The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 03-24-2011, 04:08 PM   #41
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Send a message via AIM to 2000_328CI Send a message via MSN to 2000_328CI
Duh winning
Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244
Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM
Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI
Old 03-24-2011, 04:14 PM   #42
RXP rider
My Ride: E46 325Ci 04'
Duh winning
Still winning...haha
nice build, mine keeps me plenty busy. Engine/Maint before appearance!
RXP rider is offline   Reply With Quote
Old 03-29-2011, 12:35 AM   #43
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
Bought some more stuff. Can't wait to get it back in a month or two. Friend is going to be driving around for awhile until I can get it home to MS
Old 05-30-2011, 09:23 PM   #44
TrippinBimmer
Finally, a Update
Here is me taking off the Spark Plug Wires and etc...
Took off the Hood and Valve Cover. The bolts for the Cover was barely hand tighten. One big reason it was leaking oil...
Rusted Coolant Water Can see the owner used tap water and barely any coolant...
The Coolant Hoses is full of Rust
Took out the Radiator and Most of the Coolant Hoses.
Removed the Front Clip
Only to Find out I need a New Front Radiator Support
Removed the Vacuum Lines and TB.
Look at the Stat Housing. It's Falling Apart.
Unbolting the Headers.
Parts neatly put on the side.
About to remove the Timing Belt.
THE HEAD IS OUT!
Stay Tune for More Pics
Old 05-30-2011, 10:57 PM   #45
mvrk10256
My Ride: E30 325i
damn this looks familiar. Great progress
Old 07-14-2011, 09:23 PM   #46
Jmanscotch
My Ride: Hairdressers car
Updates?
-Jake
Jmanscotch is offline   Reply With Quote
Old 07-14-2011, 10:35 PM   #47
cd330
ModZombie Moderator
cd330's Avatar
My Ride: manual stl gry 330i
Animated Gifs
cd330 is offline   Reply With Quote
Old 07-14-2011, 10:45 PM   #48
TrippinBimmer
Originally Posted by Jmanscotch View Post
Updates?
There is but had to take it all apart again.
Here is where I took the Water Pump off and Timing Belt.
Got the Main Crank Timing Belt Pulley Off.
Clean the Exhaust Side of the Engine Block and the Piston.
Lifting the Engine for New Motor Mounts
Comparing the New and Old Motor Mounts
Driver Side Motor Mount is Trashed
Oil Pan Removed to Check out the Bottom End and Clean out the Grim.
Hello Oil Pump
Fresh Rebuild 885 Head (Found out Later its a SETA Head)
New Thermostat Housing and Stat
Installed the New Thermostat Housing and Rear Water Outlet
Skipped alot of Process and Slapped the Head on. Will redo on the Next Update with the Rebuild SETA with I Cam.
Installed Spark Plug Wires, Plugs, Oil Cap, and etc.
Installed new Timing Belt, Cover and Pulleys.
Almost Done
So then I decided to Fire it UP! Sounds SO MEAN!
So after that. I start filling up the radiator and getting it ready to bleed. Then I start it up to start the process and I got this
Came to found out that the Spray Bar was Clogged and Lash was done incorrectly During that time. I found out that the 855 head I have is not an I head but a SETA as it had a 4 Cam Bearing Cam. Below you can see there is only 4 oil passage.
After taking the Head apart. I inspected the cam and saw this.
I am picking up the head tomorrow after the mods that has been done 7 oil passage for 7 cam bearings. I will be installing the new I Cam, Rockers and Rod.
Old 08-29-2011, 04:23 PM   #49
sgplayer69
My Ride: 2003 CB M3 Coupe
nice build! not skipping steps in for updates
Coming Soon...?
sgplayer69 is offline   Reply With Quote
Old 09-29-2011, 06:30 PM   #50
TrippinBimmer
Here is the other "885" head that I have been having issues with but ordered new valves for it and getting it rechecked.
Here it is Disassembled
Underside of it. Can see a few Carbon/Miss Firing Deposit on the Head.
Cycl 1
Cycl 2
Cycl 3
Cycl 4
Cycl 5
Cycl 6
Here is my Original "885" that came off the SETA motor. Got it clean, new seals, valve seat cut and etc.
I readj the lash and made sure its proper. So I wont have a bent Valve and what not...
Skipping all the parts cause its the same stuff...
So now its Alive and Runs very well and pulls so hard. I am planning on getting it tune this Thanksgiving when I visit Dallas. So now that it is running I moved into the interior side.
Here is my interior before...
First thing I decided is to remove the seats and to dye the carpet Charcoal.
So it look great and I finish the rest and took out the Cracked Dash.
So I reinstalled the Dash with a crack free one Look so much better and also install my old Alpine HU.
Bought some Mint e30 Sport vinyl seats from a Coupe.
Then I installed my Mint Black vinyl door cards and the Passenger Seat
That is all for now as my funds are super low now :/ and my b_day is around the corner
-TrippinBimmer
Old 10-03-2011, 10:19 PM   #51
Dskinn91
My Ride: 04 330i Zhp
^ looks good man!!
interior looks great.
Dskinn91 is offline   Reply With Quote
Old 10-03-2011, 10:27 PM   #52
djnekkon
My Ride: MB3ci Regensburg Bav
love this thread..
Old 10-03-2011, 10:37 PM   #53
Dominic.G.
Banned
My Ride: Jetblack 1999 323i
love this thread..
+1
Dominic.G. is offline   Reply With Quote
Old 10-07-2011, 01:39 AM   #54
spencers
My Ride: 2001 325Ci
Keep up the good work.
That ETA head looks so tiny!
spencers is offline   Reply With Quote
Old 10-19-2011, 07:31 PM   #55
TrippinBimmer
Today, I installed my PnP LC-1 with G3 gauge kit from blueapplesoda. Great guy to deal with and fast shipping.
http://www.r3vlimited.com/board/showthread.php?t=204722
Here is where I installed it and etc.
Video of the Gauge in Action.
Video of Cold Start
When I punch the gas really hard the gauge cuts out and comes back on. I am not sure what is wrong. The red wire that was hanging out I tap it to the distribution block on the passenger side by the firewall. Any thoughts?
Video of Gauge Cutting In and Out
-TrippinBimmer
Old 10-19-2011, 11:59 PM   #56
///Mostarac
///Mostarac's Avatar
My Ride: Sienna Red E46
this is truley a build thread. amazing work anthony!
///Mostarac's Official Build Thread
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 10-20-2011, 03:01 PM   #57
JaYaRe
My Ride: goes, Brroom Brooom
Nice build, Are you going to Turbo it???
100_0903-1
JaYaRe is offline   Reply With Quote
Old 10-20-2011, 04:34 PM   #58
TrippinBimmer
That is the Plan this Summer!
-TrippinBimmer
Old 10-20-2011, 07:27 PM   #59
Studdly_Studright
My Ride: 325xi - Mustang GT
interior looks great! keep it up
Studdly_Studright is offline   Reply With Quote
Old 10-21-2011, 12:38 AM   #60
domcreates
My Ride: Jet Black 1999 323i
I wish I had the money and knowledge to do this. Your progress looks great!
STUFF FOR SALE:
SEDAN CARBON FIBER CSL TRUNK
GET A CUSTOM GRAFFITI PHONE CASE DESIGNED BY ME:
CLICK HERE FOR PHONE CASES
POST YOUR E46 IN THESE THREADS IF YOU HAVE..
18" WHEELS
19" WHEELS
domcreates is offline   Reply With Quote
