Old 05-19-2013, 11:55 PM   #41
swordsman11868
My Ride: 2003 325i
^^+1 on the track needing lubrication.
I believe a silicone based spray will work fine. Should be a yearly PM operation.
Just my .02.
-Dan
It's much easier to PRESERVE an E46 than it is to RESTORE one.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is online now   Reply With Quote
Old 05-20-2013, 01:54 AM   #42
tdeep510
My Ride: 2000 BMW 323i 5speed
Window regulator best brand???
Originally Posted by jmo69 View Post
I did the e-bay regulator and other than noises that sounds like abrasive in the track and a clicking like gears slipping it's been working OK since last Aug. Although the wife uses it very seldom due to the noise. It did work better, move faster, after I did the GM5 module repair. If it does fail, I will do the Dorman from Advance Auto because of the lifetime warranty and the newest store around here seems to show one in stock everytime I check their online inventory. I do need to check out what's making the noise, maybe a little lube will help.
Dont know the price ranges on advance auto, but i found some fairly less expensive dorman brand regulators on amazon!
tdeep510 is offline   Reply With Quote
Old 05-21-2013, 02:00 PM   #43
ZemogFC3S
My Ride: '02 330xi
I take back what I said about Dorman.
The drivers front regulator I put in failed back in december. I just replaced it with a warranty replacement.
I think dorman is fine for the rears thats don't get used all them time but in hindsight I would go OE with the drivers window.
~ '02 330xi
~ '89 RX7 TII
ZemogFC3S is offline   Reply With Quote
Old 05-21-2013, 04:50 PM   #44
tdeep510
I just ordered front passenger and rear drivers side from ebay for 100 with motors. Theyre dorman. Lets see how it goes!
Old 05-21-2013, 05:17 PM   #45
Riverbmr3
My Ride: MB E350 & BMW 325i
Zip tie it before the install
Riverbmr3 is offline   Reply With Quote
Old 06-17-2013, 01:43 PM   #46
ZemogFC3S
My Ride: '02 330xi
The plastic "pulley" at the bottom of the regulator is what broke on mine. It only lasted 4 months on the car. Zip tie mod doesn't help there.
~ '02 330xi
~ '89 RX7 TII
Old 09-25-2013, 09:05 PM   #47
jmo69
My Ride: 03 325xi 98 328is
The noises on my E-Bay regulator have gotten worse and the window moves slow again. Still considering the Dorman but I'm going to see what's what with the one in there this weekend for sure.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 09-26-2013, 11:40 AM   #48
Arnezie
My Ride: 04 325XI
I bought a doorman with lifetime warranty , made in China but lifetime warranty is what I liked. Also quality was as good or better than oem.
Arnezie is offline   Reply With Quote
Old 09-28-2013, 08:21 PM   #49
jmo69
Just replaced the Ebay regulator with the Dorman unit, window is quiet now. Couldn't figure out what was causing the crunching noise on the old one. Lube didn't help, the noise seemed to come from the cable sliding across the steel.
Hers His
Old 09-29-2013, 08:28 PM   #50
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Re: Window regulator best brand???
Just did the zip tie fix. But now my window will not do the auto close only the auto open how can I fix this?
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 09-29-2013, 09:32 PM   #51
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Nevermind fixed itself
*NWS GIF REMOVED*
*GIF REMOVED*
Old 03-17-2016, 09:30 PM   #52
peacechild
My Ride: 325i
I contacted the engineering team at BMW Germany many year ago about their choice of materials, this was just after my 2001 e46 warranty just ran out, and two windor regulators failed. They did not like that and sent a message to BMW USA and they were most helpful in replacing the two regulators. I have since then replaced all four and now, 2016, it's time to do all four again, as the drivers window failed today and I need to lower it to reach the card reader at work, darn.
Not a good choice of materials and aftermarket fall into the same problem. All metal or Delrin would work better but more expensive.
Len
peacechild is offline   Reply With Quote
