Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 34 votes, 5.00 average. Display Modes
Old 07-12-2011, 11:18 PM   #41
CrazyOneToo
My Ride: 1999 328i 4dr
Originally Posted by 330ciandr6 View Post
You sir are an idiot. If you read the thread in my sig do I say anything about taking it to the dealer? I say get the car scanned and diagnose it properly so you aren't wasting time and throwing parts at it. Do you have any idea how many different codes/parts can go wrong with the abs/dsc system? Obviously not. Sorry I've only been working in the auto industry as a tech/advisor/parts for 9 years, 6 of which are BMW so maybe I don't have your level of knowledge. I have helped people on this forum damn near more than anyone else on here and most people will vouch for that so you might want to do your research before you type.
Oh OK.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 07-17-2011, 06:18 AM   #42
damir.kovacic
My Ride: 330d e46
Hay everyone, I have also problem with aBS/asc and brake lamp. They are turned on. Im first they go on 2-4 times and then off. Again on again off. I went to diagnostic and diagnostic shows rear left senzor.I buy new senzor originaly to my car number(163***8364. But the lamps are still on and speed meter now also not working. Speed meter was already stop working when they take down the senzor.One person who is expert for this things, he works just electronics for cars said that this senzor is wrong. Is that posible, I bought this originaly senzor exactly to my car number. Realy dont know what to do!Help My car is 330d (year production 17.11.2000). Thanks
damir.kovacic is offline   Reply With Quote
Old 08-11-2011, 03:22 AM   #43
trebbia
My Ride: E46
This is a good starting point.
trebbia is offline   Reply With Quote
Old 08-11-2011, 07:54 AM   #44
orient325ci
My Ride: Silver 325ci
Mobile phone/ DSC light
The DSC light came on the moment I made a call on my mobile as I was driving along. Can the phone transmission interfere with the DSC electronics? The car has had 2 new OEM rear sensors less than 6 months ago.
orient325ci is offline   Reply With Quote
Old 08-11-2011, 08:29 AM   #45
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
No.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 08-11-2011, 09:00 AM   #46
killj0y
My Ride: 2000 323i
Your joking right? Btw your phone might give you cancer, cause your car to blow up while gassing up, and make a plane crash if you use it....
killj0y is offline   Reply With Quote
Old 08-11-2011, 12:44 PM   #47
LivesNearCostco
My Ride: 2003 ZHP 6MT
If you take one of the wheel speed sensor wires and plug it into the phone, maybe. The ABS/DSC will compare the speed of 3 wheels to how quickly you're talking or texting on the phone and then decide if it should kick it to redirect your conversation.
LivesNearCostco is offline   Reply With Quote
Old 09-16-2011, 04:04 PM   #48
damir.kovacic
My Ride: 330d e46
My rear left abs senzor is stop working.that show the diagnose. I have read the number from it 10.0751-1183.3. Can enyone tell mi catalog number for this senzor?
Old 05-01-2012, 04:44 AM   #49
darrenkellum
My Ride: 1999 BMW E46 318 CI
Hi Guys,
I seem to have this issue at the moment with the 3 lights on the dash and some ABS issues.
Currently I also have a knock/clonk which happens (drivers side front wheel) when I brake. I think that is a bush thats gone.
Anyway, I also seem to sometimes have my ABS come on (hear the grinding) when Im braking at quite a low speed.
Im wondering whether the bush being gone might be affecting the ABS? Or whether from experience people would just say, its also your ABS sensors?
Any previous experience with the same symptoms whould be great.
thanks
Darren
darrenkellum is offline   Reply With Quote
Old 05-01-2012, 05:30 AM   #50
damir.kovacic
My Ride: 330d e46
I solved problem with ASC/ABS. It was ABS sensor. In your place i would try switch the sensor.
Old 05-01-2012, 02:25 PM   #51
ptrcd003
My Ride: .
How could water possibly get into the sensor and "ruin it"? Its a sealed plastic piece, and all there is inside is a coil. Also, the sensors are a pain to get out and usually break in the process. Modules are the most common things that go bad, especially in older E46s.
ptrcd003 is offline   Reply With Quote
Old 05-01-2012, 02:53 PM   #52
MJLavelle
My Ride: 2001 BMW 330ci
OMFG thank you!!!!! Finally someone smart.
OP and everyone else, please read this damn thread here:
I was going to post the same thread. It also points out that cleaning the sensor won't do a damn thing, but people continue to post that crap on here.
Old 05-01-2012, 03:01 PM   #53
330ciandr6
My Ride: .
Old 06-10-2012, 09:21 PM   #54
Dippinwandy
My Ride: 325i
I have these lights on too.
Dippinwandy is offline   Reply With Quote
Old 06-10-2012, 09:26 PM   #55
BMWE46330i
My Ride: BMW E46 330i
I had the same problem on my e46 ( DSC+ brake light "ON") , it was because the brake fluid was low, just add more brake fluid and the lights shut off in my cluster ... yeahhh
BMWE46330i is offline   Reply With Quote
Old 08-03-2013, 10:58 AM   #56
orthotist
My Ride: 2002 M3, Infiniti FX
abs dsc brale lights on
I had mine up on all fours with jack stands changing he starter and fuel filter. Once I test started it the lights were on and I did rotate the tires at some point when I was under it and it was up in the air (330xi). Once it was back on the ground and I backed out of the driveway, all the lights went off and everything was back in order. My guess is that the wheel speed sensors were misaligned and need to sync with all four wheels at the same time. (no codes came up on my code reader when I ran that test).
Hope this helps someone!
orthotist is offline   Reply With Quote
Old 08-03-2013, 11:29 AM   #57
Mr Podman
My Ride: E46 Coupe
I had the same kind of issue a 3 years ago. Paid $62.50 to have the local BMW dealership diagnose which sensor it was (in my case, right side, rear).
They quoted $300 to replace. I did nothing, expecting to replace it myself, however the problem never resurfaced after the diagnosis, presumably because they cleaned it up a little.
No problems since, for three years.
Mr Podman is offline   Reply With Quote
Old 08-05-2013, 07:28 PM   #58
Joan Lynn
My Ride: 2000 323i
I found out today that the left rear speed sensor is the one that drives the speedometer so if your getting intermittent speedo readings your sensor is bad. It also serves as the master speed sensor for the ABS/DSC system which the other three wheel sensors compare their signal outputs to.
Joan Lynn is offline   Reply With Quote
Old 08-05-2013, 07:49 PM   #59
Hollywood516
My Ride: 02 330i
I just had this problem, mine was from front driver side caliper gone bad. Heated everything up and fried wheel sensor.
Hollywood516 is offline   Reply With Quote
Old 04-14-2014, 08:53 PM   #60
Danedansker
My Ride: 02 e46 325i
Hi all I had this issue after doing some work, forgot to connect that plug on the top of the brake fluid reservoir. Lights off after that.
Danedansker is offline   Reply With Quote
abs, battery, brake, dsc, red
