Old 02-22-2011, 10:32 AM   #1
josephmech
My Ride: 2001 325i sedan 5m
Power steering fluid Pentosin
Hydraulic System Fluid CHF 11S Synthetic Oil for Power Steering and Hydraulic System (1 Liter)
Quantity in Stock: 225
Part Number: 82-11-1-468-041 / 82111468041
Manufacturer: PENTOSIN
Applications: BMW
Is this ok to use in my 2001 325i power steering system on the cap it says ATF I am wondering if this would make my PS system function or last longer or do the oposite
Name:	bmw girl pic.jpg
ID:	394032   Click image for larger version
Name:	*** girl apron.jpg
ID:	394033   Click image for larger version
Name:	power steering fluid.jpg
josephmech is offline   Reply With Quote
Old 02-22-2011, 10:34 AM   #2
nk_zhp
My Ride: ZHP / E30 M3
NO! Use exactly what's on your label. ATF damages seals for racks meant to operate with Pentosin and vice versa.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 02-22-2011, 10:44 AM   #3
Hector45
My Ride: 2002 OB 330i
Cap says it for a reason, stick with ATF!
Hector45 is offline   Reply With Quote
Old 02-22-2011, 10:45 AM   #4
mmaldin
My Ride: '04 325xit '94 325i
Is redline D4ATF OK? Anyone using it for PS?
mmaldin is online now   Reply With Quote
Old 02-22-2011, 10:55 AM   #5
franz
My Ride: 03 330i
Redline D4ATF is perfect, as is their PS fluid. I have used both, they seem very similar.
franz is offline   Reply With Quote
Old 02-22-2011, 12:42 PM   #6
genuity
My Ride: 2001 330iS
How does the first two pics (starting from the left) relate to the third one? How do they even relate to the post topic?
genuity is offline   Reply With Quote
Old 02-22-2011, 12:44 PM   #7
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Those are his private fantasy pics he posted up by mistake.
GoingNuts is offline   Reply With Quote
Old 02-22-2011, 12:56 PM   #8
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Read manual, read many ps fluid threads. I use dex3...later years, I think dex6...if changing what was in there, guess you'll drain it entirely?
Study all your fluids...trust no one. Trust me!
I'm on phone so if I wrote something stupid, it was probably the phone!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-23-2011, 09:01 PM   #9
Sansho
My Ride: 2001 325i
I've used M1 Synthetic ATF and all continues to work well.
Sansho is offline   Reply With Quote
Old 02-24-2011, 07:57 AM   #10
vintagegz
My Ride: 2005 330ci/2004 330i
Note that Dexron VI is not to be used in power steering applications, must stick with Dexron III such as Mobil 1 version.
vintagegz is offline   Reply With Quote
Old 02-24-2011, 08:52 AM   #11
MindFK
My Ride: 330Ci
Vintagegz, whats your proof for that?
How is dex 3 different from dex 4? 5? 6? They are all non synthetic which is bs. Higher should be better? No?
Use mobil 1 synthetic atf.
MindFK is offline   Reply With Quote
Old 02-24-2011, 09:09 AM   #12
Elwin
My Ride: 330i ZHP
Applications: BMW
Your car requires "ATF Dexron II-D" into power steering. "D" is very important.
Elwin is offline   Reply With Quote
Old 02-24-2011, 09:10 AM   #13
GA-e46
My Ride: 2001 325i
I thought youl go up from Dex 3 to 6 because it covers the requirements for 3, 4, and 5. But you can't do the reverse and go from 6 to 3 if 6 is required?
GA-e46 is offline   Reply With Quote
Old 02-24-2011, 10:58 AM   #14
shortyb
My Ride: Has blue lights
Uh, no. Dex III and VI have different physical properties for different applications. Dex VI is a newer fluid designed for newer trannies to meet very stringent efficiency ratings. Just because its newer does not make it "better".
You can use any decent Dex III ATF.
shortyb is offline   Reply With Quote
Old 02-24-2011, 12:15 PM   #15
vintagegz
I bought some GM dex VI last year when I was flushing my ps fluid, as I remember the bottle said not to be used in ps systems, so I flushed and went back to Mobil 1 Dex III, check the label surprised me also as usually these fluids are backward compatible
Old 02-24-2011, 12:24 PM   #16
Arsevader
My Ride: '90 325i, '02 325it
No such thing as Dexron 4 or 5.
As mentioned, Dexron VI is newer but isn't necessarily better (Like DOT 5 brake fluid, GL-5 Gear oil etc).
