General Off-Topic
Old 11-22-2011, 08:25 PM   #821
Amoeba
Amoeba's Avatar
My Ride: his: zhp hers: 325ci
Send a message via Yahoo to Amoeba
Oh power!
Amoeba is offline   Reply With Quote
Old 11-22-2011, 09:52 PM   #822
Amoeba
Amoeba's Avatar
Looks like they released a patch yesterday? For PC first... Yay they're fixing the mouse acceleration.
As promised, DICE will be rolling out a big Battlefield 3 patch tonight, and they've released the full change log/fix list, which you can find below:
Visual and performance fixes
* General performance and loading time improvements
* "Black Screen" fix for an issue occurring on some PC Configurations
* Stereo and Rendering Support for Nvidia and AMD Graphics Cards
* Adjusted the "stuttering" encountered on some PC configurations.
* Fixed several Crashes when joining MP and Co-Op sessions
* Fixed multiple problems when using multiple monitors (Eyefinity / Surround).
* Fixed visual corruption issues on certain Nvidia Cards
* Improved loading times for certain textures
* Added console command "GameTime.MaxVariableFps" to limit max FPS
* Added console command "UI.DrawEnable" to hide UI for screenshots / videos
Balance and gameplay adjustments
* Fixed a problem with high speed mouse movement
* Added back some missing Growlers on Kharg Island Conquest Large
* Added back EOR sound for SQDM and TDM
* You should no longer be able to damage a friendly vehicle when sitting in an open position
* Grenades now drop to ground if you get killed while attempting to throw it(note the affect this will have on Hardcore mode!)
* Spawn protection now should work in Conquest. You should no longer spawn on points too close to enemies
* You should no longer spawn too close to enemies in TDM and SQDM
* Combat areas on Kharg Rush tweaked in order to disallow defenders to access the carrier ship after 1st base is taken and being able to enter the AA gun
* Fixed a problem with revived players not suffering suppression
* Fixed a problem with the camera when being revived in COOP
* Added joystick deadzone setting
* Fixed sound for when climbing ladders
* Fixed an issue with some weapon sounds in first person
* Fixed a swim sound loop error
* Increased the damage of Helicopter Miniguns, AA guns, and Jet Cannons against infantry
* Increased the damage of Helicopter Miniguns against jeeps.
* Reduced the physics impact of AA guns and Jet Cannons, players under attack from these weapons should no longer lose control.
* Increased the damage of the 44 Magnum slightly.
* Increased the range and minimum damage of the .357 Round from the MP412 Rex.
* Increased the range of all .45cal and 9mm weapons.
* Slightly increased the range of the P90 and MP7 and PDW-R.
* Slightly increased the range of the 5.56mm PDW-R and decreased the minimum damage at long range.
* Slightly increased the minimum range of the Mk11, SVD, and M39 EMR 7.62mm rifles.
* Decreased the maximum damage and maximum range of the G3 and SCAR-H 7.62mm weapons.
* Reduced the damage from FIM-92 and SA-18 IGLA missiles against aircraft.
* Increased the damage and range of the 40mm BUCK rounds.
* Reduced the damage .50cal weapons do against Helicopters.
* Updated T90 canister shell tweaks to match Abrams canister shells
* UI Changes (PC)
* Added round duration and ticket summary at EOR
* Advanced squad polish - should be more intuitive
* Significant changes to the Join Squad functionality (see below)
* Fixed a problem regarding keybindings while playing
* You should now get a better error message when being disconnected via Battlelog
Server updates
* EOD Bot exploit fix
* Several crash fixes
* Anti-stat padding measures taken, disallowing ranked servers to run obscure settings
* Improved team kill kick configuration
* Support for unranked servers. Unranked servers do not report players' scores to Battlelog, but server administrators can freely control all settings
Squad changes
* Removed FIND ME A SQUAD option
* Allow players to join empty Squads alone, thus having 1/4 squad members
* Change order of options to LEAVE SQUAD, INV A FRIEND, SWITCH TEAM
* Disable Privacy flag when 1 man squad
* Reset Privacy flag from Private to Public when squad drops to 1 player
* All occupied Squads will now show up colored blue on the Squad Selection screen
* Players who choose not to join squads will also show up as Blue in the "Not in a Squad" line
* Squads that are currently empty will display as white - if you wish to join an empty Squad, you can choose the first one marked with white text
The patch will be released on Nov. 22nd 7:00 AM UTC / Nov. 21st 11:00 PM PST. You can find the full patch release note and changes on Battlelog.
Old 11-22-2011, 10:06 PM   #823
Five_seveN
My Ride: rover james
Send a message via AIM to Five_seveN
so im guessing what its downloading now when i open origin is the patch?
Originally Posted by Ballistic325 View Post
Five, your second rocket booster, pop-up umbrella and hip flask have failed.
