E46 Xi Forum
Old 02-27-2011, 11:51 PM   #1
Shinji Hirako
My Ride: 325xi
Exclamation Tein coilovers for XI on ebay!
Does anyone know if these will really fit the xi cause i'm about a week away from buying them!?
http://cgi.ebay.com/ebaymotors/TEIN-...#ht_1432wt_950
Shinji Hirako is offline   Reply With Quote
Old 02-28-2011, 01:20 AM   #2
sky123
My Ride: 330xi
2000-2005 3 Series E46 4Dr Excl. M3/ 4WD/ Wagon, it doesnt fit XI
sky123 is offline   Reply With Quote
Old 02-28-2011, 01:50 AM   #3
Dreamliner330
My Ride: 330xi
Shocks or bust. Coilovers ride super stiff...and, you live in NY.
NY=Snow.
See link in my sig for suspension overhaul components...
oh, and stay off eBay!
Dreamliner330 is offline   Reply With Quote
Old 02-28-2011, 07:17 AM   #4
My white xi
My Ride: 2004 330xi
NO they do NOT fit ...your xi...
My white xi is offline   Reply With Quote
Old 02-28-2011, 09:00 AM   #5
Rickna
My Ride: '02 330xi AT
Send a message via ICQ to Rickna Send a message via AIM to Rickna Send a message via MSN to Rickna Send a message via Yahoo to Rickna
NY=Snow.
^What he said^
237 years of democracy has died, and with thunderous applause
My_Mods_&_Stuff
Rickna is offline   Reply With Quote
Old 02-28-2011, 09:06 AM   #6
Shinji Hirako
My Ride: 325xi
NY=Snow.
Thank you Mr.liner! lol!
Old 02-28-2011, 09:11 AM   #7
Shinji Hirako
My Ride: 325xi
I wanted to go coilovers cause im not sure what size rim and tire i was planning to go with.
Old 02-28-2011, 09:13 AM   #8
lotar_6
My Ride: '01 xi, '94 Rado
Not all coilovers are harsh... you get what you pay for... especially true w/ coilovers. That said, I'd never do coils on a car that sees winters... just my opinion. And I've not looked into coilover options for the xi... get to researching!
lotar_6 is offline   Reply With Quote
Old 02-28-2011, 09:28 AM   #9
Shinji Hirako
My Ride: 325xi
Why wouldn't you put coilovers on a car that see's winter?
Old 02-28-2011, 12:23 PM   #10
lotar_6
I'll clarify... winters in northern states that use salt on the roads. Even with good coating or treatments for the threads on coilover sleeves, they still corrode and collect dibris. I suppose if you are diligent about cleaning and re-treating them through the winter it would be better, but who remebers to do that? I've just seen what winters do to the sleeves and what happens when people then try to spin the collars.
If you just plan on setting and forgetting, why do coils in the first place? There are really only two reasons to consider coils. 1) Dumping the car lower than sport springs will go. 2) Fine tuning adjustments for racing... primarily for corner balancing. If you aren't doing either of these, then why bother w/ coils? Pick your wheels, then set-up your suspension.
Old 02-28-2011, 02:43 PM   #11
Shinji Hirako
My Ride: 325xi
I wanna go with option 1) alex! all jokes aside i wanna go as low as posible during the warmer seasons then being able to raise it for the winter. Plus if i go with a certain size tire and rim i'l be stuck without being able to adjust ride hit!
Old 02-28-2011, 03:12 PM   #12
Mark M
My Ride: e30M3, e46M3, e83X3
Shindjo....are you aware that each time you change ride height you should technically have an alignment done? Changes in ride height affects rear camber, front camber, front caster, and potentially even toe if the change is drastic.
Are you budgeting for two alignments a year? Not trying to should harsh. Just brining the knowledge to the newbs.
Mark M is offline   Reply With Quote
Old 02-28-2011, 08:04 PM   #13
Shinji Hirako
My Ride: 325xi
I have a spot that does alignments for pretty cheap but i never took it into consideration! Thanks for the info!
Old 03-01-2011, 10:01 PM   #14
White_Knuckles
My Ride: 2003 325xi
Yeah your "spot" better be well versed with these babies. My Indi shop performs a crazy volume of alignment business. He invested in a proper alignment rack to perform the task on BMW's, Audis' and Mercedes because most shops screw it up and you don't even know. My wife's MINI Cooper was aligned twice by other "pros" before we learned these are tricky to do a 4-wheel alignment properly. It's $100 a pop but well worth it. Cheap is a bad indicator they're hacking.
