Old 02-24-2011, 10:07 PM   #1
bnigam
My Ride: 2002 M3
7 or 8 quarts of oil
Does a 2002 325xi require an extra quart of oil and why? I went to the BMW dealer and they said it only needs 7 quarts for 6.5 liter capacity. Everywhere I look online it says get 8 for 7.5 liter capacity.
bnigam is offline   Reply With Quote
Old 02-24-2011, 10:33 PM   #2
N89
My Ride: 330Ci
Neither; 6.9.
N89 is offline   Reply With Quote
Old 02-24-2011, 10:54 PM   #3
bmwguyNC
My Ride: 02 325i/06 330i e90
Send a message via AIM to bmwguyNC
The XI does require an extra quart of oil. It is 8 for 7.9. Whatever BMW dealer told you that, never ever let them service your car!! I used to own an 02 325XI.
http://www.trademotion.com/partlocat...egoryID=103121
bmwguyNC is offline   Reply With Quote
Old 02-24-2011, 10:57 PM   #4
brandonwish
My Ride: 02 325i 5MT
I have a 2004 330xi and mine took 7 quarts last oil change
|||2002 325i 5MT|||
brandonwish is offline   Reply With Quote
Old 02-24-2011, 11:01 PM   #5
bmwguyNC
Originally Posted by N89 View Post
Neither; 6.9.
The XI'S Have a deeper oil pan due to the fact they are all wheel drive and the front axles are there. Enter your last seven of your vin this will tell you.
http://www.bmw-z1.com/VIN/VINdecode-e.cgi
I think some of you XI guys are running a quart low!
Old 02-24-2011, 11:03 PM   #6
My325XI
My Ride: 03 325XI Sprt Prem
Mine took only 7qt last change as well.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 02-24-2011, 11:08 PM   #7
Blocked Out
My Ride: Imola 330i M-Sport
quarts (liters):
320i, 325i, 330i:
approx. 6.9 (approx. 6.5)
325xi, 330xi:
approx. 7.9 (approx. 7.5)
^^^^ straight out of the owners manual.
Why? Much larger oil pan that accommodates for the axles that pass thought it.
Please download a copy of an owners manual, if you cant afford to buy one and stop asking dealers.
http://www.linquist.net/motorsports/bmw/3manuals
Original BMW Teile ///
IMG_1725
Old 02-24-2011, 11:17 PM   #8
bmwguyNC
Originally Posted by Blocked Out View Post
quarts (liters):
320i, 325i, 330i:
325xi, 330xi:
Well said Blocked Out . Now all you XI'ers here better run on out and get another quart of oil!! You are running a quart low guys!
Old 02-24-2011, 11:19 PM   #9
brandonwish
Go ahead and put 8 quarts in. Then think of me when you're draining that extra quart out after checking the dipstick
|||2002 325i 5MT|||
Old 02-24-2011, 11:23 PM   #10
bmwguyNC
Did you have to do that? Drain out the extra quart! Or did you never try to put 7.5 quarts in the first place!
Old 02-24-2011, 11:29 PM   #11
Penguin Koolaid
Banned
My Ride: Inline Six
Learned something new.
Penguin Koolaid is offline   Reply With Quote
Old 02-24-2011, 11:30 PM   #12
Blocked Out
How do you know that you actually drained all the oil out?
Did you measure it after you drained?
If not, then you're simply assuming that you did.
If the manual says Xi holds 7.9 quarts (7.5 liter) then it must be true.
IMG_1725
Old 02-24-2011, 11:33 PM   #13
djnekkon
My Ride: MB3ci & z33 HR
Lol
Old 02-24-2011, 11:38 PM   #14
brandonwish
This is based on the assumption that OP will be draining his oil out of the drain plug. It is virtually impossibly to drain *all* the oil from the drain plug and there will always be .5 to .75 quarts still floating around in there somewhere. Of course the manual states the engine holds 7.9 quarts but assuming OP uses the drain plug, IMO, I would count on the engine retaining a half a quart and and filling with 7 quarts therefore final amount would be around 7.5 quarts
edit: Also assuming OP is asking his question with the intention of doing an oil change
|||2002 325i 5MT|||
Old 02-24-2011, 11:59 PM   #15
bmwguyNC
And where would that engine hide .75 quarts. You have the filter out and the oil plug is located at the bottom of the pan.
Old 02-25-2011, 12:11 AM   #16
brandonwish
Crankcase. Only way I've heard to get it out is by using an extractor
|||2002 325i 5MT|||
Old 02-25-2011, 12:50 AM   #17
bmwguyNC
crankcase. Only way i've heard to get it out is by using an extractor
omg
Old 02-25-2011, 09:45 AM   #18
brandonwish
omg
Care to elaborate?
|||2002 325i 5MT|||
Old 02-25-2011, 10:30 AM   #19
jgold47
My Ride: 2004 X5 3.0
annnnddddd Here we go again. This has been beaten ad nauseam. 04-05 xi's call for 6.9. 01-03 call for 7.X. Best bet. Fill it, check the level. Add as necessary. I dont know if they changed the oil pan or not, but my manual clearly states a lower numer than the older ones. Search for the other threads arguing about what the correct oil level is.....
edit.....
So I did some checking and a 2002 and 2004 have the same part number for the oil pan. the mystery deepens. I have only changed my oil once since I bought the car, and I believe I dumped in 7 quarts, measured it and called it a day. When i do my oil in the spring, I will do the fill and check method and see what I come up with.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 02-25-2011, 10:59 AM   #20
bnigam
My Ride: 2002 M3
Funny! I asked two different people in the service dept and they told me 7qts. I looked up the manual and online and it clearly states 8qts.
This is the PREMIER BMW dealership in our area. LOL
