Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 107 votes, 5.00 average. Display Modes
Old 04-07-2013, 06:10 AM   #21
Kirux0
My Ride: BMW E46 330i
Here are the settings in NERO (I used version 12) to burn CD's in order to play them in these radio's:
Sorry for that russian language in screenshots, the first screen is "No multisession", the others are understandable I guess.
Kirux0 is offline   Reply With Quote
Old 05-04-2013, 09:34 PM   #22
mattman928
My Ride: e46 M3
I tried to build the aux and input cable into the CD changer input, but no success. To tie into the input for the CD changer, I spliced into the cd changer harness wire that goes to the trunk, and used the cap/res (2x 0.22uF capacitors and 1x 300k Ohms resistor) to trick the unit into believe there is an input, but when I press the MODE button (I have an alpine unit s/n ending in 072), but had no success (got the "No CD" message, which I think is from the internal player not the changer).
Any thoughts? I've tried this wiring setup a couple of times with no success.
mattman928 is offline   Reply With Quote
Old 05-12-2013, 06:43 PM   #23
scottjoh
My Ride: '99 323i & '02 540i
Pictorial Guide to buying BMW Business CD53 Alpine Radios that play MP3 Data CD
That won't work! The HU needs to be able to communicate with the CD changer over the K-bus. It does not sense the CD changer by a resistance between the two inputs like the Aux input does. If you had a CD changer and left the digital lines connected and tapped into the analog signal lines this would work (resistor would not be necessary).
scottjoh is offline   Reply With Quote
Old 05-29-2013, 02:54 PM   #24
VertE46
My Ride: 325Cic
CD53 backlight brightness
When replacing a Blaupunkt with an Alpine CD53, is there an issue with the backlight brightness? I'm trying a second Alpine P/N 65. 12-6 927 902 on my '01 325Cic, thinking the first backlight was a dud, but both displays are about half as bright as the Blaupunkt was. It looks just like this first photo in another post, which appears to be a night shot with the buttons lit up:
http://www.e46fanatics.com/forum/sho...91&postcount=1
That's when it looks the best, but in the daytime with the top down the display is washed out. At night the radio display is as bright as the buttons so not bad, but does not "pop" like the climate control brightness. Does anyone know if there is something different in the Alpine headunit wire harness regarding the backlight? I noticed that the display looks brighter when looking down at it and dimmer when looking up, for whatever that's worth.
'01 325Cic w/ hardtop
'92 K75S/A
VertE46 is offline   Reply With Quote
Old 03-14-2014, 11:48 AM   #25
16vCorey
My Ride: '99 323i & '90 325i
FYI, my part # 65. 12-6 921 963 made Dec. of 02 has Aux., as does this guy's (http://forum.e46fanatics.com/showthread.php?t=1021258) that was built in July of '02. Also, my part # 65. 12-6 961 214 has aux and will play MP3 data discs.
16vCorey is offline   Reply With Quote
Old 04-30-2014, 08:40 PM   #26
ukohohs
My Ride: 2001 bmw 325ci
any one know if this unit Part #: 65.12-6 941 505 (01.2004) is compatible with my 2001 325ci ? i currently have the head unit with the CD button no MODE button.
p.s how do you find out if you have cd changer prewired?
thanks in advance !
ukohohs is offline   Reply With Quote
Old 05-01-2014, 03:58 PM   #27
ukohohs
does this mean unit with this part number does not support AUX fuction?
Alpine, Model CD53, Part Number 65. 12-6 921 963 (July 2002-Jan 2003)
Old 01-31-2015, 03:13 PM   #28
cxoakes
My Ride: 2002 330ci vert
My Alpine, Model CD53, Part Number 65. 12-6 919 072 ,plays MP3 data CD's.
cxoakes is offline   Reply With Quote
Old 02-01-2015, 09:46 AM   #29
16vCorey
That's what the OP said, but mine did. So maybe some do and some don't? Try it and see.
Old 07-19-2015, 03:17 PM   #30
d325xi
My Ride: 2002 BMW 325xi
I have the same unit but nothing is working
I have the same model cd53 P / no. 65.2 12-6 961 215 unit made April of 2006. I had bought the auxiliary input retrofit kit and no success just trying to use the auxiliary input. But my dad cut off the transistors at the end of the auxiliary input ( part that plugs into back of stereo) and straight wired it and it worked for a while. Then it just stopped working. So I bought another retrofit kit from ecs Tuning and it won't work. I only have FM AM and CD working. I'm wondering if there's some kind of reset I have to do to make it all work again, my car is a 2002 325 X I w/o Harmon Kardon but the head unit , I'm pretty sure is, truly a P / N0. 65.12 - 6 961 215 from April 2006 it matched all the pictures that you put and the sticker doesn't seem to be tampered with at all. To top it off when I did the region reset it said 14 06 referring to the week and date, I'm pretty sure.
d325xi is offline   Reply With Quote
Old 07-27-2015, 05:27 PM   #31
sroberts
My Ride: 2000 323ci
I also recently installed a 65.12-6 961 215 in my 2000 323ci and added an AUX which I wired directly. I used my phone to test the AUX input, and it worked great, until I plugged the phone into the charger and the AUX disconnected.
I do not know if your AUX "retrofit kit" has (had) it built-in, but you likely only need a ground loop isolator. I bought one on eBay for $7 shipped and there's enough room behind the radio to place it.
Steve
sroberts is offline   Reply With Quote
Old 07-28-2015, 09:45 AM   #32
16vCorey
I tried a cheap-o ebay ground loop isolator, and it's didn't work. I'm going to try to wire up like the factory harness and see if that works.
Old 01-16-2017, 06:56 AM   #33
Speeddragon
My Ride: e36 316 coupé
BMW Business CD53 Units manufactured and dispatched for the USA E46 cars from 1998 to 2007 with their respective Part Number, Production Period, and what each unit is capable of :
1998 to 2001 E46 3 Series vehicles
Blaupunkt, Part Number 6512-6 909 883 iPod Data Capable
Blaupunkt, Part Number 6512-6 909 882 iPod Data Capable
Blaupunkt, Part Number 6512-6 902 661 iPod Data Capable
NOTE: iPod Data Capable is ONLY if the car is Prewired in the trunk for the CD Changer - You can also add Aux Input ONLY thru an iPod Data Kit like the USA Spec PA12 or the DICE iPod kits
2001 to 2007 E46 3 Series vehicles including the E46 M3
Alpine, Model CD53, Part Number 65. 12-6 916 241 (July 2001) iPod Data Capable
Alpine, Model CD53, Part Number 65. 12-6 915 711 (Sep 2001) Ipod Data Capable
Alpine, Model CD53, Part Number 65. 12-6 919 072 (Dec 2001-Jun 2002)iPod Data, Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 921 963 (July 2002-Jan 2003)iPod Data, Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 927 902 (Feb 2003-Aug 2003)iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 10-6 927 903 (RMFD thru Dec 2006) iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 941 505 (Jan 2004 - Sept 2004) iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 941 506 (RMFD thru Dec 2007) iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 943 429 (Oct 2004 -Sept 2005) iPod Data, Aux, Sirius and MP3 Capable
Alpine, Model CD53, Part Number 65. 12-6 943 430 (RMFD thru 2008) iPod Data, Aux, Sirius and MP3 Capable
Alpine, Model CD53, Part Number 65. 12-6 961 215 (Dec 2005-May 2006) iPod Data, Aux, Sirius and MP3 Capable
Does this note:
only apply the 1998-2001 radio's or do you need that kits also for the newer ones?
Speeddragon is online now   Reply With Quote
