Old 10-25-2012, 07:41 PM   #21
san_siro
My Ride: 323i
After consulting with several users here, decided to have shop drill 3 holes from underside of grill to the reinforcement bar. Got home and had to adjust the ends that meet fender because shop said fit was due to aftermarket bumper. Now there is still noticeable gap under the headlight area. Do i need to raise the bumper or just put foam inserts on top of the reinforcement bar? Thanks.
san_siro is offline   Reply With Quote
Old 08-12-2014, 10:35 PM   #22
booey23
My Ride: 03' 325I
Originally Posted by AMCINK View Post
A) Need to remove the metal carrier
B) Need to remove the plastic holder form your old bumper
C) Need to glue the plastic holder to the new bumper
D) Then install the metal carrier
Brought back from the dead. Whats a good glue to put the bumper holder onto the bumper? Is there another way?
Sting like a bimmer - Mcqueen
booey23 is offline   Reply With Quote
Old 08-27-2014, 12:35 AM   #23
happyfelthappy
My Ride: 2001 BMW 330i Sport
What about this bumper? http://www.ebay.com/itm/BMW-E46-M3-S...81624623&rt=nc
Previous Cars:
95 Nissan 240SX Auto -First Car :) / 91 Camaro RS 5.0 Manual / 99 BMW 323i Manual / 1984 Porsche 944 / And others..
Current:
2001 BMW 330i M Tech I Sport / 2001 Jaguar XJ8 L 4.0 V8 (Daily, gas guzzler)
Parts wanted '01 330i
-Electric Fan -Windshield Cowl -Front lower control arm bushings -Air intake manifold (on radiator support) -Oil level sensor
happyfelthappy is offline   Reply With Quote
Old 08-28-2014, 11:30 AM   #24
Seirith
My Ride: 01 330ci
I went through this process a month or so ago. Here's what i wish i knew the first time.
1. that bumper looks fine.
2. Make sure you also get the following, both 330ci front lower fender well plastics. The sides of the bumper attach here and it is more secure if these are new or newer. Also the M3 radiator intake shroud. it uses a different one than the stock bumper. M3 brake ducts if you can. not an absolute must but does help.
3. You don't need to remove the old metal reinforcement clips from the old bumper. you can glue the new bumper to the metal clip. you just need to call 3m and make sure you get the glue specifically for gluing aluminum to plastic.
4. The process is a pain but looks really nice in the end.
Seirith is offline   Reply With Quote
e46, m3 bumper, problem, sedan, umnitza
