E46 Xi Forum
Old 02-26-2011, 02:05 PM   #21
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
Got new cv boots for my 330xi 2004 with 66.000 miles, original from bmw inner and outer boots right and left...
the new boots had leaking (!) and all the grease was out of the cv boot after ~ 1000 miles ... my axles are damaged extremly, getting new ones from "ERA Benelux" - that are original bmw axles...
replaced my xi-engine mounts too...
Hageee is offline   Reply With Quote
Old 02-26-2011, 03:25 PM   #22
Rickna
My Ride: '01 330xi - '09 IS-F
Good yhat you could take advantage and change the motor mounts while you were there.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 02-26-2011, 03:39 PM   #23
Hageee
My Ride: E46 330xiA
It's amazing, that my motor-mounts are defective ... after 66.000 miles, my car was shaking @ "D" by ~ 650 RPM...
the axles are from ERA Benelux, OEM-BMW, costs: 400 right & left
Old 02-26-2011, 03:58 PM   #24
Rickna
Yeah, I'm at 80,000 mi and it shakes at idle-I'll have to change the motor mounts soon.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-26-2011, 09:10 PM   #25
Kubica
My Ride: 2003 325xi
^^Yeah the motor mounts, rear springs, waterpumps, and thermostats they put on these cars are embarrassing.
Old 03-01-2011, 12:26 AM   #26
VladV
My Ride: E46 325xi
Hi.
Some days ago I found clicking in front axle.
The inspection showed that left front axle inner boot is ragged and it's placed too close to arm ball joint. Think it could be ragged of this cause find traces on the boot from ball joint.
Smb had the same problem? What will be solution...
Thnx.
VladV is offline   Reply With Quote
Old 03-01-2011, 04:50 PM   #27
Shinji Hirako
My Ride: 325xi
Originally Posted by VladV View Post
Hi.
Thnx.
WHAT?
Shinji Hirako is offline   Reply With Quote
Old 03-01-2011, 05:40 PM   #28
Kubica
My Ride: 2003 325xi
Originally Posted by Shinji Hirako View Post
WHAT?
Dude he's from Russia and it's his first post . . .do we need to remind you of your first post?
His outer cv boot got caught up in his ball joint and got chewed up, if I'm understanding that correctly.
Old 03-01-2011, 06:41 PM   #29
Rickna
It's better English than some that are born here...
2001 BMW 330xi
2009 Lexus IS-F
Old 03-01-2011, 07:53 PM   #30
Kubica
My Ride: 2003 325xi
That's what I'm saying . . . I bet a 325xi is a pretty badass car in Russia too.
Old 03-01-2011, 11:48 PM   #31
VladV
My Ride: E46 325xi
Sorry for my English )
I tried to explain as I can.
Yes but the inner cv boot was chewed up by arm inner ball joint as I found.
so I asked had anyone the same problem and how solved it.
Old 03-02-2011, 05:58 AM   #32
lotar_6
My Ride: '01 xi, '94 Rado
my only thought is that this shouldn't happen. two things come to mind... the first might be a bad engine mount allowing the engine to sit lower, or for the engine to rock on acceleration or deceleration and get low enough to interfere. the second would be the boot clamp came loose and the boot spun loose and flopped around... catching the ball joint and ripping.
good luck!!
lotar_6 is offline   Reply With Quote
Old 03-02-2011, 07:58 AM   #33
VladV
My Ride: E46 325xi
Thank you for answer.
I think the same that reason of the problem is in bad engine mount.
Old 07-28-2016, 01:56 PM   #34
bmwstephen
My Ride: e46 325XI, e36 M3
Originally Posted by lotar_6 View Post
Thanks for the pic! so what exactly are we looking at here? I can't tell from the pic what it is... I've yet to need to do my axles, but I'm sure I will sometime.
bumping this post. it looks if caught early enough, CV joints can be cleaned and repackaged with grease and the boot
bmwstephen is offline   Reply With Quote
Old 07-29-2016, 07:03 PM   #35
My325XI
My Ride: 03 325XI Sprt Prem
Sure but the cost of the parts plus the labor (if not diy) to rebuild will certainly out weight the cost of having a reman axle or possibly a new GKN axle installed.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 07-31-2016, 01:04 PM   #36
zander271
My Ride: 6spd ZHP/5sp XI
Not if you buy them from FCPeuro lifetime warranty.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
