Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 01-04-2009, 11:34 PM   #41
xnluswimr
My Ride: 1999 328i
i'm guessing it's this one?
16 CLAMP 2 01/1999 51124015053 $1.53
xnluswimr is offline   Reply With Quote
Old 01-05-2009, 02:12 AM   #42
donb
My Ride: 01 325i
Send a message via AIM to donb Send a message via Yahoo to donb
that's it dude. my car has the same clip. i did not have to replace mine. i had my rear bumper painted and all i did was push the clip out when i removed the bumper, pushed it back in place. then when can time to put the bumper back on after painting, it just clicked right in place. so you might be able to bend your clip back into shape if it's not [too] damaged. just pray that you don't have a problem with your bumper instead.
donb is offline   Reply With Quote
Old 04-06-2010, 10:11 AM   #43
McIver
My Ride: BMW 320d touring -03
up
McIver is offline   Reply With Quote
Old 05-03-2010, 02:34 PM   #44
l8apex10
My Ride: E90 M3
Anyone have more recent experience or photos of the bumper and mounting points - particularly the area right at the rear wheel well opening? Trying to get a sense of what the pieces should look like for an M tech II facelift bumper....
Thanks in advance
l8apex10 is offline   Reply With Quote
Old 09-06-2014, 05:32 AM   #45
sectrik
My Ride: BMW 318ci
Trying to get my 04 coupe rear bumper out. I figured I need t50 torx (I bought a set a year ago which has up to t40 ) I'm clear from the sides and know about the lower torx.
&, did somebody mention nuts in the luggage compartment on a facelift?
Oh and I did remove the plastic trim, no access for the torx from there. I can only undo these from under the car.
Cheers folks
sectrik is offline   Reply With Quote
Old 09-06-2014, 01:20 PM   #46
donb
My Ride: 01 325i
Cheers folks
Are you trying to remove the bumper or the bumper cover?
I had to buy a t50 torx also but it was for the cover removal, not the bumper.
Old 09-06-2014, 03:18 PM   #47
duss46
My Ride: BMW 320Cd
There you go:
duss46 is offline   Reply With Quote
Old 09-07-2014, 02:02 AM   #48
sectrik
My Ride: BMW 318ci
The painted part actually.
Old 09-07-2014, 02:32 AM   #49
sectrik
My Ride: BMW 318ci
Thanks for the vid @duss46
Old 10-28-2014, 06:09 AM   #50
John949
My Ride: E330 CI
Sorry to come to this thread late, but I'm about to take mine off and mine's like the 'after' picture iof the MTec sport rear. I think a lot of the confusion is because there are quite a few variations in bumpers/ models / years, but one thing I worked out is that there is a choice:
You can EITHER take out the two vertical T50 bolts at the outboard end of the shock OR remove the 6 nuts inside the boot (trunk if you must!) and the shocks will come away with the bumper. The latter sounds a bit more work but a lot easier.
John949 is offline   Reply With Quote
Old 10-28-2014, 05:04 PM   #51
sectrik
My Ride: BMW 318ci
Sounds like my option since I have both t50's nuts cut off from welding..
Old 10-29-2014, 03:45 PM   #52
sectrik
My Ride: BMW 318ci
Can you point out on how and where can i find these 6 nits from the trunk please? what should i remove to find them?
cheers in advance!
Old 10-30-2014, 04:03 PM   #53
duss46
My Ride: BMW 320Cd
cheers in advance!
These are covered with 1-1 plastic cover. Lift up the trunk carpet, remove the 2 trays right and left side, and you should see them there.
Cheers
Old 10-30-2014, 04:53 PM   #54
sectrik
My Ride: BMW 318ci
Cheers mate! will see to this as i get my 46 from the garage!
Old 11-08-2014, 01:01 PM   #55
sectrik
My Ride: BMW 318ci
Are these the 6 bolts you guys mentioned earlier? because I slackened them and the bumper didn't even budge...
ID:	580175   Click image for larger version
Old 12-06-2014, 07:30 PM   #56
KTulay
My Ride: SE46
I only glanced through this thread, as I can here from a Google image search for something else, and found it odd there was a 3 page thread to remove the bumper lol. But, there are 2 ways to the remove the bumper. You can take just the bumper and cover, or you can take the shocks, bumper and cover. If you want to leave the shocks in you need to access the two larger torx bolts from below, and the shocks will stay on the car. If you want to remove the shocks with the bumper, you take the nuts off that you are showing in your picture. Make sure the bumper is loose from the clips near the wheel wells, and make sure all of the splash guards are loose. Then, it might still take a little bit of a yank to get the shocks to come loose and it will come right out.
KTulay is offline   Reply With Quote