Five_seveN is offline   Reply With Quote
Old 11-23-2011, 05:09 AM   #824
MTreyM
My Ride: MTrey, E60
Played with some members on ps3 today. GG fellas
MTreyM is offline   Reply With Quote
Old 11-25-2011, 02:09 AM   #825
ruan916
My Ride: 2002 325i
The patch did more harm than good. I have more crashes/black screens now when switching maps... wtf!!!
ruan916 is offline   Reply With Quote
Old 11-26-2011, 06:29 PM   #826
kuksul08
My Ride: M3
Send a message via AIM to kuksul08
Where's the best place to buy bf3 for PC? Amazon is $40 right now, was $30 yesterday apparently.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
kuksul08 is offline   Reply With Quote
Old 11-27-2011, 12:42 PM   #827
Marcb2g
My Ride: E46///M3
I never catch you guys on, this is one of my better matches of rush.
FH2002 is pretty good gun, under rated.
ID:	426745   Click image for larger version
Marcb2g is offline   Reply With Quote
Old 11-28-2011, 08:10 AM   #828
Saviorself
My Ride: 2005 330 CI
Send a message via AIM to Saviorself
Saviorself is online now   Reply With Quote
Old 11-28-2011, 08:13 AM   #829
joeski3d
My Ride: 2000 323i
Ballbusters Inc.
DISCLAIMER: No balls were physically hurt during the reading of this post. Should redness and/or swelling occur consult your gynecologist immediately.
joeski3d is offline   Reply With Quote
Old 11-28-2011, 04:07 PM   #830
Five_seveN
got most of the big games this year including bf3, mw3, skyrim etc and i must say, the presentation of bf3 is on a whole other level. the visuals and audio just blows everything away. i think dice really set a new standard here
Old 11-28-2011, 04:24 PM   #831
s3th
s3th's Avatar
My Ride: 325xi
Oman is gunna be sick! Can't wait for karkand too!
s3th is offline   Reply With Quote
Old 11-28-2011, 04:27 PM   #832
r2d2
My Ride: 330i
i cant fly jets worth shishkabobs. i dont know how people do the dogfights. flying choppers is hard enough.
robert
r2d2 is offline   Reply With Quote
Old 11-28-2011, 04:54 PM   #833
oAllElseFailo
My Ride: 328Ci
^ i know for PC a lot of guys have joysticks next to them for when they do get a jet.
oAllElseFailo is offline   Reply With Quote
Old 11-28-2011, 06:02 PM   #834
s3th
s3th's Avatar
My Ride: 325xi
Thats what I did on bf2 on the pc. I had a pretty sweet joystick set up. Up for sale if anyone wants it haha!
Old 11-28-2011, 07:30 PM   #835
Saviorself
I hear ya on that one! I cant fly a chopper or plane for sh!t. Wish there was a toturial or practice mode to get the hang of it.
But on the other hand I have been getting pretty good with the tanks and IFVs!
Old 11-28-2011, 09:03 PM   #836
charz1130
is your best friend
My Ride: M-AZING e90
Send a message via AIM to charz1130
bf3 for $30 including shipping just in case anyone wants to hop on it! just got mine!
http://srz3.com/srzwp/cyber-monday-s...d-3-for-29-99/
charz1130 is offline   Reply With Quote
Old 11-28-2011, 09:24 PM   #837
HPFMTRE
My Ride: HPF stage 3 M3
Originally Posted by Saviorself View Post
Goosebumps! I cant wait!
Photobucket
Pictures of my car
http://www.cardomain.com/ride/2927228
Originally Posted by BeRzErKaS View Post
wat?? guys with turbo M3's don't have woman troubles...
try adjusting your wastegate
HPF Stage 3 #001
R35 GTR coming soon ;)
HPFMTRE is offline   Reply With Quote
Old 11-28-2011, 10:14 PM   #838
Marcb2g
My Ride: E46///M3
They need to fix this F'ing game, I get to the end of a 9,000+ point game to the point add up screen and it freezes wtf!!!!
Old 11-28-2011, 10:44 PM   #839
s3th
s3th's Avatar
My Ride: 325xi
How is the skill computed on the stats page?
Old 11-29-2011, 05:09 PM   #840
MTreyM
My Ride: MTrey, E60
Practice makes perfect man. I used to say the same thing, but I got a few kills got the missiles, etc and got a hang on the controls. Im all the way up to the rocket pods. Dog fighting is the best way to get a kill because the gun is so strong and people easily get away from missiles using the flares (if they know how to use it)
I wanted to ask, what is everyones fav gun to use? I keep cycling through the M4A1, AE91, M416. I have the G326C or whatever its called but dont really like it and am waiting to unlock the F2000
Rate This Thread