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 02-24-2011, 12:26 PM   #17
vintagegz
no Dex VI in power steering systems
here you go, long but interesting
General Motors DEXRONŽ-VI Global Service-Fill Specification
During early 2005 General Motors released a newly developed automatic transmission fluid (ATF) for the factory fill of all GM Powertrain stepped gear automatic transmissions. The new fluid provides significantly improved performance in terms of friction durability, viscosity stability, aeration and foam control and oxidation resistance. In addition, the fluid has the potential to enable improved fuel economy and extended drain intervals. Since the performance of the new fluid far exceeded that of the DEXRONŽ-III service-fill fluids available at the time it became necessary to upgrade the DEXRONŽ service-fill specification in order to ensure that similar fluids were available in the market for service situations. This latest upgrade to the service- fill specification is designated DEXRONŽ-VI.
Since General Motors introduced the first ATF service-fill specification in 1949 it has been periodically necessary to upgrade the specification. This upgrading process ensures that available service fill fluids are of an appropriate quality for use in transmissions that have been designed around the factory fill fluid performance. It should be noted that, as with previous upgrades, DEXRONŽ-VI fluids are designed to be backward compatible with earlier transmission hardware. More importantly, earlier type fluids are not forward compatible with transmission hardware that was designed to use DEXRONŽ-VI fluid, i.e. DEXRONŽ-III is not compatible with the most recently designed transmissions, and the use of these earlier type fluids could result in transmission damage. All current calibrations and certification tests are now conducted with DEXRONŽ-VI ATF. DEXRONŽ-III fluids should not be used for these applications where the owners manual recommends the use of DEXRONŽ-VI. GM does not license or support obsolete ATF specifications or the use of fluids that are being marketed against cancelled specifications.
All DEXRONŽ-III licenses expire at the end of 2006 and will not be renewed. Beyond that date GM will only support the use of DEXRONŽ-VI fluids for use in Hydra-Matic transmissions. Fluids sold in the market after that date bearing claims such as “suitable for use in DEXRONŽ-III applications” or similar wording should be avoided. DEXRONŽ-VI licensed fluids are fully backward compatible and can be used in all applications covered by earlier GM ATF specifications.
and from GM Tech Link at
http://www.sandyblogs.com/techlink/2...dexron-vi.html
Although DEXRON-VI (fig. 1) was introduced into production starting with 2006 model year vehicles (see bulletin 04-07-30-037D), there are still some misunderstandings about it. Here are some facts to help clear up these misunderstandings.
Since GM introduced the first service-fill specification for automatic transmission fluid (ATF) in 1949, it has been necessary periodically to upgrade the specification as part of a continuous improvement strategy. The upgrading process ensures that available service fill fluids are of an appropriate quality for use in transmissions that have been designed around the improved factory fill fluid performance.
IMPORTANT: As with previous upgrades, DEXRON-VI fluids are designed to be backward compatible with earlier transmission hardware. But more important, earlier type fluids are NOT FORWARD COMPATIBLE with transmissions that were designed to use DEXRON-VI.
DEXRON-VI can be used in any proportion in past model vehicles equipped with an automatic transmission, in place of DEXRON-III (for instance, topping off the fluid in the event of a repair or fluid change). DEXRON-VI is also compatible with any former version of DEXRON for use in automatic transmissions.
TIP: Simply topping off the fluid is adequate, but a full drain and replacement is preferred, to obtain the full benefit.
IMPORTANT: DEXRON-VI Automatic Transmission Fluid (ATF) is the only approved fluid for warranty repairs for GM transmissions requiring DEXRON-III or prior DEXRON transmission fluids.
TIP: Any vehicle that previously used DEXRON-III for a manual transmission or transfer case should now use p/n 88861800 (88861801 in Canada) Manual Transmission and Transfer Case Fluid. And power steering systems should now use p/n 89020661 (89021183 in Canada) Power Steering Fluid.
Old 02-24-2011, 01:00 PM   #18
Arsevader
This only relates to GM vehicles and not other makes such as BMW that use Dexron III in PS systems. Most BMW PS systems are not compatible with 'Power Steering Fluid'.
Do not follow this recommendation unless you have a GM vehicle.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 02-24-2011, 04:53 PM   #19
vintagegz
your vehicle, your choice, your pump
Old 02-24-2011, 05:48 PM   #20
sprintman
My Ride: Ex 325CI owner
Redline D4ATF in mine and still as new after 50,000 kms. I checked the spec for fluid with Dave at Redline.
sprintman is offline   Reply With Quote
