on mine and it works flawlessly.
Romanian is offline   Reply With Quote
Old 03-07-2011, 06:12 PM   #15
Romanian
My Ride: 03 325i
http://forum.e46fanatics.com/showthread.php?t=356847
Just follow the DIY and your set.
Also no need to replace the regulator, just fix it. This solution has been working for years now.
Old 03-07-2011, 08:43 PM   #16
SILVRRONIN
My Ride: 2003 325.xit
ECS is good stuff... I like them..stil need more info from them about swaybars for the XI..( I have a touring).
SILVRRONIN is offline   Reply With Quote
Old 03-08-2011, 09:58 AM   #17
ECSTuning
ECSTuning's Avatar
My Ride: BMW
MTC or URO are great bargains for the $$!
Thanks again for the kind words everyone!
Old 03-08-2011, 10:15 AM   #18
SamDoe1
Do they last though? Or will they break in 2 weeks and I'll have to do this all over again?
Old 03-08-2011, 10:56 AM   #19
ECSTuning
ECSTuning's Avatar
My Ride: BMW
I've had two URO regulators in my own personal E46 for 2 years thus far w/o any issues.
Old 01-05-2012, 11:22 PM   #20
burnhamd
My Ride: 325i 2002
I bought an MTC regulator after it was recommended by ECS tuning and it failed after only two months with my window in the down position. I had to take it to the dealership because they were the only shop that had one in stock. I don't know if it was just a fluke but I definitely can't recommend it.
burnhamd is offline   Reply With Quote
