Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 03-01-2011, 01:54 AM   #1
yemil
My Ride: 03 325i
ballast or ignitor problem?
03 325i (4d)
left xenon wouldn't turn on once in 3 times, worsening with time. Most of the cases would come on in a few minutes. I swapped bulbs and problem disappeared for several weeks after which the problem resurfaced on the left side again. How can i check if the problem is in the ballast or ignitor?
i guess i can always swap the ballasts, but i'd rather not.
Thanks a bunch!
yemil is offline   Reply With Quote
Old 03-01-2011, 02:05 AM   #2
paraklas
My Ride: ESS TS2 320ci
What is the condition of the plugs that go into ballast? Check for corrosion. Then I'd swap ballasts
Old 03-01-2011, 07:53 AM   #3
tantalize8
My Ride: Imola Red 330i zhp
I had issue and did the swap and problem always occurred on the same side. I replaced the the ignitor and never had the problem since.
FYI the ignitor is in the headlight housing. You have to remove the whole lamp assembly to get to the ignitor. good luck.
tantalize8 is offline   Reply With Quote
Old 03-01-2011, 10:06 AM   #4
Redryan98
My Ride: 07 Legacy GT 5MT
Same issue happened to me. Passenger side light would work some times, not others. Took the headlight assemblies apart. First swapped the bulbs. Problem did not follow. Next swapped the ballasts, again problem did not follow (good thing cause they are EXPENSIVE). finally swapped the ignitor and the problem did move from passenger side to driver side. Ordered a new igniter for around $80 and problem solved.
Good Luck
Redryan98 is offline   Reply With Quote
Old 03-01-2011, 10:18 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by yemil View Post
03 325i (4d)
Thanks a bunch!
If you don't want to do this then just leave your car the way it is.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 03-01-2011, 04:05 PM   #6
yemil
My Ride: 03 325i
Thanks for the input.
I'll try to get to ballasts this evening. I'll post the results.
Old 03-01-2011, 04:15 PM   #7
2003 325i
My Ride: '03 Orient Blue 325i
Same car as me... hope you don't have headlight washers... PITA
Old 03-05-2011, 04:43 PM   #8
yemil
My Ride: 03 325i
Swapped ballasts. Found no rusty or loose connections. Problem disappeared so far. I have a feeling that it'll return. I'll post once/if it does.
Old 03-19-2011, 12:44 AM   #9
yemil
My Ride: 03 325i
A month after the ballast swap the light goes out again on the same:left side. Anything else I should check before ordering an ignitor?
Old 02-04-2015, 01:22 PM   #10
dino71
My Ride: 2003 BMW 330i
Yemil, Did you ever replace the ignitor?
dino71 is offline   Reply With Quote
Old 02-04-2015, 05:28 PM   #11
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Check again for any corrosion that you can clean off on the connectors. If there is none, I think you may have found the culprit.
Sorry didn't realize that this thread was from 4 years ago.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-26-2015, 02:02 AM   #12
typeflex
My Ride: e46
Having the same problem with my passenger side headlight. When I turn on the lights only the driverside comes on, I have to turn the lights on and off twice to get the passenger side to turn on.
Can anyone save me the time on a search and tell me where replacement igniters are purchased from? Besides the stealership.
typeflex is offline   Reply With Quote
ballast, ignitor, xenon
