///M3 Forum
Old 02-22-2011, 02:19 PM   #1
cosmos///m3
My Ride: 2005 JB/IR ZCP ///M3
FINALLY...ST Coilover Install... PICTURES
Well like the title says I finished with the install earlier today... Overall not to bad at all, except for the damn RTABs...maybe im just an idiot but it took me a good 10 mins just to figure out how to get the damn tool to work :lolhit: I really enjoyed doing the install myself... Not only do I have the extra money in my pocket, but also self satisfaction :thumbsup2:
Anyways I rather be slow and take my time, making sure everything is done right than rush through and not have things be right... I still have to make minor adjustments with ride height, but everything seems A O K :thumbsup2:
Now for the pictures
(there are plenty of DIYs... so no need to comment each picture... but if you have any ?s feel free to PM me :thumbsup2
(had to remove RSMs after picture... forgot to lube it up :shifty
Drumroll...:drums:
(10 minutes after she was off the jack stands)
My Favorite
My one question I do have... Im guessing I am going to have to remove the Driverside Front Im thinking I either didnt torque this side down enough or something Anyways the short drive I went on after I was finished I could hear a small rattle up front so I am guessing this is the plaintiff...
Any ways to torque without removing everything?
I would also like to give a thanks to Prit :thumbsup2:
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
cosmos///m3 is offline   Reply With Quote
Old 02-22-2011, 02:22 PM   #2
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
the ride is probably very nice right now since the suspension is new, but can you chime in a few months later to give a final review?
Devious1 is offline   Reply With Quote
Old 02-22-2011, 03:31 PM   #3
egk2
My Ride: is Alpine Weiss...
How's the ride? Looks like you could space the wheels out.
egk2 is offline   Reply With Quote
Old 02-23-2011, 01:39 AM   #4
kaiv
My Ride: E46 M325iT
Congrats on the install!
It looks like you have air; you can just impact the strut hat nut.
kaiv is offline   Reply With Quote
Old 02-23-2011, 02:12 PM   #5
cosmos///m3
Seems to be very comfortable as of right now. Compared to my old roommates Ground Control setup I think it will alot more on the comfort side than his... but Yep Ill chime back in with a small review in a month or so
I just adjusted everything last night and I am currently sitting at 13.25" all around... not sure if thats where I exactly want it, but works for now. I actually have 15mm spacers up front and 12mm in the rear shown on the pictures
I tried using the impact on the strut hat nut and the damn thing just spins... any suggestions?
Old 02-23-2011, 05:19 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
If you're trying to tighten that nut on the top, it looks like you have to stick an allen wrench in the top opening and use a crescent wrench or open ended wrench to tighten it. The allen key will keep it from spinning.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-23-2011, 06:14 PM   #7
cosmos///m3
Yeah... about that... easier said that done finding a wrench that not only fits in the opening, but also secures the bolt and allowing the use of an allen key
Old 02-23-2011, 06:39 PM   #8
VMRWheels
VMRWheels's Avatar
You're probably going to have to remove the suspension in order to access that and torque it down correctly unfortunately. Otherwise you could try getting some type of vice or wrench with some form of a soft grip and squeeze the piston/shaft without damaging it while using an impact gun.
Old 02-23-2011, 07:38 PM   #9
HardPark'd TT
My Ride: is parked hard.
Send a message via AIM to HardPark'd TT
Shouldn't having the wheels on the ground keep it from spinning and you can just torque it? At least that's how it is on my TT. I never did coils on my M3...
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
HardPark'd TT is offline   Reply With Quote
Old 02-24-2011, 11:44 AM   #10
cosmos///m3
Thats the impression I had, but unfortunately I was wrong again I might actually just try taking it up to a shop and seeing if they can hit it with an impact, I think mine is just to weak...
Old 02-26-2011, 09:11 PM   #11
kaiv
My Ride: E46 M325iT
Maybe a little late now but I took a pic of the tools you need to tighten that:
Old 02-28-2011, 02:27 PM   #12
cosmos///m3
Yeah I just got something very similar to what you have that worked. BTW what kind of socket is that? I wanted to purchase a "through rachet" set where the allen wrench could be used also, but it only went up to 3/4" in size when I needed the 7/8"
Old 01-11-2012, 04:09 PM   #13
khurram
My Ride: IB M3
For the rear springs, did you reuse the top oem spring pad for the bottom?
khurram is offline   Reply With Quote
Old 01-12-2012, 12:49 PM   #14
STiwhip
My Ride: AW Slick Top 6mt
if you're using a pneumatic gun. wait till the compressor fills up completely then constantly "blip" the gun untill it stops spinning. The problem is that the strut shaft spins. so you have to keep blipping the gun to get them to seat.
STiwhip is offline   Reply With Quote
Old 12-01-2012, 05:13 AM   #15
nick0780
My Ride: 2004 M3
So how is the handling on these. Firmer?
nick0780 is offline   Reply With Quote
Old 12-02-2012, 01:34 AM   #16
joeysm3
My Ride: ///M3 02
+1 very intrested
(noticed he bumped 1 year old thread
joeysm3 is offline   Reply With Quote
Old 12-02-2012, 04:13 PM   #17
illestminimike
My Ride: Project Drama
I know it's an old tread but if anyone has pics of these coils maxed out I would really appreciate it.
Old 12-02-2012, 04:29 PM   #18
scrace
My Ride: 03.5 M3
Spacers next?
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 12-02-2012, 05:14 PM   #19
Ballstowalls
My Ride: 05 e46 m3 vert
Wow that's like a perfect high not to low were u scrape on a pine cone (my friends Lexus GS400 did lmao
Ballstowalls is offline   Reply With Quote
Old 12-03-2012, 09:56 AM   #20
joeysm3
My Ride: ///M3 02
http://www.modbargains.com/ST-Speedt...6-M3-90223.htm
scroll all the way down ull see car slammed on them
