Old 02-25-2011, 11:17 AM   #21
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
7.9 on all xi. Just did an oil change the other week and the level was correct with 7.9
Drew@Swift Motorworks is offline   Reply With Quote
Old 02-25-2011, 11:18 AM   #22
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by bnigam View Post
Does a 2002 325xi require an extra quart of oil and why? I went to the BMW dealer and they said it only needs 7 quarts for 6.5 liter capacity. Everywhere I look online it says get 8 for 7.5 liter capacity.
Seven.
OOPS.
The Xi takes 8 quarts. Sorry for my confusion.
Old 02-25-2011, 01:45 PM   #23
Kubica
My Ride: 2003 325xi
I just changed the oil in my xi- took 7 quarts exactly, but I only had the front wheels on ramps. If I lift the whole car, I need to put in about 7.5 quarts.
Old 02-25-2011, 01:49 PM   #24
bmwguyNC
My Ride: 02 325i/06 330i e90
Send a message via AIM to bmwguyNC
Originally Posted by brandonwish View Post
Care to elaborate?
I really should not elaborate! But next time you change your oil get 2 solo cups the same size, as your oil drains out please catch a cup full. Then hold empty solo cup under drain and pour full cup back into car. Please let me know if you only get 1/4 of a cup as it flows back out. U know retaining .75 of a quart! Because I am now really curious!
bmwguyNC is offline   Reply With Quote
Old 02-25-2011, 02:25 PM   #25
N95
My Ride: 330i
8 Quarts or 7.5 Liters
N95 is offline   Reply With Quote
Old 02-25-2011, 06:24 PM   #26
brandonwish
My Ride: 02 325i 5MT
Just stating the facts. I still don't think you understand the concept but I've given up. Do some research
|||2002 325i 5MT|||
brandonwish is offline   Reply With Quote
Old 03-01-2011, 01:56 PM   #27
GCoop
My Ride: '04 325xi
Well said Blocked Out . Now all you XI'ers here better run on out and get another quart of oil!! You are running a quart low guys!
The XI'S Have a deeper oil pan due to the fact they are all wheel drive and the front axles are there. Enter your last seven of your vin this will tell you.
http://www.bmw-z1.com/VIN/VINdecode-e.cgi
I think some of you XI guys are running a quart low!
The XI does require an extra quart of oil. It is 8 for 7.9. Whatever BMW dealer told you that, never ever let them service your car!! I used to own an 02 325XI.
http://www.trademotion.com/partlocat...egoryID=103121
Not all XIs
Here is mine. Which clearly states 6.6 qt capacity. Go figure
6.6 will put me at the mid point on the stick. 7.0 takes it right to the upper mark on mine. There are MANY theories as to why the various figures--from differing oil pans on some to different dip sticks. There have been no solid confirmations as to why from what I have been able to gather.
GCoop is offline   Reply With Quote
Old 03-01-2011, 02:27 PM   #28
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We take all the guess work out with all Inspection I service kits...
This oil change kit has been assembled to include all the quality parts you need for your next oil service. Quality, factory correct oil, filter, and an drain plug will all work in harmony to keep those harmful contaminants from circulating through your engine. A complete kit to make your next service easier.
* BMW High Performance Synthetic Oil ( 8 Quarts)
* Oil Filter Kit
* Drain Plug with Crush Washer
Best,
Joe
Old 03-01-2011, 02:37 PM   #29
Nervous
My Ride: 01 330CI 6MT ZSP EU3
My 330ci was draining oil for a couple of weeks (since I was doing some repairs, such as oil filter housing gasket, CVV and VANOS). After I am done I put 8 qts of oil in it and only after this I reached proper level of oil (measured 5 min after warmed engine is off).
Nervous is offline   Reply With Quote
Old 03-01-2011, 04:31 PM   #30
Kubica
My Ride: 2003 325xi
Originally Posted by GCoop View Post
Not all XIs
Whoa that's weird. Where did you get that image exactly?
Old 03-02-2011, 11:58 AM   #31
GCoop
My Ride: '04 325xi
Right from BMWs site
BMW Electronic Owners Manual
2004 325xi
Page 163
Oddly enough the 2005 325xiT online manual lists the capacity as 7.9
Note also -- The 2005 sedan manuals listed on BMW site are actually E90 manuals
For reference my Pan looks exactly like this one.
I have seen other designs as well like this one from an'01 330xi -- Note the width, I suspect this is the 7.9 Capacity pan
Old 03-02-2011, 12:04 PM   #32
Kubica
My Ride: 2003 325xi
2004 325xi
Page 163
The 2005 sedan manuals are actually E90 manuals
Yeah that's definitely a typo . . . .looks like they switch xi and non-xi capacities.
Either way, you're going to fill using the dipstick as a guide- not some .pdf.
Old 09-01-2011, 11:33 AM   #33
miyata
My Ride: 2005 330 XI
My paper manual indicates same capacities as GCoop's. I just completed my FIRST oil change and input 7.5 quarts oil. The oil level is a little above the MAX line. I have been confusing a lots yesterday because Tischer sent the kit with 8 quarts oil (for XI).
I have 2002 330XI.
miyata is offline   Reply With Quote
